| Mosquito Rudders #75692 05/22/06 04:48 AM 05/22/06 04:48 AM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn OP
Posts: 502 Port Noarlunga, SA, Australia | Hi all, I have been checking out Mosquito rudders for some time now and have seen rudders from Boyer, Hallsworth, Mackenzie and Trewern, did I miss any?
I would interested to read experiences/opinions regarding rudders available in Australia, fitted to Mosquitos and similar classes.
I currently have 15 year old Boyers on my boat, they are light, well made and steer the boat reasonably well, though I have been told by several people that they used rudders the same shape as mine and didn't like the feel.
Lots of sailors have used these 15 year old Boyer rudders, what do you think?
Darryn Mosquito 1704 | | | Re: Mosquito Rudders
[Re: Dotan]
#75701 05/25/06 10:18 PM 05/25/06 10:18 PM |
Joined: Feb 2006 Posts: 135 Bendigo, Victoria, Australia colmc
Posts: 135 Bendigo, Victoria, Australia | I noticed that the photographed Mozzies have chosen to use the "Steiner" Rudder Blade. On checking the website there is also a "NACA" Rudder Blade(which appears closer to the one I am presently using). What are the advantages/disadvantages of each profile and cross section?
Col "Now What?" Mosquito 1810
[Re: Steve_Kwiksilver]
#75704 05/27/06 04:46 AM 05/27/06 04:46 AM |
Joined: Mar 2006 Posts: 97 Adelaide, Australia Tony_Snape
Posts: 97 Adelaide, Australia | I am currently adjusting rudder position as I didn't like the existing system that came with the mozzie I bought and have been forced to move things around. What I am wondering is where does everyone place or prefer to place the leading edge of their rudders... i.e. on the pivot centre line or in front, etc. Also a second question is what about rudder rake. Who has their rudders 90 degree's to the decks and who uses forward rake and who uses rearward rake and by how much and whats the prefered?
Tony
Mosquito 1743
'Phat Cat'
[Re: Tony_Snape]
#75706 05/29/06 03:45 AM 05/29/06 03:45 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Tony,
I run my rudders at 90 degrees to the deck by using a teflon block on the upper pivot gudgeons. The rudders are set up so that the bottom leading tip is exactly in line with the axis of rotation.
I used to have them set up with varying amounts of forward bias to account for poor sail shape but found that they were unpredictable at high speeds and resulted in many out of control reaches. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> If the blade is behind the axis it must behave predictably.
Peter
Mosquito 1814 Macka Mozzie
[Re: Peter_Foulsum]
#75707 05/29/06 04:32 AM 05/29/06 04:32 AM |
Posts: 97 Adelaide, Australia | Thanks for the replies..
Now you must remember I am fairly new to this sport as this will be my third season coming up and my first on a mozzie.
I found my rudders were unpredictable as they were some 40mm in front of the pivot point and the lock down system jammed every single time I used them, hence the reason I needed to change.
I have read that adjusting the rudder rake will balance the boat (weather helm) which I understand and that also raking the mast will do the same. So, can you balance using either? What I mean is I have also read that mast rake helps pointing, is this because having a lee helm would force you off the wind rather than into it with weather helm? Is this the only reason for mast rake... to induce weather helm for pointing or is there another reason.. i.e. rake the mast for good pointing then rake the rudders to balance the helm!!! This is what I am not sure about???
Tony
Mosquito 1743
'Phat Cat'
[Re: Tony_Snape]
#75708 05/29/06 06:01 AM 05/29/06 06:01 AM | Anonymous
| Anonymous
Unregistered | Hi Tony,
I often hear sailors talk about tucking their rudder blades forward past the pivot point to reduce weather helm, to my understanding this has nothing to do with the weather helm of the boat, it only effects the balance of the rudder blade itself. What it can do is stop you from feeling the weight of weather helm, which I think is a bad thing. I think it is OK to have the leading edge past the pivot point, but not to the extent you have no feel of if you are pulling on the tiller or not.
Weather helm or Lee helm is a result of the balance between the centre of effort in the sails and the centre of lateral resistance of the parts of your boats that are under water, ie.Hulls below the water line, the centreboards and the rudder blades. I don't think there is enough adjustment in any of the parts in the water to make a difference to the weather helm, apart from pulling your centreboards up.
So I always adjust the mast rake to balance the boat to the point where it turns into the wind when you let go of the tiller, but you are not constantly pulling the tiller against the weather helm to keep it sailing straight, close hauled when you are on trapeze in about 15 kts. of wind.
Regards Gary. | | | Re: Mosquito Rudders
[Re: Tony_Snape]
#75709 05/29/06 06:40 AM 05/29/06 06:40 AM |
Joined: Mar 2006 Posts: 25 Lake Bonney Yacht Club, Barmer... Andrew_d
Posts: 25 Lake Bonney Yacht Club, Barmer... | Hi Tony
Thought this extract from tuning guide for Nacra F18 might be helpful, different boat, same principles apply.. "Moving the mast aft decreases power and makes the catamaran easier to handle, hence further back in heavier winds. Also the lighter the crew, the further back the mast and visa-versa. Also moving the mast aft, allows the center of effort on the sails to move further aft and so will encourage the boat to point higher. BUT this might mean that you feel “weather helm” through the tiller, if so, “tuck” the rudders further underneath the catamaran by adjusting the screw thread on the rudder casting. When sailing upwind, with two on trapeze, you ought to be able to rest the extended tiller on the top of your index finger and the catamaran should slowly climb up into the wind."
Hope this is helpful.
What type of lock-down system are you using on your rudders?
Andrew
Andrew DeLaine
Mosquito 1734
Go-Nads II
[Re: Andrew_d]
#75710 05/29/06 07:32 AM 05/29/06 07:32 AM |
Posts: 97 Adelaide, Australia | Cheers guys...
Both of your posts explain it very well. Makes perfect sense.
1. Mast rake changes weather - leehelm balance due to change of CoE in relation to CoLR position. 2. Rudder rake balances the (amount) of feel of the weatherhelm.
The lock down system on my rudders was purely a peice of 4mm rope connected about 150mm down from the top of the rudder on the leading edge which then went up onto the rudder assembly frame and through a 6mm cleat. Everytime I used it the rope would jam between the rudder and frame and I'd be hanging off the back of the boat trying to unjam it. This would happen everytime on both sides <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />. And of course if you hit anything or picked up weed my rudders wouldn't retract, potentially very damaging.
I am replacing that with a bungee setup at the moment. Any idea's (pics) would be appreciated. My rudders are Hallsworth I think.
Tony
Mosquito 1743
'Phat Cat'
[Re: Tony_Snape]
#75711 05/29/06 08:24 AM 05/29/06 08:24 AM |
Posts: 25 Lake Bonney Yacht Club, Barmer... | Tony I am using the SmartLock lock down system (Boyer) with good results. Like everything, it comes down to personal preference, but these are simple & they work, ie. they stay locked when they should & let go when you run out of water. Go to http://www.ahpc.com.au/ & look in the Technical Support section for "Using the Smart Lock Snap Down Rudder System". There is a .pdf file with pics explaining the system. If your rudders don't have the "ears" to take the rod I can explain how that is overcome. Cheers Andrew
Andrew DeLaine
Mosquito 1734
Go-Nads II
1 registered members (FredL),
2,799
guests, and 283
