| Re: Wave backrests...my two cents worth...
[Re: Paul_Yezbak]
#76425 06/13/06 12:37 AM 06/13/06 12:37 AM |
Posts: 15 Seattle wash | I have the back rest on both of my Waves. Its great it was a little tough to get the end caps out they are rivited and siliconed in. I drilled the rivits and then worked it until it came out then cleaned the scone out of the cross bars. I have the pins in one and the screws on the other I've taken both off and put them back on before but no need to unless you are racing (and I can't seem to rally any adult Wave owners around here to race) or there is a space problem.I also have the Hooter on one and its great for off wind its a big difference. I like the pins the best but sometimes the pin slips out so you can put nylon slip ties on and around the back rest bars and that works but the screws are fine too they can back out also so watch for that.I attached a line around the backrest and the cross bar and atached my blocks to those for my Hooter sheets so I don't sit on them when I getway back on the hulls. Mark
another sailor
[Re: mmiller]
#76427 06/24/06 03:51 PM 06/24/06 03:51 PM |
Posts: 6 fort scott ks | I put the backrest on my wave the first of june. It does make the boat more comfortable. In heavy wind I sit over the back support. It feels pretty sturdy. It certainly adds another dimension to wave sailing. It looks cool too! I just got a drill bit the same size as the quick pins drilled a hole and mounted the backrest. They seem to work just fine. Randy
rbrazz
[Re: rbrazz]
#76428 07/03/06 11:45 PM 07/03/06 11:45 PM |
Posts: 6 fort scott ks | Does anyone sail in heavy wind sitting on the backrest? I try to be careful not to put too much stess on the backrest but, it is fun to sit on the backrest and use it like a trapeze. But, it feels like I need a tiller extension and a way to keep the mainsheet from being cleated. I have to sit scrunched over and hold the tiller and keep the main sheet not cleated in. Does some one have their boat set up for this? Do you have some tiller extension or main sheet alteration or some trick? thanks rbrazz
rbrazz
681
guests, and 362
