| Re: N20 ?
[Re: Chris9]
#79753 07/10/06 11:26 AM 07/10/06 11:26 AM |
Posts: 12,310 South Carolina | On my n20, a line attached to the boom limits my outhaul. Why?
Is anyone changing their outhaul setting when going downwind? Chris, I asked the same question earlier this year - it was on Frank's I20 my F18 as well. Apparently, before they started building the mainsails with the plastic sail slug on the luff/foot of the main, it was possible to pull the main sail out of the mast track by cranking the outhaul. The line was put in place to limit the outhaul travel so this wouldn't happen. I use it now on my F18 but only set it to my desired upwind setting so that when we're rounding Cmark, I just yank on the outhaul until the line catches it. I don't have to look at it to know it's where I want it.
Jake Kohl | | | Re: N20 ?
[Re: Chris9]
#79754 07/10/06 11:59 AM 07/10/06 11:59 AM |
Posts: 1,203 uk | Because the boom angles upward toward the back of the boat, pulling on more down-haul also has the effect of tensioning the foot tension of the sail. When we were first sailing the 20's, some guys were pulling on the outhaul too much in the rush to get sorted at the leeward gate, then jumping out on the wire and hammering the downhaul which over tensioned the outhaul and pulled the bottom of the sail out of the mast. To set the correct length of this limiter line, rig the sail with loose out-haul, pull on a shed load of down haul, then pull on out-haul until it is snug. This is then the position of max out-haul and the line can be adjusted accordingly. In a decent breeze, letting off the down-haul also eases the outhaul enough. Only in really light stuff did we use the actual control on the boom the add more camber.
487
guests, and 233
