| spinaker trim #75836 05/22/06 11:11 AM 05/22/06 11:11 AM |
Joined: May 2006 Posts: 19 Chesapeake va catsailor2032 OP
Posts: 19 Chesapeake va | i have a inter 20 i need some help with the spinaker trim when the boat starts to lift do i head up to bring it under control or do i fall of please i would apreciate any info thanks
Sailing catana411. i20
| | | Re: spinaker trim
[Re: catsailor2032]
#75837 05/22/06 01:39 PM 05/22/06 01:39 PM |
Posts: 1,449 | 2032, It is the opposite to upwind sailing. Upwind you can head up to depower. Downwind if the hull is lifted and you head up your looking at making it worse and possibly capsizing. When the spinnaker is up and you want to settle things down head down. Get the boat out in light breeses and play around. You'll get the hang of it pretty quick.
| | | mast rake
[Re: phill]
#75838 05/22/06 02:06 PM 05/22/06 02:06 PM |
Posts: 19 Chesapeake va | can any one tell me the proper mast rake for the inter 20 nacra
| | | Re: mast rake
[Re: Barry]
#75840 05/23/06 03:38 PM 05/23/06 03:38 PM |
Posts: 5,590 Naples, FL | That seems a little short. I run from the spinnaker bridal tang, and see where it touches the rudder (placed in the upright position). Usually touches about 1/3 of the way down the rudder. I must have a lot more mast rake.
What's your team weight? I was usually between 325 and 365. Used about 1 3/4" of spreader rake and 700 lbs diamond tension.
3,175
guests, and 228
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
