| Re: Crossing Situations at Multi Class Regattas
[Re: Acat230]
#71842 04/06/06 09:31 AM 04/06/06 09:31 AM |
Posts: 552 | Hey Bob, Nice post. It shows more the character of the sailors, than the character of the boats. Down here, we have multi class, with mono's too, all the time. The Beach Cats sailors are always mindful of each other, however. They watch out for one another and offer helpful solutions. We can not afford to lose any cat sailor [ we are a limited bunch to start :-) ] It sounds like the non spin cats were more mindful than the spin cats. Maybe next time, when the spin cat comes blazing in, just position ones self to anticipate a 'block' at the mark, ...then the spin boat came experiance 'being in the way'..[ wrong place at the wrong time with no place to go]... In last months regatta, I was coming into the upwind mark on port, I usually weave thru the mono's and make it,...well, this time,...not to be! ...tacked to starboard.....the wind [ and my sailing ability] disappeared at the same time [ hopelessly in irons...ugh],....and I was a bobbing obsticle, 30 feet from the starboard side layline of the mark [ port rounding],....yep,..wrong place at the wrong time....the 'true' skippers understood,...the #*@%head ones did not... ..it happens... ..keep it fun! regards, Bruce I-17 St. Croix USVI ps....when a Uni goes into irons,..it likes it![ kinda like a wife going shopping ]....and stays there for awhile :-)  | | | Re: Crossing Situations at Multi Class Regattas
[Re: Acat230]
#71843 04/06/06 09:44 AM 04/06/06 09:44 AM |
Posts: 12,310 South Carolina | A lot of jib/main sailors don't fully comprehend what a boat's capabilities are with a spinnaker flying. Spin boats just can't "come up" to avoid a leeward boat and may find themselves in a situation where they MUST bear away in order to keep from capsizing in a gust. I think a little additional knowledge in this sitatuation would have helped...that and cooler heads.
Jake Kohl | | | Re: Crossing Situations at Multi Class Regattas
[Re: rhodysail]
#71846 04/06/06 11:38 AM 04/06/06 11:38 AM |
Posts: 3,114 BANNED | As far as spinnaker boats not being able to head up in a windward leeward situation, the answer is tough luck. You need to head up and if that causes you to flip then flip you must. And that sir, is the most assholish attitude I could possibly encounter on the race course. Rounding someone up into the wind on the start line, ok, big deal, but heading up someone so high that they HAVE to capsize in order to avoid contact is grounds for an assbeating. People can get hurt on a capsize, gear can break, and purposely causing one of these situations to occur goes beyond the scope of competitive sportsmanship, into the area known as a "dickhead maneuver". My two cents. | | | Re: Crossing Situations at Multi Class Regattas
[Re: MauganN20]
#71847 04/06/06 11:50 AM 04/06/06 11:50 AM |
Posts: 4,451 West coast of Norway | Maugh, for a beercan race I agree.
If you go and play with the serious boys in grade 1 events, it's tough luck.. But then it's all about going fast, so if they can get away from you faster they wont put you into a "checkmate" situation like that. If they can do it while not slowing down, you better keep clear.
Looking forward and thinking two moves ahead will usually keep you out of such trouble. Shouting about turns etc. is uneccesary, a simple "protest" does it.
The described situation sounds like the guys on the I20 did not think far enough forward, even if the Hobie was in error.. In their defense, it's easy to sit here in my armchair and have 20/20 hindsight.
If luffed up like this, I would have dumped the main traveller and let the spi flog. That will usually save your day at the cost of some wear on the spi. | | | Re: Crossing Situations at Multi Class Regattas
[Re: MauganN20]
#71848 04/06/06 12:04 PM 04/06/06 12:04 PM |
Posts: 3,348 | As far as spinnaker boats not being able to head up in a windward leeward situation, the answer is tough luck. You need to head up and if that causes you to flip then flip you must. And that sir, is the most assholish attitude I could possibly encounter on the race course. Rounding someone up into the wind on the start line, ok, big deal, but heading up someone so high that they HAVE to capsize in order to avoid contact is grounds for an assbeating. People can get hurt on a capsize, gear can break, and purposely causing one of these situations to occur goes beyond the scope of competitive sportsmanship, into the area known as a "dickhead maneuver". My two cents. I agree. | | | Re: Crossing Situations at Multi Class Regattas
[Re: fin.]
