| Re: Wings + More sail area = faster ?
[Re: surfer64]
#76498 05/31/06 04:59 AM 05/31/06 04:59 AM |
Posts: 9,582 North-West Europe | In summary,
In high winds you'll want the same sailarea or less with preferably more righting moments. So don't add sail area here. If anything add righting moment = wings
In light winds you'll want more sail area high in the mast. This won't happen with the jib and the I-20 spi is already very large. This means that its area is relatively bit in relation to its luff length. Luff length is more important performance wise then area in a spi. Afterall the 350 sq. ft. Nacra 60 NE spi is not faster then the standard 270 sq. mtr. I-20 spi. So you'll be making costs for hardly any gains. Not smart.
30 inches = 0.76 mtr. 18 lbs = 8 kg => 16 kg in total
Basic I-20 righting moment 150 kg crew = 787 kgm With wings = 922 kgm = 117 %
With this increase I would just keep the current sailplan and just add wings if you really want that. I big winds you may expect some 5% more speed if the wings don't hit the water etc. Mostly when beating to weather. On downwind legs you won't win much at all.
[Re: MauganN20]
#76501 06/01/06 01:04 PM 06/01/06 01:04 PM |
Posts: 591 Bradenton, FL | Some of the old open-class Worrell boats had wings that could flip up on the downwind side so they didn't touch the water. Adds complexity and weight though, I'm sure.
Hobie 14T
[Re: surfer64]
#76504 06/01/06 02:51 PM 06/01/06 02:51 PM |
Posts: 96 | Adding larger wings may work best ,this was the approach taken by several earlier 1000 mile race entries . If the basic math is taken into account a 400 lb crew moved out 2 ft provides an added 800 ft Lbs of righting moment to help hold the boat down as wind increases . Move them out 10 ft and the ft Lbs becomes 4,000 --wow . The I-20 has wide flat large volume forward sections so it can handle some of the added forces from a 10 ft wing without pitchpoling ---right away . <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> The other corespondng modification might be smaller forward placed hydrafoils http://www.foils.org/sailfoil.htm and these could aslo act to balance the spin set on a longer spin pole --say 15 ft . this increases spin luff angle and also creates added lift . Check out Aussie 18 skiffs for examples of spin luff angle and lift . http://jameswebb.ca/gallery/Aussie18Crashes It would also be a good idea to lengthen the forstay a little and rake the mast back more . There is a speed trials on San Fran Bay in June ,--this would be a great craft to enter . | | | Re: Wings + More sail area = faster ?
[Re: surfer64]
#76505 06/03/06 09:04 PM 06/03/06 09:04 PM |
Posts: 1,307 Asuncion, Paraguay | Having sailed a Hobie 21, I must agree that wings ARE comfortable. If I were you, I'd just buy from Hobie the wing model that best fits the specific boat, instead of making a new design and going through the trouble of building it. Less worry about things going wrong, less suppliers, more time to cruise, spares available...
Luiz
[Re: surfer64]
#76506 06/05/06 09:45 AM 06/05/06 09:45 AM |
Posts: 552 | Hello All,
Go to the Hobie FX-1 site in France.
One has to do a little 'hunting', but there are pictures of 'racks' for the FX-1
They are quite innovative, not the 'passenger' models,..rather, the 'race' versions.
I remember 3 models.
One was a 'short' extension, maybe 8 inches out from the hull.
The next was 20-24 inches out. Made to hike off of.
The last was the largest extension and set up to sit on.
My needs for my I-17 was the 2nd model[heavy weather], but I do not need any material [ other than support] forward of the d-board well [ just d-board back to say, 1 foot behind rear x beam]
Throw a couple footstraps on,...and bam,..you are ready to fly!
regards,
Bruce USVI <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> | | |
1 registered members (FredL),
343
guests, and 59
