| Some advice regarding doing races on F16 #80369 07/17/06 05:01 AM 07/17/06 05:01 AM |
Joined: Jun 2001 Posts: 9,582 North-West Europe Wouter OP
Posts: 9,582 North-West Europe | Some advice regarding doing races on F16 when 1-up in shifty and light winds Put telltales on the LEECH of your sail. Mid upper panel, just below mid leech overall and one halveway between those two. When sailing uni-rigged you have to sail by these. The telltales in the sail are not much help in really getting going because the stream to easily. I found that I'm inclined to oversheet my mainsail often. second tip. Go to www.tacticat.com register (for free) login and do alot of races practising your tactics regarding shifts, wind strength, racing rules and general covering of the your opponents. You'll learn heaps and because after a while you know them by heart when on the water you'll make alot better use of these on the water in an actual race. I really advice this online training. Apparent quite a few of us F16 sailors are doing it as I've encountered a fair share of those in the game already. (you often race against real people and can communicate with them) Wouter
| | | Re: Some advice regarding doing races on F16
[Re: bobcat]
#80373 08/02/06 11:27 AM 08/02/06 11:27 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Okay, so when you say a leech telltale "breaks," what do you mean? Do you mean it is starting to flow forward? And, if so, is it going forward on the back side of the sail or on the side toward you? | | | Re: Some advice regarding doing races on F16
[Re: bobcat]
#80381 08/04/06 09:01 AM 08/04/06 09:01 AM |
Posts: 9,582 North-West Europe | I'm much helped by these leech tell tales. On my boat and sail I now almost exlcusively sail to these WHEN I'M SINGLEHANDING UNIRIGGED. I think this is the result of using a sloop mainsail for unirig use. The lower part of the sail often tends to be to tight for unirig sailing. The top halve is more or less okay as it is cut to twist off more as their is no jib at that height skewing the flow.
We (Blade with Ashby and my own Taipan with redhead sails) are finding that alot of downhaul is fast in very light conditions. We are running the least downhaul in medium conditions then some more in light stuff and even more in really heavy stuff. It seems to help pointing and the sail tends to breath more freely making the boat go faster.
Solo, unirigged in light winds I first trim my downhaul to number 7 (which I can't translate to your settings) then I trim my traveller to have the lowest leech tell tale stream about 50 % of the time; then I add mainsheet till the upper two leech tell tales stream AT LEAST 50 % of time preferable a little more if the winds are unstable. The last seems to allow good breathing of the top. Then a I steer and steer and adjust these settings in the exact same sequence when the wind changes.
I'm finding that like this I do rather well against the two Blades at my club and other boats like F18's and Inter-20's.
I'm finding that oversheeting (top too tight) is really killing boat speed when uni-rigged. It is surprising how much twist you are sometimes using in light airs. The tell tales in my mainsail (not the leech ones) are too insensitive to signal when I'm oversheeting on either the traveller or mainsheet in these conditions.
When doublehanding or singlehanding in more winds then I start using the jib and ordinary mainsail tell tales more but not in light winds. This is for the same reason of insufficient sensitivity.
I have a 4th leech tell tale right on the corner of my squaretop but this one is pretty useless for fine trim. So don't put a leech tell tale all the way on the top of the leach, Have it at least 500 mm down.
Tuning of prebend is an art form in itself. However I do believe your current problems are trim related (sheets, downhaul) and not tuning related (prebend etc)
I hope this helps
[Re: Rolf_Nilsen]
#80384 08/04/06 12:33 PM 08/04/06 12:33 PM |
Posts: 3,528 Looking for a Job, I got credi... | The optimum (in my opinion) is that leech telltales stream aft, but break forward now and again. That way your sail is generating maximum power and minimum drag.
If the leech telltales stream aft all the time, you are probably not taking max power out of your sail but still have the same amount of drag.
If the leech telltales break forward all the time, airflow separates from the leeward side too early and you are loosing power and pointing ability at the same time as you are generating lots of drag. 100% agree, and as Wouter says, trim on the mainsail is VERY critical sailing single handed. You must have enough tension in the leach to allow you to point (and be powered up) but not too much to stall. Leach telltails are critical in telling you when this is happening.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Some advice regarding doing races on F16
[Re: KMarshack]
#80386 08/04/06 01:47 PM 08/04/06 01:47 PM |
Posts: 6,049 Sebring, Florida. | Has anyone tried putting a row of tell tales all the way from luff to leach, say every foot or so, and then one on the leach too, both sides of the main, just to see where the flow does separate? They do this with airplane wings in the wind tunnels and in flight too, to see at what angle of attack the wing will stall and how much of the wing is stalling at any given angle of attack. Some slight separation will happen at the takeoff and landing phase of flight, where you want the maximum lift from the wing. You will also be at maximum drag but the engines are at takeoff power and they can overcome the drag.
But at cruise, you want minimum drag and the engines are only at cruise power, which is much less than takeoff power, even though you are flying 300% faster. You could equate that to sailing in very light wind vs. very high wind speeds and trying to shape your main sail for maximum lift vs. minimum drag. In the maximum lift phase you will have separation. In the minimum drag profile, you should have very little separation, so you must vary it according to the conditions, which is what makes sailing (or sail shape) so much harder than flying! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Blade F16 #777
3,175
guests, and 228
