| Re: repairing a delaminated Fiberfoam batten tip
[Re: GeoffS]
#82403 08/13/06 05:28 AM 08/13/06 05:28 AM |
Posts: 1,382 Essex, UK | The same thing happened to one of my battens when it got accidentally shut in the trailer lid. Fortunately the damage was only a couple of inches.
I decided that as the batten foam was so thin at this point, I could dispense with it altogether: filed out the damaged foam, packed the gap with chopped strand mat and epoxy. Clamped the tip between some polished plastic offcuts (make sure to retain the taper shape) and left overnight. Next morning I simply finished the tip off on my bench grinder. Fixed!
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: repairing a delaminated Fiberfoam batten tip
[Re: GeoffS]
#82404 08/13/06 10:34 AM 08/13/06 10:34 AM |
Posts: 12,310 South Carolina | The old tapered Performance Catamaran battens (from the 80's) would do this. I repaired a bunch of them by lightly wedging open the delaminated tip, spooning in epoxy to the foam and the fiberglass skin, then with some strips of wood on each side, clamped firmly together. They held up just fine.
Jake Kohl | | |
359
guests, and 57
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
