| Re: Re-attaching the tramp track
[Re: charlesa]
#8353 06/30/02 11:02 PM 06/30/02 11:02 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Generally use stainless steel or aluminum. Hobie may be able to give you the original part specs.
[Re: charlesa]
#8356 07/01/02 01:59 PM 07/01/02 01:59 PM |
Posts: 917 Issaquah, WA, USA | See Hobie Cat Catalog 2002 online http://www.hobiecat.com/cats/partset.htmlFrom the price list, the rivet is 6-10 PN HD Monel. The backup washer is curved to fit the lip on the hull. As an alternative to Monel, use stainless steel. Make sure you have a heavy duty rivet gun, the large type with long handles. The rivets must be set correctly with a tight fit, so there is no slop between the track and the hull. Good luck. Caleb | | |
1 registered members (vasil),
849
guests, and 56
