| Re: Hull flying question
[Re: breiner]
#83426 08/24/06 10:01 AM 08/24/06 10:01 AM |
Posts: 182 Coopersburg, PA | I have found that when I sail with my father with a total of about 360 lbs, we need about 20mph winds or a little less to be able to fly a hull. Also, since your are still getting used to the boat, some advice I could give would be not to be scared off by the strong puffs. When I let my crew skipper on 15+ days, he always has the tendency to immediately spill the main while in a puff and that is another reason why you might not be able to get a hull up. When the wind picks up, dont be afraid to just keep the main cleated off and let the boat take off. It took me a while to get used to leaving the main cleated and just letting the hull rise in the puff then come back down at the end of it, but once you get used to it, your sailing trips will be so much more fun.
My $0.02
~vinny~
[Re: Vinny_M]
#83427 08/24/06 03:50 PM 08/24/06 03:50 PM |
Posts: 306 St. Louis, MO | You can fly the hull in 15-20 kts steady with moderatly rough seas. Just don't be afraid to take advantage of the power the boat has. If you want more power, let off on the downhaul some. This will give you a deeper sail shape. Fall off from the wind as far as you can while keeping your telltales flying when the main is sheeted in. Keep an eye on the jib and trim it correctly to keep the slot optimal.
When I first started hull flying I used the main sheet to control the angle of heel. I would let off the main when I started to go too high. I would react to the wind instead of staying ahead of the boat. You can see puffs coming and should steer the boat to adjust for them. Fall off when the gust is gone and head up when the gust hits. This keeps the sails "powered up" and doesn't have as drastic an effect on the heeling angle. The boat doesn't react as fast when steering to control the angle of heel, and it will take some practice to get used to it, but you will find you can keep your hull up longer when you get good at it.
I hope this made sense. If not someone will chime in a clear it up, I'm sure.
Nick
Current Boat Looking for one
[Re: breiner]
#83432 08/25/06 06:06 PM 08/25/06 06:06 PM |
Posts: 4,119 Northfield Mn | A friend and I were out with about 3mph of wind the other day. We managed to fly a hull. Granted it was the leward when we were trapping just to see if it would happen. Kind of a reverse wild thing.
[Re: alan_ellis]
#83433 09/08/06 03:16 PM 09/08/06 03:16 PM |
Posts: 321 Albuquerque NM | This last weekend, I was trapped out on an TheMightyHobie18 w/about 8" -10" of air between the water and the dagger. The skipper un-cleated the main while not holding on very tight at all.
Instant tea-bag from over 10' up what a rush.
Sam
[b] Sail Like you have a Pair
[Re: Banzilla]
#83434 09/08/06 03:43 PM 09/08/06 03:43 PM |
Posts: 306 St. Louis, MO | I do that to my crew when they stop paying attention and don't call out traffic.
Nick
[Re: hobienick]
#83435 09/08/06 04:02 PM 09/08/06 04:02 PM |
Posts: 321 Albuquerque NM | This was just a streight up slip. He got just as wet as I did.
[Re: JaimeZX]
#83437 09/10/06 02:33 AM 09/10/06 02:33 AM |
Posts: 110 | hey i did one of them this summer too, i was flyin a hull, solo, and it was quite rough, when all of the sudden my leeward hull dives. when this happened, i went flying from one end of the boat to the other, due to the extreme change in speed and the fact that my windward hull spins around and then dives as well. i tried to correct myself using the rudders and dumping the mainsheet, but i was flyin through the air my rudders were out of the water. when i landed back on the railing, i have just enough time to see my boat has come about, all the battens pop over, and the boat dumps on top of me... oh and also i was too light and the wind was too strong to keep it from turtling... ahhh... good times... | | | Re: Hull flying question
[Re: newbiesailor]
#83438 09/11/06 11:32 AM 09/11/06 11:32 AM |
Posts: 5 | i did something similar yeserday, iwas flying a hull and all of a sudden a big gust hit and i was on nearly in the water but i could'nt get the trap hook off, so i just lent back on it a bit and it came back!
Andy
2,689
guests, and 599
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 10 hours ago | | |
