| Re: H17 Mainsail STUCK!!@#$ Help me!
[Re: MauganN20]
#7355 05/26/02 11:02 PM 05/26/02 11:02 PM |
Posts: 283 | Where are you located? Perhaps there's someone from a local fleet who can help you.
My guess is that for some reason you are unable to hoist the main that extra inch or two that it takes to get the halyard ring above the mast hook.
You also have to rotate the mast in the correct direction to get it out of the hook. I have a Hobie 20, and in my case, I rotate the mast counter clockwise to get the sail down.
The drill is:
1. Hoist main an extra few inches.
2. Rotate mast counter clockwise.
3. While mast is rotated, pull down on sail, and it should come down, and miss the hook.
If you rotate the wrong way, you could rotate it almost backwards and not get it out.
It may also be that something is fouled up there, and you may have to flip her on her side. An additional suggestion is that you get an aussie style ring, which is a twist shackle welded to the halyard ring.
Good luck! I feel your pain!
Sea ya,
Tim J.
Tim D. Johnson
Hobie 20 #690
Bald Eagle Yacht Club, Fleet 52
www.beyc.org | | | One more tip!
[Re: MauganN20]
#7360 05/27/02 05:29 PM 05/27/02 05:29 PM |
Posts: 283 | Hey,
I talked to my local Hobie 17 expert today, and he informed me that older Hobie 17s have a "keeper" at the top of the hook that snaps over the top when the sail is hooked. Does yours have this? If it does, remove it! You'll be much happier without it.
Fair winds,
Tim J.
Tim D. Johnson
Hobie 20 #690
www.beyc.org | | | Re: One more tip!
[Re: hobie541]
#7361 05/27/02 07:27 PM 05/27/02 07:27 PM |
Posts: 3,114 BANNED | It doesn't have a "keeper" per say... its a 91, so its not *That* old. The bowline knot wasn't tight on the ring, with about two inches of slack, so I'm guessing that was my problem. I'll try to retie the knot and pop it off before I go out again. Thanks for your help | | | Re: Another tip
[Re: Mal]
#7365 05/29/02 10:57 AM 05/29/02 10:57 AM |
Posts: 3,114 BANNED | Well in this case, binoculars wouldn't have done much good because the knot that was holding the ring had to much loop in it, therefore getting jammed in the top of the mast. Hopefully when I replace the halyard, I wont have this problem again ![[Linked Image]](/forums/images/icons/smile.gif) Thanks for the help again guys. | | |
17,926
guests, and 758
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 10 hours ago | | |
