| Re: moving spinnaker pole / moving mast
[Re: Kennethsf]
#79455 07/07/06 05:02 AM 07/07/06 05:02 AM |
Q1 : Having the spinnaker on the lee side of the boat (relative to centreline) really cuts down on the leehelm that you get. Placing it more to windward (relative to the centreline) will therefor increase leehelm. In short, you may well upset the balancing act in forces on the rudders.
Additionally the flow on the luff side of the spi needs to clear the jib/mast/mainsail. By placing the spi more to windward you are closing off this slot. We all know that a jib that is too small will backwind the mainsail and make the baot feel bound up and slow.
Also it is too cumbersome and costly for too little gain.
Q2 : Benefits are to small on a bouy race course and the adding of a spinnaker negates much of the need to rake your mast forward or straight up for optimal performance. In short to cumbersome and costly for too little gain.
There is one golden rule on spinnaker boats : Simpler is faster !
On spi boats systems must be simple and work very well otherwise the gains are fully negated and you are better off without them.
System to gybe the spi pole and rerake the mast while sailing do not satisfy these criteria.
Greg goodall ones told me that during training for the F18 worlds in 2004 they found that each second of delay in setting and powering up the kite they would lose 10 mtr distance relative to the other boats. How many seconds do you need to rerake the mast and gybe the pole to windward at each gybe ? Do you think that the extra boatspeed is large enough to overcome these initial losses of about 100 to 200 meters ?
[Re: Kennethsf]
#79457 07/07/06 09:15 AM 07/07/06 09:15 AM |
I don't know really, putting the spi pole on the centerline has noticeable slot size (between its luff and the mast/jib luff) advantages. You don't want this to be closed off to much.
I personally don't really see the advantages of putting the spi to luff, What do you think are the benefits ?
[Re: Wouter]
#79458 07/07/06 02:31 PM 07/07/06 02:31 PM |
Posts: 1,459 Annapolis,MD | Moving the asym spin tack to windward is a trick done on bigger multis (F-boats) for lighter air and heavier air, where driving the hot angles to make the spin work doesn't always pay off. Moving the tack to windward makes the sail work a little more like a symetrical, allowing you to drive deep. Something some of the f boats seem to have figured out when sailing in those conditions against monos with symmetrical chutes. While they're sailing hotter angles faster, the monos are killing them by driving deep. Would this pay off on smaller lighter boats? Maybe not so much in heavy air, but in light stuff it just might. The thing would be to drive deep with things bagged out.
Being able to move the asym tack to the lee would definitely help in trying to carry the spin at higher angles than normal.
For a bouys course this would definitely be more hassle than it's worth, especially one design. But, on a distance race... | | | Re: moving spinnaker pole / moving mast
[Re: Kennethsf]
#79459 07/07/06 06:34 PM 07/07/06 06:34 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | Wouter,
thanks for the explanation, so if i understand correct....
Moving the pole windward in combination with a different cut for the spi and/or jib might be worth it. [but mainly on long distance- if seconds are lost] If the system would work without extra seconds los it will be worth on bouy racing as well.... correct?
Mast - don't mess with it; basicly What boat are you sailing? Tiger Mike | | | Re: moving spinnaker pole / moving mast
[Re: Keith]
#79460 07/07/06 09:17 PM 07/07/06 09:17 PM |
Joined: Jun 2006 Posts: 110 Northern California, USA RyanMcHale
Posts: 110 Northern California, USA | Moving the asym spin tack to windward is a trick done on bigger multis (F-boats) for lighter air and heavier air, where driving the hot angles to make the spin work doesn't always pay off. Moving the tack to windward makes the sail work a little more like a symetrical, allowing you to drive deep. Something some of the f boats seem to have figured out when sailing in those conditions against monos with symmetrical chutes. While they're sailing hotter angles faster, the monos are killing them by driving deep. Would this pay off on smaller lighter boats? Maybe not so much in heavy air, but in light stuff it just might. The thing would be to drive deep with things bagged out.
For a bouys course this would definitely be more hassle than it's worth, especially one design. But, on a distance race... Thank You for attempting to think "Outside the Box" allthough I hate the term as it is usually applied, sometimes it makes sense. Just because It hasn't been done doesn't mean it can't be done. It might not make a big difference, but winning by a tenth of a sec. is still a win. Every little bit helps, potentially!!!! If the downside doesn't override the upside.
Ryan McHale Hobie 14 (battened jib)
[Re: RyanMcHale]
#79461 07/07/06 11:36 PM 07/07/06 11:36 PM |
Posts: 3,114 BANNED | Just because It hasn't been done doesn't mean it can't be done. It HAS been done before, and shown to not be effective for bouy racing. | | | Re: moving spinnaker pole / moving mast
[Re: C2 Mike]
#79462 07/08/06 05:30 PM 07/08/06 05:30 PM |
Joined: Jun 2005 Posts: 133 The Netherlands Kennethsf OP
Posts: 133 The Netherlands | Wouter,
Mast - don't mess with it; basicly What boat are you sailing? Tiger Mike I'm sailing a Nacra F18 . Since Round Texel I'm wondering about this, first +/- 15- 20 km were Spi-able. we needed to tack right above the island because we could not go deep enough [to the wind that is]. I was thinking about using two "spreaders" horizontal be to move the spi pole | | | Re: moving spinnaker pole / moving mast
[Re: davidtilley]
#79465 07/10/06 03:56 AM 07/10/06 03:56 AM |
Posts: 9,582 North-West Europe | If we follow the "...its been done before..." we all need to pack up and go home.
Good point, while I personally don't see an advantage worth persue right away I'm all for some real life testing. But not on my boat as I have a jib and strut that go all the way down to the spi pole. So who else is going to take this up. Wouter
[Re: Kennethsf]
#79467 07/10/06 05:32 AM 07/10/06 05:32 AM |
Posts: 1,449 | Kenneth, Moving the spi pole to windward:- I tried this around 10 years ago. At the time it seemed to give me the same speed with a lower angle. However, the current spinnaker shapes have you going so fast that you are just wasting time adjusting things like this.
The sooner you can get motoring with the kite up the better.
Maybe it could provide a benefit in distance racing.
I wouldn't bother with it around the bouys.
Regards, Phill
2,652
guests, and 166
