| Re: Rivet guide does not show sizes??
[Re: Captain_Dave]
#72308 04/10/06 11:41 AM 04/10/06 11:41 AM |
Posts: 306 St. Louis, MO | When I do this, I take the part number from the rivit guide and look at the price list in the back of the catlog. That gives the dia, length, and material of the rivit.
Hope this helps...
Nick
Current Boat Looking for one
[Re: Captain_Dave]
#72310 04/10/06 02:50 PM 04/10/06 02:50 PM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave OP
Posts: 292 Ontario, Canada | Nick,
I just went through and cross-referenced the Hobie rivets as you suggested. The main rivet sizes are Monel 6-4, 6-6, 6-8, and 6-10.
Having no real experience with these rivet identifiers, can you tell me how to derive length and diameter from these numbers? By the look of things, and from the few rivets I`ve already replaced, the diameters of those above are all the same - only the length varies. So, what`s a 10 length or a 4 length for example.
Dave | | | Re: Rivet guide does not show sizes??
[Re: Captain_Dave]
#72311 04/10/06 05:29 PM 04/10/06 05:29 PM |
Posts: 306 St. Louis, MO | I have no idea what those numbers mean. Usually when buying pop (blind) rivits you get a range of thicknesses they will work for, but that won't work here (ie 6-6).
Since they come in 1/16" in dia encrements and 1/8" length increments it might be as follows:
6-6 is 6/16" (3/8") dia and 6/8" (3/4") long. 6-4 is 6/16" (3/8") dia and 4/8" (1/2") long.
Maybe someone else can shed some light on this.
Nick
[Re: Captain_Dave]
#72312 04/10/06 05:33 PM 04/10/06 05:33 PM |
Posts: 152 Central Texas | Could it be mm (as in millimeter). I remember having the same problem. I found pretty much only one common diameter for the SS rivets used on a hobie 16. I ended up using only the longest and the second to the longest rivet style - and the selves of course where needed. actually sometimes I used the sleves for "shimming" widened rivet holes.
Patrick
Patrick, Hobie 16 '85
[Re: yoh]
#72313 04/10/06 05:35 PM 04/10/06 05:35 PM |
Posts: 306 St. Louis, MO | A 6mm dia rivet is about 1/4" dia. I don't think there are any rivets that large on the H16
Nick
[Re: hobienick]
#72314 04/10/06 06:11 PM 04/10/06 06:11 PM |
Posts: 292 Ontario, Canada | I am glad to see that my question was not as "dumb" as I thought it might be. The problem remains though. I have a little bag of several sizes of Hobie rivets with no way of really identifying them. I wondered if the second number was a millimeter measurement, but I just don`t know and it seems silly to guess - there must be a measurement correlation. I looked through past posts and it seems the question has never been answered fully and the issue has been carefully "danced" around on several occassions. Apparently, I`m not the only one reluctant to admitt that they don`t know what those little numbers (ie. 6-6) actually mean. Hopefully we can "crack the code" of the rivet here! And, what an accomplishment it would be! Dave | | | Re: Rivet guide does not show sizes??
[Re: mmiller]
#72316 04/10/06 06:58 PM 04/10/06 06:58 PM |
Posts: 292 Ontario, Canada | The code has been cracked! Thanks Matt. I was kind of hoping you would save the day. That certainly clears things up. Now I can determine what the various rivet shank lengths are supposed to be. Then I can match them up to the Hobie part number on the Hobie rivet guide, and ultimately use the correct rivet for the job. Many thanks. I have a feeling that Newbies for many moons to come will be accessing and printing this post! Dave | | | Re: Rivet guide does not show sizes??
[Re: mmiller]
#72317 04/10/06 09:09 PM 04/10/06 09:09 PM |
Posts: 321 Albuquerque NM | Herrrreeee he comessss to savvvve the daayyyyy, Miiighty Matt is on the wayyyyyyyy!!!!
[b] Sail Like you have a Pair
[Re: hobie1616]
#72323 04/12/06 08:33 AM 04/12/06 08:33 AM |
Posts: 306 St. Louis, MO | One thing I have found is that Hobie doesn't price it's fasteners much different than any industrial supplier. So, for small numbers of fasteners, there is no reason to not get them from Hobie. I have tried to find the rivet "shims" elsewhere and I can't get them in small numbers for a reasonable price.
Nick
[Re: hobie1616]
#72324 04/12/06 11:23 AM 04/12/06 11:23 AM |
Posts: 1,252 California | How many years does that hold you? That would be a couple years supply here. | | |
3,195
guests, and 376
