| Trailex trailer for Wave and H16 #78597 06/26/06 11:25 PM 06/26/06 11:25 PM |
Posts: 31 orlando, fl | Hi I currently sail a Wave but will be sailing a Hobie 16 soon. I want to get a trailer that I can use to transport my Wave now, but one that can also carry a H16 when I eventually get one. Does anyone have the Trailex TX-416-HC? I hear this works great for the H16, but can it be used to carry a Wave too? On the website photo I see the grooves on the side that carry the hulls of a H16. Can these grooves be moved in to accomodate the 7-foot beam of the Wave? thanks! -Will P.S. here's the link to a picture of the TX-416-HC from Trailex's site... http://www.trailex.com/photos/full/tx-416hc.gif | | | Re: Trailex trailer for Wave and H16
[Re: bvining]
#78601 06/27/06 08:23 AM 06/27/06 08:23 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | I have intended to write an article about trailers. The crux of it all is simply make a flatbed trailer.
I have several trailers, mostly Trailex. I started off with a Hobie 18, Nacra 5.5, Mystere, 6.0, Nacra 6.0, Taipan 4.9, Taipan 5.7 and now a Wave (3 of them, actually)
I was constantly having to adjust padding, rollers or whatever.
Finally, it came to me. I stripped all that stuff off the trailer, bolted on two 3/4" Marine Plywood 4x8 pieces to make an 8x8 flat bed. Went to the local carpet store trash container and pulled out some really cushy stuff and padded the trailer. Voila! (a little french lingo there) a trailer that can handle any boat any time.
I can also load 4 Waves on my biggest Trailex which was designed to handle 2 20' cats with a total weight of close to 1000 lbs.
Another use of this idea.., just build some framing for siding and you can haul all kinds of stuff while you are not hauling a boat.
Rick | | | Re: Trailex trailer for Wave and H16
[Re: RickWhite]
#78602 06/27/06 11:52 AM 06/27/06 11:52 AM |
Posts: 5,582 “an island in the Pacifi... | Another use of this idea.., just build some framing for siding and you can haul all kinds of stuff while you are not hauling a boat. Be aware that the axle is not designed for a lot of weight. If you carry a lot of heavy loads above the axle's weight rating you may be passed by one of your wheels while crusing down the road. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Trailex trailer for Wave and H16
[Re: will_FL]
#78605 06/28/06 06:55 AM 06/28/06 06:55 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | With the flatbed, just as any other trailer, you have to tie the boat down. I use those ratchet type tie down and criss cross from starboard beam to port frame of trailer, and vice versa, front and back.
I am usually pulling them with my diesel RV. While I can go about 85 with it, I usually travel at 60. Otherwise, the boats get covered with diesel soot and my mileage drops drastically. At slower speeds I get over 10 mpg.
With the car, I pull the trailex at whatever speed limits are + 5 mph. No problems yet.
[Re: will_FL]
#78606 06/28/06 07:04 AM 06/28/06 07:04 AM |
Posts: 12,310 South Carolina | You don't have to get an aluminum trailer - a galvanized trailer will be about 1/2 the cost. I'm sure there are dealers around you but you might try www.Sailmax.biz to look at that option.
Jake Kohl | | | Re: Trailex trailer for Wave and H16
[Re: sruffner]
#78609 06/28/06 09:33 AM 06/28/06 09:33 AM |
Posts: 1,246 Orlando, FL | Just came back from Daytona (I-4) doing about 75-80 mph. I was admiring how the boat/trailer really could handle the speeds.
I think the tramp' DOES provide some sail (lifting) ... In fact I don't think my tires even saw the pavement over 70 mph <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Now if I could only keep the "pointy" side up on the water like on the trailer ........
USA 777
[Re: sruffner]
#78611 06/28/06 09:38 AM 06/28/06 09:38 AM |
Posts: 2,921 Michigan | So, butting in on another thread with another newbie question:
I have an EZloader galvanized trailer which I just got with my boat. I'm pulling it with a Ford Ranger.
The question I've got is this: bringing the boat home, I was doing only about 60-65mph on turnpike/interstate, but up around 65 the wind effects boat appeared to become noticeable, I expect this to get worse at higher speeds. I had some concerns about trailering with the tramp installed, believing it might provide some wing/sail effect making the trailer even more squirrely back there. What says the collective? Should I never go these speeds, tramp or no tramp? have you checked the tongue weight? | | | Re: Trailex trailer for Wave and H16
[Re: PTP]
#78612 06/28/06 10:28 AM 06/28/06 10:28 AM |
Joined: Jun 2006 Posts: 35 Charlottesville, VA sruffner
Posts: 35 Charlottesville, VA | Just came back from Daytona (I-4) doing about 75-80 mph. I was admiring how the boat/trailer really could handle the speeds. Heh...yeah, I'm more likely to stick to ~72...the troopers around here in the mid atlantic are a little tougher on that. I know your stretch of I-4 though, so I'm not surprised... have you checked the tongue weight? You know, I haven't really. The tongue weight is actually quite low, because I can lift the tongue move the trailer, with the boat on it, by myself without much trouble. I expect the tongue weight is about 50lbs, perhaps a little more. I think of squirelly behavior when there is too much weight, but I guess too light would do that too. This trailer used to have a platform screwed to it - looks like some old OSB - that rotted out and was just yanked off. I was thinking of replacing that with marine grade 3/4" ply and putting astroturf on it. I need to build a sail box anyway, so I can put that up front to increase the tongue weight. Thanks for the tip! | | |
2,423
guests, and 262
