new step casting threading problem with post #73262
04/23/06 03:56 AM
04/23/06 03:56 AM
Northern California
artley Offline OP
artley  Offline OP
Northern California
We have a 1973 H16 and are replacing the step casting. The mast step kit did not fit the old step casting. We drilled out the pop rivets and tried to thread on a new step casting. However the threading on the dolphin striker post appears to differ from that of the new casting. Is there an alternatative step casting for the H16?
Re: new step casting threading problem with post [Re: artley] #73263
04/23/06 08:53 AM
04/23/06 08:53 AM
There are three versions of the step casting, but they all have the same threads for the dolphin striker post.
Make sure the threads on the post are clean (wire brush) since there's undoubtably corrosion on a 36 year old post. Use a lubricant (WD40) when you thread the casting onto the post and back it off 1/4 turn for every 1/2 turn (like you're using a tap / die).
Re: new step casting threading problem with post [Re: artley] #73264
04/23/06 12:13 PM
04/23/06 12:13 PM
Midland
Mac05 Offline
Mac05  Offline
Midland
What is the thread size on the dolphin striker? I will be changing my step casting soon as well, and I know that the top of the threaded dolphin striker has mushroomed out inside the casting a bit. I want to clean the threads with a die or nut before putting the new casting on.
Thanks!
Re: new step casting threading problem with post [Re: Mac05] #73265
04/23/06 07:04 PM
04/23/06 07:04 PM
9/16" x 18 NF
A tap that size will cost you about $30 US
The matching die goes for about $20 US
McMaster-Carr
search for tap / die
Re: new step casting threading problem with post [Re: mbounds] #73266
04/23/06 09:37 PM
04/23/06 09:37 PM
Midland
Mac05 Offline
Mac05  Offline
Midland
Thanks Matt - fortunately I have the right tap and die for a std 9/16 - 18. I think I'll have to cut the old casting off so I don't damage the threaded post. 1972 and I think it's the original casting!
Cheers,
Mac
Sail Number? [Re: Mac05] #73267
04/28/06 11:18 PM
04/28/06 11:18 PM
Minnesota
Jeff Peterson Offline
Minnesota
What's the original sail number on your '73 H-16?
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Sail Number? [Re: Jeff Peterson] #73268
04/30/06 11:09 PM
04/30/06 11:09 PM
Midland
Mac05 Offline
Mac05  Offline
Midland
I believe it's 39150, but honestly, I would have to double check the last 3 numbers. I was out today in about 8 to 10 knots of east wind. I had a couple of good runs, but my mast and step castings are so worn that the stops don't even touch. When you reef on the main the mast turn almost 90 degrees. Still tons of fun!
Re: new step casting threading problem with post [Re: artley] #73269
06/13/06 08:35 PM
06/13/06 08:35 PM
ateam Offline
ateam  Offline
I have a new step casting and can't figure out how to get the old one off. I drilled out the pop rivets but don't see how to unscrew it from the dolphin striker. Any suggestions?
Re: new step casting threading problem with post [Re: ateam] #73270
06/14/06 07:31 AM
06/14/06 07:31 AM
See my reply to your post in the Open Forum.
