| Re: Bondo-Glass To Fix Hull?
[Re: alan_ellis]
#75864 05/22/06 07:06 PM 05/22/06 07:06 PM |
Posts: 5,582 “an island in the Pacifi... | Has anyone ever used Bondo-Glass to fix a fiberglass Hobie hull? I've got a couple of small cracks in the bottom of the hull which allow the boat to take on a minor amount of water and was wondering if this Bondo product would work. It appears to be easier to work with than a fiberglass repair kit. We're repairing seven Sabots that have been used for a junior sailing program. They've been abused for about four years and have lots of damage. We've found that using a tube of one part Bondo works great for scratches. We are applying paint over the Bondo. For damage where the hull has been dented or punctured we're using two-part Bondo or two-part Bondo with fiber in it. We had a couple of places where the damage had been bad enough that we removed what foam was left and used Great Stuff insulating foam to fill the void. After it set we shaped it, filled in the small holes with Bondo and glassed over it. After sanding and paint it looked just like new. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Bondo-Glass To Fix Hull?
[Re: hobie1616]
#75865 05/28/06 02:52 PM 05/28/06 02:52 PM |
Posts: 152 Central Texas | IIRC all or most of the Bondo Products use polyester as a resine. Better adhesion and durability is probabely provided when you use somekind of epoxy material. In some cases you might be better up using a gel coat. Check the west systems website.
Patrick, Hobie 16 '85
[Re: yoh]
#75866 05/29/06 03:44 PM 05/29/06 03:44 PM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave
Posts: 292 Ontario, Canada | It is probably worth mentioning that polyester resin dissolves foam quite aggressively. So, if you are patching over foam, be sure to use epoxy.
Yes, epoxy is tougher and adheres better. But, it is a lot more expensive, has a much longer cure time, and is generally harder to use.
Personally, I use both. My general rules of thumb are;
- Structural damage = epoxy - Foam exposed = epoxy - Big cosmetic damage (gouges,dings) = vinyl ester (preference) or polyester - Minor cosmetic damage (scratches, small gouges) = vinyl ester or polyester - High wear spots in need of build-up (keel) = vinyl ester or epoxy with an appropriate filler and/or glass cloth
...Moral of the story - a crack letting in water would generally be classified as a structural issue and would benefit from the use of epoxy. You will need to thoroughly dry, and then clean out the crack. Then your best choice would be non-thickened epoxy followed by some thickened epoxy to fill the void. Without seeing the damage, I cannot advise whether glass cloth should be included in the repair.
Dave <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: Bondo-Glass To Fix Hull?
[Re: alan_ellis]
#75868 06/07/06 01:32 PM 06/07/06 01:32 PM |
Posts: 5 North Carolina | I had typical beach dragging type damage to my boat from years of beach trips before Cat-Trax. I used a product recomended to me by car mechanic he had used on a corvette. It was a fiberglass resin GEL. The thicker product helped to build up the edge and repair the hull profile. It wasn't pretty, but serve the purpose until I sold the boat. Good prep makes the repair. I sanded the repair area with a fairly couase grit automotive type sandpaper, to make a good maiing surface and get is clean. I layed on a couple of layers of cloth more out of precaution than anything and then rebuilt the hull shape using the thicker gel. It took tons of sanding and I ended up using an "Air File" (pnuematic inline sander) to work down the high areas. Agin this was not a pretty or professional job, but I was back sailing in a week with lots less water in the hulls.
Used to sail an H16.....now boatless
[Re: BlackDOG]
#75869 06/07/06 11:47 PM 06/07/06 11:47 PM |
Posts: 1,383 Kingston SE South Australia | I am currently repairing my stingray with West System and have found it extremely easy to use. Spend the extra on the instruction book and you will do a fantastic job, I have watched the experts do it roughly and it looked rough not to mention all the beer bottles etc stuck everywhere around the workshop. It sands easily for a pleasing tough finish. regards
[Re: Captain_Dave]
#75870 06/08/06 08:24 AM 06/08/06 08:24 AM |
Posts: 1,187 38.912, -95.37 | Using Formula 27 for the cosmetic repairs (thanks Matt B for that tip), it is poly based and very easy to shape and sand.
Now that the weather is warm enough for repairs (and warm enough to sail too <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />) I've experienced a very, very, short window of working time with this product. I've reduced the hardener significantly and see not much difference in set up time (and when it starts to go hard it's gone in a flash) and I'm wasting a lot of product.
Has any one tried mixing in a plastic cup and setting that in ice? Looking for, or will try any suggestions. I has to be better than what I'm doing.
[Re: _flatlander_]
#75871 06/08/06 06:06 PM 06/08/06 06:06 PM |
Posts: 27 | I've experienced a very, very, short window of working time with this product. I've reduced the hardener significantly and see not much difference in set up time (and when it starts to go hard it's gone in a flash) and I'm wasting a lot of product.
Has any one tried mixing in a plastic cup and setting that in ice? Looking for, or will try any suggestions. I has to be better than what I'm doing. I had a similar experience with West System epoxy. I had mixed a batch of 200 grams: after several minutes, the mixture began to smoke, became very hot, and then turned solid within a few seconds. Nothing to say against West System! I reread the manual and found that there's "weight limit": I wasn't supposed to mix batches bigger than 100 grams. Possibly your batch size caused you having the short window of working time? H77 | | | Re: Bondo-Glass To Fix Hull?
[Re: h77]
#75872 06/09/06 08:09 AM 06/09/06 08:09 AM |
Posts: 1,187 38.912, -95.37 | No, I least I don't think so. My scientific measurement is a pool about 3 to 4" diameter. Don't know how many grams.
[Re: _flatlander_]
#75873 06/09/06 09:59 AM 06/09/06 09:59 AM |
Posts: 306 St. Louis, MO | One way to help out with this problem is using a different hardener for higher temp environments. Also, instead of mixing in a cup or other small container, mix on a board and spread out the epoxy. This will allow the heat of the chemical reaction to disperse more. When the epoxy cures, it creates heat. Heat adds more energy to the mixture causing it to catalyze faster. It's a snowball effect. If you are going to chill the mixture, chill the parts before you mix them. I keep a resin and hardener in my fridge for summer repairs. For more detailed information on epoxy check out these guys. CLC Boats They really know thier stuff. Though most of thier problems are dealing with the epoxy being too cold during the winter.
Nick
Current Boat Looking for one
[Re: jmhoying]
#75877 06/10/06 06:12 PM 06/10/06 06:12 PM |
Posts: 1,383 Kingston SE South Australia | I have seen the cup melt and gear going everywhere and was wary about using it myself, but I purchased the west system manual for $11 read it then did it exactly as per the book which included buying the pump dispensers and never got any excess heat for a very pleasing job. I mixed it in a plastic drink cup for each batch stirring with a piece of broken steel tape measure and recoated the entire decks using a small foam roller.
3,933
guests, and 548
