| Re: suggested use for 87 inch carbon tube
[Re: GeoffS]
#77254 06/09/06 11:13 AM 06/09/06 11:13 AM |
Posts: 371 Michigan, USA | Geoff,
On my A2, the mainsheet goes to the end of the boom and sheet tension also forces mast rotation, the rotation being limited. This mast rotation control is very important to tuning the A2 rig. The mainsail is attached to the boom and allows outhaul adjustment independant of mainsheet tension. It all works pretty well. Personally, the mid-boom sheeting systems felt awkward when I tacked because I have always had mainsheets that went to the end of the boom or mainsail. Others swear by the mid-boom system. You see about everything on the A-Class cats.
Les Gallagher
[Re: Keith]
#77255 06/09/06 11:19 AM 06/09/06 11:19 AM |
Posts: 163 Atlanta | Depending on your A-Cat, you could always rig a small spin set up for it, just like those videos of the Marstrom... Right now I am enjoying not having a spinnaker too much! My rig time has been reduced to almost instantaneous and the boat still really moves downwind. I know I am not sailing as deep, but I have been surprised by how much the boat feels like my previous spin boat (I-17R) going downwind (heat it up fall off etc.). | | | Re: suggested use for 87 inch carbon tube
[Re: GeoffS]
#77256 06/09/06 12:56 PM 06/09/06 12:56 PM |
Posts: 371 Michigan, USA | GeoffS, Right now I am enjoying not having a spinnaker too much!
My rig time has been reduced to almost instantaneous There has been a number of things that the Michigan F17 Fleet has done to make set-up and take-down time shorter. It takes significantly less time for me with my 2006 F17 than it did with my 2000. Lots of quick connects (tiller cross bar ends, boom-to-mast, rotator arm to rotator control line, rotation control lines on platform to rotation control lines on boom, spinnaker pole to bridle, mainsail to boom, mainsheet to boom) that make the setup sweet. I also have found a way to keep spinnaker sheet on the platform threaded thru the blocks while still retaining mid-sheet attachment to clew of spinnaker. The whole spinnaker rig stays with the spin pole. It is WAY quicker than what I did with my 2000 F17.
Les Gallagher
[Re: GeoffS]
#77257 06/09/06 01:51 PM 06/09/06 01:51 PM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista
Posts: 351 Santiago, Chile | Andinista: If you weren't in Chile, I'd find a way to mail it to you. I hope you'd do a better job managing your fore-aft weight distribution than I did when I broke it.
Thank you! I was just joking.. | | | Re: suggested use for 87 inch carbon tube
[Re: sparky]
#77258 06/10/06 07:23 AM 06/10/06 07:23 AM |
Posts: 805 Gainesville, FL 32607 USA | Re: Split outhaul/mainsheet- These work nicely on a CF sailboard mast converted to a boom. The further you separate these 2 connections, the more you bend any boom. Keep the 2 close (6 cm- 2.4 inches) and even a puny thin-wall aluminum boom will be ok. Reinforce it if it looks too bendy- before you break it is best! NOTE: If you put up a different sail with longer or shorter foot, then change the length of the little retaining line- end of boom to the mainsheet.
3,115
guests, and 352
