| Re: Trampoline Rip How do you repair
[Re: Qb2]
#75054 05/13/06 02:30 PM 05/13/06 02:30 PM |
Posts: 3,348 | | | | Re: Trampoline Rip How do you repair
[Re: StrayCat]
#75055 05/13/06 02:34 PM 05/13/06 02:34 PM |
Posts: 4,451 West coast of Norway | Brett, it depends on what kind of trampoline you have. If it is a mesh cloth tramp, I would have bought some vinly coated cloth from sailrite and stitched it to the underside of your tramp. Overlapping the edges of the tear with 50mm should be sufficient. http://secure.sailrite.com/itemdesc.asp?CartId=&ic=112011&eq=&Tp=You can easily stitch this material with a domestic sewing machine. While you are at it, buy needles and fitting thread from sailrite as well. I have no experience with other trampoline materials, but I think the above should work well with vinyl and other materials also. Qb2: Heat guns and trampolines dont mix well! Have you tried having a friend help you so you can work on both sides? | | | Re: Trampoline Rip How do you repair
[Re: Qb2]
#75062 05/16/06 03:18 AM 05/16/06 03:18 AM |
Posts: 1,382 Essex, UK | Assuming the threaded bush is still captive and all you've done is strip the thread, you should be able to repair it with a s/s thread insert. These are marketed under various names, Helicoil being one of them. The kit comes with a thread insert to the finished thread size/type you specify, a tap and an insert tool. You simply drill the old thread out to the EXACT specified size, tap it with the supplied tap, and then insert the new thread unit. It's a very cost effective and neat repair.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Trampoline Rip How do you repair
[Re: Qb2]
#75064 05/20/06 11:58 PM 05/20/06 11:58 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Qb2- On my Taipan the new tramp was extremely tight fit and I too was trying to get it on by myself. I finally figured out a way to do it by myself. First, I sprayed the tracks with dry silicone lubricant, then I attached the jib blocks at the rear inside corners of the rear beam and ran a separate line (to give me enough length to reach it from the front beam) under the tramp to the front of the boat. Then I positioned myself at the front of the boat and guiding the bolt rope with one hand while pulling the jib sheet line with the other I was able to get the tramp on. Worked well for me!!
Kirt
Kirt Simmons Taipan, Flyer
630
guests, and 403
