| Re: spin question
[Re: WindyHillF20]
#81922 08/07/06 09:33 AM 08/07/06 09:33 AM |
Posts: 12,310 South Carolina | You shouldn't be broad reaching into C - C is usually downwind so bearing away actually moves you closer to C. You can only carry a kite so high. To try and go higher, ease the tack line on the kite up to 10", downhaul HARD on the main, and let the traveler way out - to the end stop if required (temporarily - this is not fast...it's usually faster to drop the kite at this point).
Jake Kohl | | | Re: spin question
[Re: WindyHillF20]
#81927 08/07/06 03:40 PM 08/07/06 03:40 PM |
Posts: 6,049 Sebring, Florida. | Were your boards up or down when you were having the problems with the gusts? In those conditions you should pull them up about half way, to keep the hull from popping up on you, also you were trapped out, right? If you can fly the hull you should be out on the wire downwind. That will help keep you from zig zagging around the course.
Blade F16 #777
| | | Re: spin question
[Re: Timbo]
#81928 08/07/06 04:07 PM 08/07/06 04:07 PM |
Posts: 1,246 Orlando, FL | Were your boards up or down when you were having the problems with the gusts? In those conditions you should pull them up about half way, to keep the hull from popping up on you, Can you provide add'l clarification on why you recommend this?
USA 777
| | | Re: spin question
[Re: tback]
#81929 08/07/06 06:12 PM 08/07/06 06:12 PM |
Posts: 12,310 South Carolina | Your boards, as they flow through the water, provide lift in the opposite direction of the sail pressure to give resistance to the boat moving sideways. The center of the lift provided by the boards will be located roughly in the middle of the exposed board below the hull. If 4' of your board is extended below the water, the center of force is about 2' below the bottom of the boat. This gives it more leverage and means the boat is tipping over a lower center of force. If you extend your boards only 2' below the boat, the force is only 1' below the bottom and providing less tripping leverage.
The tradeoff is that you get less lift with less board in the water - however, there may be times when you don't care so much about lift from board...especially when sailing downwind. Downwind, you want just enough board in the water to keep the boat tracking in a straight line - sideways isn't fast.
Also keep in mind that this is a pretty oversimplified explanation - but is generally accurate.
[Re: tback]
#81930 08/07/06 06:22 PM 08/07/06 06:22 PM |
Posts: 6,049 Sebring, Florida. | With the boards all the way down, the low hull has a deeper center of resistance and it will lift the windward hull much sooner than if you pull the boards up a bit. You can experiment and see for yourself, it works both upwind and down. If you are overpowered and constantly fighting to keep the windward hull at the right height, pull the leeward board up a little until you can control it. It depends on how long your boat's boards are, as to how much you pull them up, so you have to keep pulling until it's under control. When it gets really wild downwind, I pull them way up, that really calms the boat down and let's you gain control in a gusty situation.
If you look closely at pictures of Inter 20's going upwind in strong winds, you will usually see they have pulled their boards up about 6" as they have very deep boards and don't need that much in high wind.
The reverse works downwind in light air, that is, if you want to go downwind on one hull (and who doesn't?) but it's really light air, be sure your leeward board is all the way down and sit well inboard, (like those A Cat sailors) send your crew "down below" to the front of the low hull to trim the kite from there, and you can usually fly a hull with the help of the spinnaker, downwind in light air. The fun part is trying to keep it ballanced just right!
In heavy wind you will probably want two on the wire, boards half way up and be ready to bear off in the gusts, a footstrap at the back will keep you from getting slingshot around the bow when you stuff the low bow on the bear away. Oh, and hold on to your crew...
Remember, at first you want to go deep from A directly to C mark, but if you got too deep and need to get up, two on the wire with boards up a bit will allow you to reach up a little higher. Or, go deep and fast, dump the chute, reach in to the mark at high speed, T bone the guys coming down on you, all the while yelling "Leward Boat, Get up!"
Blade F16 #777
| | | Re: spin question
[Re: WindyHillF20]
#81932 08/07/06 06:37 PM 08/07/06 06:37 PM |
Posts: 6,049 Sebring, Florida. | What type of boat is this? I only ask to know what type of boards and spinnaker you have.
Blade F16 #777
| | | Re: spin question
[Re: Timbo]
#81933 08/07/06 06:58 PM 08/07/06 06:58 PM | Anonymous
| Anonymous
Unregistered | Simplyfied kite instructions.
1. Keep main sheeted "firmly" at all times or you'll break your mast.
2. Generally speaking keep the traveller central and play the tiller (pull away to de-power)
3. If trying to maintain height, play traveller.
4. In shifty conditions do a bit of both. steering all over the place is very inefficient.
5. Have just enough board down to stop you going sideways. A cat hull going fwds through the water has a lot less drag than one going sideways. | | | Re: spin question
[Re: Timbo]
#81934 08/07/06 07:11 PM 08/07/06 07:11 PM |
Posts: 1,246 Orlando, FL | Remember, at first you want to go deep from A directly to C mark, but if you got too deep and need to get up, two on the wire with boards up a bit will allow you to reach up a little higher. Or, go deep and fast, dump the chute, reach in to the mark at high speed, T bone the guys coming down on you, all the while yelling "Leward Boat, Get up!" I'm actually getting better at this due to massive hours on Tacticat. I am a bit concerned that Tacticat is developing an overly aggressive skipper that will translate these virtual skills to those in a real regatta with real boats that cost real money to repair! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
USA 777
| | | Re: spin question
#81936 08/07/06 07:58 PM 08/07/06 07:58 PM |
Posts: 6,049 Sebring, Florida. | Thanks Jake. The old Hobie 18 (as opposed to the Tiger) had fairly short, wide boards to begin with and were pretty good heavy wind boats. Did you ever see the video they did of the three guys sailing it in Hawaii? That was wild!
Anyway, with racks and double traps, you should be able to sail that in pretty big wind, downwind, and it should be pretty stable too, especially when you pull the boards half way up. Not much chance of recovery once you put the bows under though, so try to avoid that! Keep your weight to the back if you are going to go deep downwind. But it is hard to learn spinnaker trim in shifty, gusty lake type wind. Try it on a day when the wind is more stable and the apparant wind won't move around on you so much.
Also, be sure to put some 12" casette tape streamers on your pole bridal wires and up on the shrouds so you can see what is going on with the aparant wind. I have found Brittany Spears or Clay Aiken tapes sound best when used for this purpose. If you were going 15-20 downwind, the apparant wind should have been ahead of beam reaching.
Blade F16 #777
547
guests, and 112
