Where to get a tiller exension #82343
08/11/06 05:38 AM
08/11/06 05:38 AM
soggy Offline OP
soggy  Offline OP
Hi,
my current tiller extension is just a piece of PVC pipe, its heavy and flexes when steering making it rather insensitive.
Has anyone got any recommendations?
Paul Wiggins
Canberra
Re: Where to get a tiller exension [Re: soggy] #82344
08/11/06 07:25 AM
08/11/06 07:25 AM
Tornado_ALIVE Offline
Ronstan Battle
stick - http://www.ronstan.com.au/marine/product.asp?ProdNo=RF3137
Or for a few more $$$$ Carbon Kevlar from Composite Spars and Tubes.
http://www.compositespars.com/tiller_extensions.htm
Re: Where to get a tiller exension [Re: Tornado_ALIVE] #82345
08/12/06 12:30 AM
08/12/06 12:30 AM
ncik Offline
ncik  Offline
Agreed, ronstan or CST would be top two preferences.
Re: Where to get a tiller exension [Re: ncik] #82346
08/12/06 09:33 PM
08/12/06 09:33 PM
soggy Offline OP
soggy  Offline OP
What's the length that most Mosi's are using ?
Re: Where to get a tiller exension [Re: soggy] #82347
08/13/06 07:06 AM
08/13/06 07:06 AM
Peter_Foulsum Offline
Paul,
The Ronstan telescopic tiller extension is great until you bend it a few times or once badly. I have given up on the expense and gone to an aircraft grade aluminium alloy which is both light weight and very strong. It's a whole lot better than the spagetti from Bunnings and comes in 5m lengths so you can pretty much cut it in half and have a spare as backup. I'll try to get more detail on the supplier.
Peter
Mosquito 1814
Macka Mozzie
Re: Where to get a tiller exension [Re: Peter_Foulsum] #82348
08/14/06 02:34 AM
08/14/06 02:34 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Paul,
We have been using CST (Composite Spars and Tube, Sydney)tillers now for about 4 years with only one minor lot of damaged which was "self inflicted" and not the fault of the tiller. This was repaired simply with some carbon and resin.
I have found it light, strong very stiff and most of all comfortable to use and to date have fitted one to another boat, other than our own (2 of).
Expense????...all relative I guess but they run about the $230 mark and we are using the longest one they make...actually for the A class.
There's my choice for what it is worth.
Re: Where to get a tiller exension [Re: dkd] #82349
08/15/06 05:42 AM
08/15/06 05:42 AM
soggy Offline OP
soggy  Offline OP
Peter,
if you could dig up the information on the aircraft aluminium tube that would be great...
Re: Where to get a tiller exension [Re: soggy] #82350
08/15/06 11:28 PM
08/15/06 11:28 PM
ncik Offline
ncik  Offline
I found a really good section of light walled, larger diameter aluminium at bunnings recently (I think 20-25mm OD, 1-1.5mm wall. Was surprised to see it at bunnings actually, didn't really appear sturdy enough for home handy-man style work)...it is currently working brilliantly as the tie-bar between teh tillers. It could be good for an extension...?
Re: Where to get a tiller exension [Re: ncik] #82351
08/16/06 12:09 AM
08/16/06 12:09 AM
soggy Offline OP
soggy  Offline OP
Nick, will check out Bunnings in the next few days. Thnaks for the tip...
Re: Where to get a tiller exension [Re: soggy] #82352
08/22/06 07:44 AM
08/22/06 07:44 AM
Paul,
I haven't forgotten your request. It's just taken more time than I thought to get the source details. My contact informs me that it is 25 mm dia. high tensile drawn alloy mill finish. It's something you don't usually find at Bunnings but hey, they could have got a special order from somewhere and had surplus they wanted to unload.
I'll keep perservering.
Peter
Mosquito 1814
Macka Mozzie
Re: Where to get a tiller exension [Re: Peter_Foulsum] #82353
08/22/06 06:53 PM
08/22/06 06:53 PM
ncik Offline
ncik  Offline
Yeah, it was a very unusual section to find at bunnings. Don't hold high hopes for finding it again.
Re: Where to get a tiller exension [Re: Peter_Foulsum] #82354
08/22/06 10:50 PM
08/22/06 10:50 PM
Sugarloaf sailing club, Melbou...
Fat Bomber Offline
Fat Bomber  Offline
I've been using the Bunnings aluminium tube for a while as I have a habit of falling on top of the tiller extensions. I also wrap plaster jointing tape near the end and then the wide PVC tape over that for better grip. I seal the ends with some epoxy filler so it floats.
0 registered members (), 672 guests, and 252 spiders.
