| Re: Went sailing this weekend
[Re: bobcat]
#81426 10/25/06 06:14 PM 10/25/06 06:14 PM |
Dyneema is just fine. Just set up your pole with some noticeable prebend and the creep will only relax it a little bit. Dyneema has about 2 % creep I think but after that has settled it won't stretch any further at all. So compensate for this by making your lines a little too short initially. Only a little !
Besides I've been hanging (trapezing) of 3 mm dyneema (hard outer mantle) for many seasons now. Using a fishermans hitch and bowlines. Also my spi luff is handing off a 2.5 low grade dyneema line. The lines haven't given way yet. Mind you I hate spectra with a passion. It is nowhere like true dyneema in my opinion and it will snap.
D12 versions of dyneema (the new rage) are very slippery on the outside and these line have inferiour knot holding characteristics. So just go for the plain dyneema with hard outer mantle (also cheaper) and you are set.
[Re: WillLints]
#81428 10/26/06 02:49 AM 10/26/06 02:49 AM |
Posts: 1,382 Essex, UK | Hi Will,
I have worked out how I'm going to do it, I just haven't done it yet!
What I intend to do this winter is fit a pair of Harken through deck micro sheaves to the pole tip, set horizontally, one on either side of the pole. I'll then fit an internal system with a single line exiting under the pole near the mainbeam with a clamcleat to lock it. The two tails from this line will exit the sheaves on either side of the pole tip and I'll splice hardeyes onto them. Then the dyneema pole guys will have spring clips (or maybe I'll use Inglefield or 'sister' clips) to attach them to the adjustable tails. This way I should be able to pretension the pole even on the water......
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Went sailing this weekend
[Re: Rolf_Nilsen]
#81430 10/26/06 03:55 AM 10/26/06 03:55 AM |
The dyneema I'm talking about is the older kind, not the hollow D12 line.
I've yet to see a good use for the D12 line. It is simply to slippery for most uses.
I'm told often that dyneema and spectra are the same but for some reason I've always suspected a quality difference between them.
[Re: Wouter]
#81431 10/26/06 07:03 AM 10/26/06 07:03 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | I've done some research into this many years ago and from what I recall, they were virtually identical in chemistry and manufacture, except that dyneema had one more process that made it less brittle. I've heard many people claim that spectra has snapped on them when the load "bounces". Wikipedia Marlow Ropes Honeywell - SpectraDSM - Dyneema I'd almost consider using Vectran for all fixed rope systems; no creep, good toughness, abrasion resistance and UV resistance plus I think it actually gets stronger when knotted!...Will have to look for a price next time I head to the chandlery. Vectran | | | Re: Went sailing this weekend
[Re: pdwarren]
#81442 10/26/06 05:06 PM 10/26/06 05:06 PM |
Joined: Jul 2004 Posts: 2,718 St Petersburg FL Robi OP
Posts: 2,718 St Petersburg FL | OK, so that sounds like one knot where I currently tie two - an improvement. But what stops the pole moving sideways along the line under force?
Paul Wrapping the line around the spinnaker pole atleast two rounds. This will prevent it from moving left to right. I will take photos and post em in the next few days. | | |
3,226
guests, and 278