#71849 04/06/06 12:27 PM 04/06/06 12:27 PM |
Posts: 5,590 Naples, FL | As a spin boat driver, I always assumed those boats not in my class were "obstacles" and needed to be avoided through good strategy.
Knowing that non-spin boats don't always realize what a spin boat will do on a turn leaves all that much more responsibility with the spin boat driver.
I think everyone agrees on the rules of the road, but why make the H-16 do a turn? I could see that if the H-16 and N20 were racing open fleet against each other, but I suspect they were in different classes. In that case, there seems to be no advantage gained by the H-16 getting tangled up with the N20.
If I were in a spin boat in a different class (or even different course) than another group of boats, I just do my best to negotiate around them with as little loss of position in my fleet as possible. It's all part of the tactical plan.
It's my duty to avoid a collision, regardless of whether I have right of way or not.
Please understand my position is based on the concept that BOTH boats were doing their best to avoid this messy situation. Yes, the N20 was stuck luffing or gybing to avoid contact. Yes, the H-16 should have known they would get run down by spin boats and worked to stay out of trouble. But we're all not in a perfect world. If we were, we would all tie for first place...
But sending a boat to the sidelines just sounds a little harsh, unless it's a professional (money earning) race.
I guess I'm spoiled that most races put spin and non-spin boats on different courses, or plan the starts to reduce the chance of pileups at mark roundings...
[Re: MauganN20]
#71850 04/06/06 12:30 PM 04/06/06 12:30 PM |
Posts: 894 Branford, CT | As far as spinnaker boats not being able to head up in a windward leeward situation, the answer is tough luck. You need to head up and if that causes you to flip then flip you must. And that sir, is the most assholish attitude I could possibly encounter on the race course. Rounding someone up into the wind on the start line, ok, big deal, but heading up someone so high that they HAVE to capsize in order to avoid contact is grounds for an assbeating. People can get hurt on a capsize, gear can break, and purposely causing one of these situations to occur goes beyond the scope of competitive sportsmanship, into the area known as a "dickhead maneuver". My two cents. Who's the [censored], the guy who defended his clear air or the guy who broke the rules to try and take it? | | | Re: Crossing Situations at Multi Class Regattas
[Re: waterbug_wpb]
#71851 04/06/06 12:36 PM 04/06/06 12:36 PM |
Posts: 3,348 | I guess I'm spoiled that most races put spin and non-spin boats on different courses, or plan the starts to reduce the chance of pileups at mark roundings... That is probably the only hope for a meaningful solution, imo. | | | Re: Crossing Situations at Multi Class Regattas
[Re: rhodysail]
#71852 04/06/06 12:56 PM 04/06/06 12:56 PM |
Posts: 3,114 BANNED | Who's the [censored], the guy who defended his clear air or the guy who broke the rules to try and take it?
I don't really give a crap what the rules say, If someone causes me to capsize on the course because of some maneuver they pulled and there was nothing I could have done about it, then that person is going to hear about it later. You're stuck in the "rules of sailing say I can do this" while I'm more in line with the "rules of being a good person and caring for the well-being of others and their property say that I shouldn't." Too many people think that because their "racing" means that they can be a douchebag and get away with it because they're playing inside the rules. I know my opinion isn't popular amongst those "serious" or "competitive" or "driven" racers. Again, just so we're clear, I'm not talking about using the rules to give you an advantage on the course, I'm talking about using them to cause an accident that otherwise wouldn't have happened. | | | Re: Crossing Situations at Multi Class Regattas
[Re: MauganN20]
#71853 04/06/06 01:05 PM 04/06/06 01:05 PM |
Posts: 3,348 | MAUGH17
You'll do better toning down the rhetoric. I happen to agree with you, but you can't win your point with this tone. And, you are making a VERY important point.
If this win at all cost mentality becomes the norm, I'll leave the sport. For me, either the sport will be somewhat genteel or I'll find another sport.
btw- there is a monohuller in my club that has caused two collisions in port/starboard entcounters. He was clearly wrong in both cases and just doesn't care. I don't speak to him, break bread with him or acknowledge him in any way. The problem is that others do.
I doubt if the I20 driver in this case cares what anyone thinks. Until he is censured he will continue.
