Attaching a self tacker #80142
07/13/06 02:36 PM
07/13/06 02:36 PM
Houston, Texas
EasyReiter Offline OP
Houston, Texas
I am about to attach my new self tacker to the front crossbar,(I20) has anyone had an mishaps doing this that I should be careful of?
Marc Reiter I 20 #861 Dikes, Ferries and Tramps. www.texascitydike.com
Re: Attaching a self tacker [Re: EasyReiter] #80143
07/13/06 02:41 PM
07/13/06 02:41 PM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
I think Jake Kohl has done this and had something about his experiences on the Sailmax website. You could probably find something on it with a search of the Open Forum.
Les Gallagher
Re: Attaching a self tacker [Re: EasyReiter] #80144
07/13/06 03:03 PM
07/13/06 03:03 PM
Is it the new welded aluminum one or the fiberglass one?
Some of the detail during installation of the aluminum one is in this post and there is more detail if you click on the link to go to the flikr images:
http://www.teamseacats.com/?p=94
Note, I'm trying to get the links working properly on our blog software...this link may change - if it doesn't work, post here and I'll update with a new link (or you can just search on the team seacats site for "tacker").
there's not much to it...although I don't think the measurement is in the blog. I can measure the horizontal line the rivets are in on the one I mounted and post here tonight - it's just right.
Re: Attaching a self tacker [Re: Jake] #80145
07/13/06 06:39 PM
07/13/06 06:39 PM
Houston, Texas
Houston, Texas
Yes it is the new aluminum one, someone said to put nuts behind the two end screws and I have done that and may just put nuts on all the screws. The link worked and I would apreciate the exact mesurment to the line I will look at the tabs and see if any are shorter than others they all looked the same when I assembled it.
Re: Attaching a self tacker [Re: EasyReiter] #80146
07/13/06 09:38 PM
07/13/06 09:38 PM
if you take a metal tape measure, hook the end in the track in the top of the beam. Pull it forward and bend it around the front curve of the beam. The centerline of the rivets is right on 2". You might want to add slightly and go 2 1/8" to 2 3/16" because if this traveler is left up when stepping the mast, the mast base can catch on it. Other than that the trimming position is pretty good there.
I did see one F18 pull two screws out of the backing plate...they do a poor job tapping those and I kinda wonder if they don't just run the screws in a regular hole and forgoe the whole tapping process.
Re: Attaching a self tacker [Re: Jake] #80147
07/14/06 07:17 AM
07/14/06 07:17 AM
We run our traveler car halfway between the last post and the next to last support post. I would put nuts behind just those bolts on the inside there.
Re: Attaching a self tacker [Re: Jake] #80148
07/14/06 09:56 AM
07/14/06 09:56 AM
Houston, Texas
Houston, Texas
Thanks will drill tonight and rig tomorrow, I do not have the running rigging figured yet I want to do something tricky to be able to furl the jib without detaching the jib sheet, so I will have to do it on the beach.
Re: Attaching a self tacker [Re: EasyReiter] #80149
07/14/06 10:23 AM
07/14/06 10:23 AM
You've probably seen these already but on the F18, we use a micro block with becket on the traveler. The sheet / tail that hooks from the jib to the traveler attaches to the becket with a tiny snap shackle. To furl, you just unclip the snap shackle at the jib traveler and furl. You can sail it without the shackle hooked in because it will stop at the micro block on the jib - you just loose half your purchase until you clip it back in.
Re: Attaching a self tacker [Re: Jake] #80150
07/14/06 10:53 AM
07/14/06 10:53 AM
Houston, Texas
Houston, Texas
I thought of that, and will do it if I cant figure a way that the crew can furl from the tramp. without having to lean out forward of the beam to unclip it. I am thinking of the times when going down wind and dem dogs is blowing off days chains and you need the jib furled to keep the long stick thing pointed up. i will post pictures if I imagine correctly.
Re: Attaching a self tacker [Re: EasyReiter] #80151
07/14/06 11:16 AM
07/14/06 11:16 AM
Ohio
TeamTeets Offline
TeamTeets  Offline
Ohio
You shouldn't try to furl for downwind runs... The jib is not big enough to make a noticable difference anyway. You are more likely to screw up and go over trying to furl or unfurl the jib.
ex-N20 470 w/self tacker
Mike, Ohio
Re: Attaching a self tacker [Re: TeamTeets] #80152
07/14/06 11:48 AM
07/14/06 11:48 AM
Not to mention that the thing furls like crap with any wind pressure on it anyway.
Re: Attaching a self tacker [Re: TeamTeets] #80153
07/14/06 02:54 PM
07/14/06 02:54 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
quite right, best time to furl is in very light winds - to keep spinny filling
Paul[ex i20 137]
Re: Attaching a self tacker [Re: TEAMVMG] #80154
07/14/06 04:01 PM
07/14/06 04:01 PM
Houston, Texas
Houston, Texas
Have furled in light air and in over 25 ever been beat by an A cat down wind with your spin up, it is an amazing thing to behold.
PS Attached the [email]F@#&%[/email] thing and it moves with a lot of friction, I am hoping it will losen up with use, the rivits are on as straight a line as I was able and they all attach, not sure if the rail is straight however it no longer matters as it is on. And I will see how it does.
Re: Attaching a self tacker [Re: EasyReiter] #80155
07/14/06 04:06 PM
07/14/06 04:06 PM
don't worry about the friction - it's actually a good thing. If the jib flogs, your self tacker won't beat your beam to death (this also applies to trailering)! It will, however, align itself when the jib is sheeted in tight. I've seen them that are floppy loose and felt gyped...then I had one that was floppy loose and I felt lucky.
However, if the tacker is hitting the rivet heads, you probably need to do something about that because it will grind away at the aluminum. I had this problem with the I20 - the t-shaped stainless tabs aren't very precise.
Re: Attaching a self tacker [Re: Jake] #80156
07/14/06 05:12 PM
07/14/06 05:12 PM
Houston, Texas
Houston, Texas
Besides pre grinding the aluminum what else would you suggest? It seems this is a done deal and it is time to see if it works, of course I still have to rig sheet lines so more fun tomorrow.
Re: Attaching a self tacker [Re: EasyReiter] #80157
07/14/06 05:25 PM
07/14/06 05:25 PM
theres not much you can do about getting beat by a Acat in light air.
After all, they probably weight close to 1/3 of what you do.
Re: Attaching a self tacker [Re: EasyReiter] #80158
07/14/06 06:17 PM
07/14/06 06:17 PM
That's about it - it's a whole lot easier than attempting to extend the stainless tabs. You'll really like the system - although some of the construction details aren't excecuted flawlessly, the system works very very well.
Re: Attaching a self tacker [Re: MauganN20] #80159
07/14/06 06:26 PM
07/14/06 06:26 PM
Houston, Texas
Houston, Texas
I get beat by almost everyone, was considering naming the boat DFL. but I race against some very talented sailors so when if ever I do move up in the standings I will have accomplished something.
Re: Attaching a self tacker [Re: EasyReiter] #80160
07/14/06 07:09 PM
07/14/06 07:09 PM
Marc,
Rumour has it that the DLW moved to Texas a while back - have you seen her?
Re: Attaching a self tacker [Re: MauganN20] #80161
07/14/06 08:36 PM
07/14/06 08:36 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Aww...that's a bit harsh isn't it. I know Marc has put on a little over the years, but he did weigh less than 495lbs the last time I saw him <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
0 registered members (), 2,745 guests, and 482 spiders.
Yesterday at 10:10 AM
