Homemade Righting Pole #79757
07/10/06 10:45 AM
07/10/06 10:45 AM
M
Michael_Imhoff Offline OP
M
Has anyone made their own "power righting pole"? It seems like it would only require a pvc or slightly stronger 6 foot pole, with an adapter (larger diameter pole) clamped onto the dolphin stryker...?
I'm trying to figure out how one costs ~$250, what's so expensive?
Cheers!
Re: Homemade Righting Pole [Re: Michael_Imhoff] #79758
07/10/06 10:54 AM
07/10/06 10:54 AM
I wouldn't use PVC, it'll flex too much.
Use an old windsurfer mast.
Re: Homemade Righting Pole [Re: Michael_Imhoff] #79759
07/10/06 11:20 AM
07/10/06 11:20 AM
Most of those use a carbon fiber tube for the pole in order to keep the weight down - that is the bulk of the cost. A PVC tube would be too flexible and you probably wouldn't be able to get out to the end of it before it buckled.
Re: Homemade Righting Pole [Re: Jake] #79760
07/10/06 01:23 PM
07/10/06 01:23 PM
CT
jbugbee126 Offline
jbugbee126  Offline
CT
Best this to get is the Murrays big bag, and make your own 4:1 system. Cost me around $125 for everything.
Re: Homemade Righting Pole [Re: jbugbee126] #79761
07/10/06 01:28 PM
07/10/06 01:28 PM
M
M
What are the advantages of a righting pole over a water bag? I would think the righting pole will be MUCH quicker to work with... Have a righting line on my boat, but have never flipped it; just want to prepare myself...
Care to explain how you did your own 4-1 system to a newbie?
Cheers!
PS - You make it to Candlewood Lake yet?
Re: Homemade Righting Pole [Re: jbugbee126] #79762
07/10/06 02:40 PM
07/10/06 02:40 PM
Why buy from Murrays, when there is an ONLINE store here! <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
Re: Homemade Righting Pole [Re: Michael_Imhoff] #79763
07/10/06 04:04 PM
07/10/06 04:04 PM
srm Offline
srm  Offline
I've wondered about the righting pole too. I'm assuming it only works when the boat is on it's side, so do you have to hav a separate rope just incase the boat goes turtle?
Also, I assume the boat pops up right away with the pole, but if it doesn't, you're left doing a pull-up on the bar.
Re: Homemade Righting Pole [Re: Michael_Imhoff] #79764
07/11/06 02:52 AM
07/11/06 02:52 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
If you cant find an old windsurfer mast, try a round aluminum tube. Cheap - something like $8/ft for a 2" round section per foot.
I wouldnt bother with buying a premade righting pole, you can rig up something with standard fittings and rope.
Bill
Re: Homemade Righting Pole [Re: bvining] #79765
07/11/06 11:13 AM
07/11/06 11:13 AM
M
M
I found this last night: http://dgaleana2.proboards56.com/in...action=display&thread=1146112173
Might give this a try, although I'm hoping to find a better way to mount it to the dolphin stryker.
Cheers!
Re: Homemade Righting Pole [Re: Michael_Imhoff] #79766
07/12/06 06:13 PM
07/12/06 06:13 PM
CT
jbugbee126 Offline
jbugbee126  Offline
CT
Actually I did buy it from Cat Sailor, but its a Murrays non the less a few dollars cheaper!. I dont think that a bag is that much slower to use than a pole. Maybe 30secs to a minute to fill that bag longer than deploying a pole, but the advantage is that it is as light if not lighter than most poles, and it can be used to right a turtled cat as well as one on its side. (I have don this and it works well).
A pole will not be of any use in righting a turtled cat and to me seems like a waste of money compared to a bag. Plus in the event you need to stay put, the bag can also act as a sea anchor.
I can show you mine Mike if you want to get together. I'll call you when I get the new bottom on my boat done and am ready to go sailing again.
-Jeff
Re: Homemade Righting Pole [Re: jbugbee126] #79767
07/13/06 06:41 AM
07/13/06 06:41 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Another newbie with a silly question does the old windsurfer mast with extra flex aid in righting the boat or have any other advantages over aluminium besides weight?
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Homemade Righting Pole [Re: JeffS] #79768
07/13/06 06:46 AM
07/13/06 06:46 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Its not the extra flex that is attractive. It is the masts greater ability to take the strain without going into failure. It will bend without kinking.
Re: Homemade Righting Pole [Re: jbugbee126] #79769
07/13/06 09:27 AM
07/13/06 09:27 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Jeff,
Would you please explain how to use a righting bag to assist in getting a cat out a turtled position?
Thanks!
GARY
Santa Monica Bay
Re: Homemade Righting Pole [Re: Michael_Imhoff] #79770
07/13/06 01:58 PM
07/13/06 01:58 PM
maui
jollyrodgers Offline
maui
That link shows a heavily overdesigned righting pole system, and it looks fairly heavy.
a foot of quarter inch prestretch is all you need to connect the pole to the dolfin stricker. the other end of the pole just needs a length of line to tie the pole to the top hull. all that line in the system would only be necessary if you flip often so the pole is pre attached to the windward hull. you could STF for previous posts on this subject.
Re: Homemade Righting Pole [Re: bobcat] #79771
07/13/06 05:15 PM
07/13/06 05:15 PM
JeffS Offline
JeffS  Offline
Thanks for the reply bobcat
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Homemade Righting Pole [Re: hobiegary] #79772
07/13/06 05:23 PM
07/13/06 05:23 PM
CT
jbugbee126 Offline
jbugbee126  Offline
CT
I have attached the Murrays instructions that came with my righting bag. I have righted from a turtle position once (on purpose) and it works OK, but you really need to fill the bag up to the top, (I'm only 140lbs).
-Jeff
0 registered members (), 557 guests, and 364 spiders.