[Re: MauganN20]
#71854 04/06/06 01:11 PM 04/06/06 01:11 PM |
Posts: 917 Issaquah, WA, USA | We had similar situtations at the Hobie Tiger and Hobie 17 North Americans in Monterey, CA two years ago. In most races, we had seperation, but on occasion, we did end up together. Roundings at the windward mark, and running before the spin flying Tigers did make for some interesting conditions. The conditions were about 15 to 20 knots, and five foot waves. Solution: anticipate, keep clear, and keep under control.
Caleb | | | Re: Crossing Situations at Multi Class Regattas
[Re: Acat230]
#71856 04/06/06 01:28 PM 04/06/06 01:28 PM | Anonymous
| Anonymous
Unregistered | I didn't read the whole thread and am a little rusty on rules, but isn't the overatkingboat suppose to keep clear? | | | Re: Crossing Situations at Multi Class Regattas
[Re: MauganN20]
#71857 04/06/06 01:29 PM 04/06/06 01:29 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | According to book by my rules guru Dave Perry Page 104 (then page 114) addresses a situation like this.
[color:"blue"]"When boats approach each other, they must continually assess the situation in terms of what are the probable chances that I may hit this other boat or vice versa? This judgement should factor in: what the reponses have been from the other boat, whether the other boat is keeping a good lookout, what the sailing conditions are like and how well a boat of the class involved maneuvers in such conditions, who the sailors on the other boat are, and is there anything at all peculiar about the way the other boat is being handled?"[/color]
Rule 16.1 - Changing Course When a right-of- way boat changes course she shall give the other boat room to keep clear. The give-way boat will need to keep clear. Assuming the give-way boat reacts promptly and in a seaman-like way the right of way boat must give her enough space and time.
[color:"green"]It could be argued that the right-of-way boat did not give the give-way boat ample space and time to react. The give-way boat was making effort to get out of the way.
I think this would have been interesting to see how the judges would interprete this in the protest room if there was a protest that ensued.
Later, Dan[/color]
[Re: Acat230]
#71858 04/06/06 01:32 PM 04/06/06 01:32 PM |
Joined: Jun 2001 Posts: 160 Connecticut Eric Anderson
Posts: 160 Connecticut | OK I will add my 2 cents in this.
First, back to Bob Hodges initial scenario. Both boats screwed up in a big way. First the H 16 was on the port layline approaching the weather mark in a mixed fleet with spinnaker boats rounding. Why? That is plain stupid. Why place yourself in a situation where you have no rights and you have to weave through traffic? Frankly in a windy event with mixed skill levels present, you are just asking to get hit hard. Even if you get by the ones going downwind, now you have to tack at the windward mark with no rights. As far as the I 20 goes, delaying the spinnaker set a few seconds because there was a lot of traffic would have been a good idea. Hailing protest and following through with it would have been fine also. Yelling repeated insults on the race course is not acceptable although I have to admit getting mad enough to do it myself a time or 2. We all share the same water and are suposed to be having a good time.
As far as whether you could head a spinnaker boat up and make it flip, what would be the point? First off you might violate rule 16.1 if you are not careful. Secondly his mast is likely going to come down on top of you. By the time you extricate his mast from your shrouds, your race is over anyway, and you have an enemy for life. There is a good chance one or the other of you had some significant damage (think rule 14.2). Seems like a lose- lose situation for me. This all brings up a good point. Different fleets have different values and norms. On a hobie 14 or 16 I wouldn’t think twice about enforcing my rights in a mark rounding, even if I know there will be chaos and a possible minor collision. Nor would I think twice about heading up a boat that was rolling me ½ boat length away. In the A cat, or a spinnaker boat I would not chance it, except in some cases at a Nationals. We all sail under the same rules, but the expectations are different depending on the fleet and the event.
Sail fast Eric Anderson | | | Re: Crossing Situations at Multi Class Regattas
[Re: Dan_Delave]
#71859 04/06/06 01:40 PM 04/06/06 01:40 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I think it can be very scary having boats of widely different speeds on the same course. That's why I don't like to race my Wave in multi-class regattas. I feel like a tractor on a freeway. When those spinnaker boats are flying downwind, if I can't see the people on their boat, I figure they can't see me, either. When one of them is coming straight at me, I usually just stop my boat to let them go by and try to figure out which way to jump if they hit me.
I like the way Rick sets up the courses for Tradewinds because it greatly reduces the interactions between the slow boats and the fast boats. | | |
2,490
guests, and 352
