I 20 rudder question #77786
06/16/06 09:46 AM
06/16/06 09:46 AM
Crofton, MD
Chris9 Offline OP
Chris9  Offline OP
Crofton, MD
I’m looking for ideas with a rudder problem. Here are the details:
2001 Nacra I 20. Rudder, when loaded up no problem. When not loaded, the stainless, screw that goes into the rudder casting from the top gudgeon wiggles. Annoying as annoying gets and is probably getting worse.
Possible solutions?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: I 20 rudder question [Re: Chris9] #77787
06/16/06 10:16 AM
06/16/06 10:16 AM
Put a nut on the screw to tighten it down. Rake is about six threads showing from the casting, then after the nut is on (depending on nut size) it's only one or two threads showing.
Re: I 20 rudder question [Re: ] #77788
06/16/06 12:18 PM
06/16/06 12:18 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
I used to tighten the nut against the casting when the rudder was on the pintle, then the whole threaded eye turns tight against the pintle and is supper snug.
[infusion GBR7]
Re: I 20 rudder question [Re: TEAMVMG] #77789
06/16/06 01:59 PM
06/16/06 01:59 PM
Don't turn the nut tight against the casting while on the pintle, as this can hurt the integrity of the pintle weld. Tighten the nut while the rudder system is off the boat, just make sure the eye of the screw fits over the pintle properly.
0 registered members (), 685 guests, and 325 spiders.
