| Re: Formula 22
[Re: majsteve]
#7489 06/04/02 12:16 AM 06/04/02 12:16 AM | Anonymous
| Anonymous
Unregistered | Hi David,
What is unturtle? All SC and ARC products are designed with a mast of sufficient cross section area that when the top 10 to12 ft of mast is submerged, the turned over boat reaches a stable position and the boat turns no further. I guess if the boat won't turtle under normal circumstances then the difficulty to' unturtle' the boat is a mute question.
It sounds like you have had experience with boats that do turtle. I guess their designer didn't think about the boat going turtle and boat safety at the time the mast section was selected.
Safe Sailing, no turtling,
Bill | | | Re: Formula 22
[Re: Keith]
#7490 06/04/02 12:27 AM 06/04/02 12:27 AM | Anonymous
| Anonymous
Unregistered | Thom,
You have to pick your goal and then keep your eye on it. Is the objective of the Pro Sail Circuit to determine:
1. The best catamaran sailor in the country?
or 2. Develope the fastest beach cat in the country?
Pick your goal and then the boat decision is easy.
[Re: wfo3]
#7492 06/04/02 07:16 AM 06/04/02 07:16 AM |
Posts: 195 Texas | Bill, Thom and Wf.
I do believe that the sc22 is a great boat. However, it is out of my control to say the series will be run on a specific platform. The series staff and myself have asked for input from designers, builders, sailors, sponsors, broadcasters, and publishers. Most of this input has been that the series bring in new ideas and technologies in the form of Formula racing.
I believe that there will be only 2-3 different boats on the course at best. So in car terms it will be a ford,chevy,dodge showdown much as in nascar. The only difference really is in the bodywork, car setup and driver. I know that this is a very simple way to look at it but, the idea is to develop first and then control the crazies. Most teams/builders will take the straight, narrow and reliable because there is no money to be made if your always broken down.
Oh yes and the series limits a team to how many parts/boats a team can have during a season so to limit the overall costs. Much in the way that IRL and other car series have done.
Steve | | | Re: Formula 22
[Re: majsteve]
#7494 06/04/02 07:27 PM 06/04/02 07:27 PM | Anonymous
| Anonymous
Unregistered | Hi Steve,
The Pro Circuit parallel to NASCAR doesn't hold water. We do not have established followings to three or more manufacturers with a large fan base supporting each. In beachcat sailing we do not have the equivalent of the Ford, Cheve, Dodge race car base or fan base. There is one parallel we can have to NASCAR and that is 'THE CHAMPION OF CHAMPIONS'. The Champion of Champions Race is held in identical cars. It is one design car racing! As I understand your effort, this is your goal.
Bill | | | Re: Formula 22 #7495 06/05/02 11:30 AM 06/05/02 11:30 AM |
There are several issues here.
First---- I do not believe that there is a single manufacturer that currently could build 30-40 high quality race boats in a period of a year and still maintain the light weight, low cost, uniformity that a series based upon a single boat requires.
Second ---- I personally believe that competion between designers, builders and the lot brings new technologies and innovation to the sport.
Third --- I do not think that a team who is spending their own dollars is willing to go that far over the known edge in pursuit of speed as to jepordize their chances of finishing an event.
Four --- A team must finish an event to recieve a check worth the time and effort. Even if the series pays a purse to every racing team they have to finish to make it finanically viable to race the entire season.
Five ---- The series is working to encourage a team to race EVERY event. How this will be handled I do not know yet.
I agree that if you want to see the playing field level to find out the best sailor than it probably should be run on a one-design. However, the goal of the series is provide exciting competitive sailing as a sport to the benefit of the series sponsors, sailors, the sailing community and et al.
For this the series will be run on a Formula basis, with certain rules that prohibit run-away spending and multiple platforms. Rules that encourage sailors to race every event and that reward the best sailor, builder, and designer as well as the sport.
Steve
| | | Re: Three designs and two builders
[Re: thom]
#7498 06/08/02 04:32 PM 06/08/02 04:32 PM |
Posts: 195 Texas | Thom,
The basic information is as follows:
The box rule is currently
being worked out however the following is set in stone.
LOA 22 ft
Max beam 12'6"
Minimum weight fully rigged 300lbs.
Max spar 40 ft measured from base of spar.
crew weight minimum 350lbs ( may have three crew)
Sail Area is being debated at this time and is part of
the overall design process. Designers are invited to
submit a design and recomendation for
approval/debate. Designs will be held confidential
and will not be released to any party other than the
PRO and committee without written release of the
designer/builder.
SA is a heated topic of conversation: However all designs have come in between 1000 sq ft and 1200 sq ft. The major difference is in the size of spinnaker. Since the course is primarily a windward-leeward gate with an offset mark to clear the windward mark. Most designs have been a unirig.
The design process is open with builders being encouraged to submit designs. Notice: Minimum of three boats must be built to qualify and a team can not change designs during the season also parts are limited with the exception of rigging and sails. Colors, team name, and sailors are to be registered.
Thanks
Steve
[Re: majsteve]
#7502 06/09/02 07:09 AM 06/09/02 07:09 AM | Anonymous
| Anonymous
Unregistered | Steve,
Tom Haberman and I designed and started producing the 22 in 1992. The boat was designed to have a PN of 58. That is where the boat is today. Tom has 10 years experience building these boats. Is there any reason why we have not been formally asked to suggest numbers for the Formula 22 box and the rational behind these numbers?
Bill | | | Re: Three designs and two builders
[Re: thom]
#7505 06/09/02 09:36 AM 06/09/02 09:36 AM |
There will be no minimum sail area that will be part of the tuning process for each team. As you know lighter teams don't need the same sail that heavier teams do and so on.
Personally, SA is a topic that is so hotly debated I think that the series will wait a few months after the announcement to set the max. If you look at it this way: Max spar is 40' so the max main sail area you could possibly build is 400 sq ft (note thats max just mathimatically and not practically). Probably the largest practical main is in the 340-355 sq ft range. So that leaves a spin sa of 845 sq ft. ( nothing that I would care to sail behind).
Since the series is caping the number of sails you can sail in a season to 9 total (registered, measured, marked and electronically tracked). Here is where it gets nuts. DO you build 2 mains and seven spins or 1/8,3/6, 4/5, 7/2 ?????? What do you do? Remember that this is a pro series and sail changes are expected -- hell even encouraged as it raises the level of interest. We as cat sailors are not accustomed to sail strategy but every monohull guy out there is an the series must cater to that demographic as well. I think that a good sailmaker and team can intelligently talk about weight, sa, mast and come up with 2 or 3 combinations that work for all the teams needs. But, max main plus max spin can not exceed max sa. in other words don't bring a 200 sq ft main and 1000 sq ft spin and expect to register a 300 sq ft. main also. Someone is going to scream about that but common sense is that no one is going to fly that combo together and the series is going to rely on a certain amount of self policing. To allow something like that in the tempt area is not good officiating.
Every attempt is being made to reduce costs and still provide an exciting formula racing format. Several builders want the series to run one design. Thats great for certain things but for all the reasons that have been previously posted the series will be formula and that is set in stone.
Personally, I prefer a boat that is solid and tested versus flimsy and unknown but, a 17 months is a long test period for any builder to perfect thier product. On that comment Bill will agree.
Thanks
Steve | | |
270
guests, and 43
