| Re: comptip track
[Re: srm]
#72582 04/12/06 11:15 AM 04/12/06 11:15 AM |
Posts: 1,252 California | That is what the aluminum section was created for. The aluminum section snaps onto the mast. All of the tracks snap on to the different model CompTips. There is a sheet on luff track replacement you can look at. http://www.hobiecat.com/community/viewtopic.php?t=1178You will need to remove the plastic track, snap on the aluminum. Cut the plastic to fit and install. It should be a 10 minute job. Usually the luff is pulled out by counter rotation of the mast from the sail. The other "reason" seemed to be the use of the Aussie halyard ring. The welded ring would pull the luff out. The original ring and shackle combination had a "universal" action that would allow some twist without transferring it to the headboard. | | | Re: comptip track
[Re: DanWard]
#72585 04/12/06 11:56 AM 04/12/06 11:56 AM |
Posts: 330 | Yea, it was in the right place...above the hook, right?...  Just kidding. I never flipped the boat on it's side with the sail up to make sure the clamp was right at the top of the sail (although you would have to leave an inch or so anyway to release the hook and lower the sail). I just eyeballed it with the mast down, using the ring and shackle as a guide. Anyway, thanks all for the info. I'm very happy to see that I don't have to pull the whole mast apart to replace the track. sm | | | Re: comptip track
[Re: mmiller]
#72586 04/12/06 02:33 PM 04/12/06 02:33 PM |
Posts: 5,582 “an island in the Pacifi... | That is what the aluminum section was created for.
The aluminum section snaps onto the mast. All of the tracks snap on to the different model CompTips. There is a sheet on luff track replacement you can look at. Matt, Is there any way to buy an aluminum section to replace all of the plastic track? TIA US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: comptip track
[Re: hobie1616]
#72587 04/12/06 03:19 PM 04/12/06 03:19 PM |
Posts: 1,884 Detroit, MI | Is there any way to buy an aluminum section to replace all of the plastic track? Kinda defeats the purpose of the Comptip, doesn't it? The 1' section of aluminum track is a bitch to "snap" on. You have to use a rubber mallet and a good (accurate) whack to get it on. A piece the size of the whole track wouldn't snap no matter how hard you hit it. | | | Re: comptip track
[Re: mbounds]
#72588 04/12/06 03:37 PM 04/12/06 03:37 PM |
Posts: 5,582 “an island in the Pacifi... | Is there any way to buy an aluminum section to replace all of the plastic track? Kinda defeats the purpose of the Comptip, doesn't it? It does but the CompTip was implemented due to legal action not performance improvements. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: comptip track
[Re: mmiller]
#72590 04/12/06 04:06 PM 04/12/06 04:06 PM |
Posts: 5,582 “an island in the Pacifi... | I think a full length of metal track would be of no use. It also would be impossible to install as Matt B. said. Bummer. It might be possible to slide it on before the CompTip is glued/riveted to the aluminum section but it's too late now. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
542
guests, and 42
