| Re: Attaching a self tacker
[Re: EasyReiter]
#80143 07/13/06 02:41 PM 07/13/06 02:41 PM |
Posts: 371 Michigan, USA | I think Jake Kohl has done this and had something about his experiences on the Sailmax website. You could probably find something on it with a search of the Open Forum.
Les Gallagher
[Re: EasyReiter]
#80144 07/13/06 03:03 PM 07/13/06 03:03 PM |
Posts: 12,310 South Carolina | Is it the new welded aluminum one or the fiberglass one? Some of the detail during installation of the aluminum one is in this post and there is more detail if you click on the link to go to the flikr images: http://www.teamseacats.com/?p=94Note, I'm trying to get the links working properly on our blog software...this link may change - if it doesn't work, post here and I'll update with a new link (or you can just search on the team seacats site for "tacker"). there's not much to it...although I don't think the measurement is in the blog. I can measure the horizontal line the rivets are in on the one I mounted and post here tonight - it's just right.
Jake Kohl | | | Re: Attaching a self tacker
#80145 07/13/06 06:39 PM 07/13/06 06:39 PM |
Joined: Mar 2002 Posts: 281 Houston, Texas EasyReiter OP
Posts: 281 Houston, Texas | Yes it is the new aluminum one, someone said to put nuts behind the two end screws and I have done that and may just put nuts on all the screws. The link worked and I would apreciate the exact mesurment to the line I will look at the tabs and see if any are shorter than others they all looked the same when I assembled it.
[Re: EasyReiter]
#80146 07/13/06 09:38 PM 07/13/06 09:38 PM |
Posts: 12,310 South Carolina | if you take a metal tape measure, hook the end in the track in the top of the beam. Pull it forward and bend it around the front curve of the beam. The centerline of the rivets is right on 2". You might want to add slightly and go 2 1/8" to 2 3/16" because if this traveler is left up when stepping the mast, the mast base can catch on it. Other than that the trimming position is pretty good there.
I did see one F18 pull two screws out of the backing plate...they do a poor job tapping those and I kinda wonder if they don't just run the screws in a regular hole and forgoe the whole tapping process.
#80147 07/14/06 07:17 AM 07/14/06 07:17 AM |
Posts: 12,310 South Carolina | We run our traveler car halfway between the last post and the next to last support post. I would put nuts behind just those bolts on the inside there.
[Re: EasyReiter]
#80149 07/14/06 10:23 AM 07/14/06 10:23 AM |
Posts: 12,310 South Carolina | You've probably seen these already but on the F18, we use a micro block with becket on the traveler. The sheet / tail that hooks from the jib to the traveler attaches to the becket with a tiny snap shackle. To furl, you just unclip the snap shackle at the jib traveler and furl. You can sail it without the shackle hooked in because it will stop at the micro block on the jib - you just loose half your purchase until you clip it back in.
[Re: EasyReiter]
#80151 07/14/06 11:16 AM 07/14/06 11:16 AM |
Posts: 215 Ohio | You shouldn't try to furl for downwind runs... The jib is not big enough to make a noticable difference anyway. You are more likely to screw up and go over trying to furl or unfurl the jib.
ex-N20 470 w/self tacker
Mike, Ohio Former H16, H18, N20, N17, M4.3
[Re: TeamTeets]
#80152 07/14/06 11:48 AM 07/14/06 11:48 AM |
Posts: 12,310 South Carolina | You shouldn't try to furl for downwind runs... The jib is not big enough to make a noticable difference anyway. You are more likely to screw up and go over trying to furl or unfurl the jib.
ex-N20 470 w/self tacker Not to mention that the thing furls like crap with any wind pressure on it anyway.
[Re: TeamTeets]
#80153 07/14/06 02:54 PM 07/14/06 02:54 PM |
Posts: 1,203 uk | You shouldn't try to furl for downwind runs... The jib is not big enough to make a noticable difference anyway. You are more likely to screw up and go over trying to furl or unfurl the jib.
ex-N20 470 w/self tacker quite right, best time to furl is in very light winds - to keep spinny filling Paul[ex i20 137]
[Re: EasyReiter]
#80155 07/14/06 04:06 PM 07/14/06 04:06 PM |
Posts: 12,310 South Carolina | don't worry about the friction - it's actually a good thing. If the jib flogs, your self tacker won't beat your beam to death (this also applies to trailering)! It will, however, align itself when the jib is sheeted in tight. I've seen them that are floppy loose and felt gyped...then I had one that was floppy loose and I felt lucky.
However, if the tacker is hitting the rivet heads, you probably need to do something about that because it will grind away at the aluminum. I had this problem with the I20 - the t-shaped stainless tabs aren't very precise.
[Re: EasyReiter]
#80158 07/14/06 06:17 PM 07/14/06 06:17 PM |
Posts: 12,310 South Carolina | Besides pre grinding the aluminum what else would you suggest? It seems this is a done deal and it is time to see if it works, of course I still have to rig sheet lines so more fun tomorrow. That's about it - it's a whole lot easier than attempting to extend the stainless tabs. You'll really like the system - although some of the construction details aren't excecuted flawlessly, the system works very very well.
[Re: EasyReiter]
#80160 07/14/06 07:09 PM 07/14/06 07:09 PM |
Posts: 12,310 South Carolina | Marc,
Rumour has it that the DLW moved to Texas a while back - have you seen her?
[Re: MauganN20]
#80161 07/14/06 08:36 PM 07/14/06 08:36 PM |
Posts: 606 League City, TX | theres not much you can do about getting beat by a Acat in light air.
After all, they probably weight close to 1/3 of what you do. Aww...that's a bit harsh isn't it. I know Marc has put on a little over the years, but he did weigh less than 495lbs the last time I saw him <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> | | |
2,715
guests, and 503
