| Best course #84104 09/06/06 11:30 AM 09/06/06 11:30 AM |
Posts: 3,348 | I was under the impression that there are an infinite number of "best" courses to the weather mark. The higher you sail the slower the boat goes, but it travels less distance and, if done equally well, all would get you to the top of the course in the same amount of time.
Also, I had heard or read, somewhere, that it is better to take the headed tack first, when going to weather. The belief being that less distance is traveled. Further, that belief could be demonstrated trigonometrically.
True or false? | | | Re: Best course
[Re: fin.]
#84107 09/06/06 12:08 PM 09/06/06 12:08 PM |
Posts: 146 Crofton, MD | Tiki,
Upwind, indeed there are infinite courses, however typically there is only one optimum course (in some cases there are more but they are usually very similar). Upwind, you can sail at different courses (angles) to the true wind (ig. 30 deg. true, 35 deg. true, 40 deg. true). For each of these you will have a certain velocity. Now you do the trig. for each course and velocity and get the component vector towards the windward mark (0 deg. true). Now, based on the speed you can achieve for each course, there will be one optimum component velocity (Velocity made good). The course off of true wind with the highest velocity made good is your optimum course. These all may differ for different windspeeds. This is typically how Target boat speeds and courses are derived on big boats. They also have the advantage of a polar diagram usually created from a velocity prediction program which essentially does all of the math for them. Conversely, you can figure the same downwind.
Now, the second question - Upwind you want to sail towards the shift. I think i've typed too much on this response already so you could read Rick's book for a more thorough explanation... | | | Re: Best course
[Re: fin.]
#84108 09/06/06 12:20 PM 09/06/06 12:20 PM |
Joined: Sep 2001 Posts: 254 Gower, Wales, UK sailwave
Posts: 254 Gower, Wales, UK | Also, I had heard or read, somewhere, that it is better to take the headed tack first, when going to weather. The belief being that less distance is traveled. Further, that belief could be demonstrated trigonometrically.
True or false? True if the wind is steadily tracking one way; if it's going right, go right first, and visa versa. | | | Re: Best course
[Re: Todd Berget]
#84110 09/06/06 12:33 PM 09/06/06 12:33 PM |
Posts: 1,187 38.912, -95.37 | So who gets out the GPS (with the VMG function) and actually plots the chart for their catamaran? Anyone? Of course you'd need to mount a compass to utilize the findings. Is a compass class legal in most catamaran classes for buoy racing?
We raced a PHRF mixed fleet event last weekend and noticed the wind heading posted at every start.
From Hobie rules; "The use of navigation and speed metering equipment is illegal unless specifically allowed in the individual boat rules or by the Notice of Race for the particular event or regatta." I've heard the wind heading will be posted at the 18/20 Nationals but nothing in the NOR allowing compasses. Why then display wind direction?
Is the catamaran that much faster that you can "feel" VMG and it's not worth plotting, whereas changes in a larger/slower boat are more subtle and therefore less apparent?
| | | Re: Best course
[Re: fin.]
#84111 09/06/06 12:37 PM 09/06/06 12:37 PM | Anonymous
| Anonymous
Unregistered | Pete:
This old 27 year cat sailor learned a lot from "Catamaran Racing for the 90's". <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> I got the seminar tapes too. Roll Tacking tape is a must. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Doug | | | Re: Best course
[Re: ]
#84112 09/06/06 02:05 PM 09/06/06 02:05 PM |
Posts: 12,310 South Carolina | Doug, just using the word "tapes" really dates you. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I've never understood the reason behind that exclusion in the Hobie rules. I'm just beginning to learn how vital a compass is for competitive sailing around the bouys. It's less about understanding what you're best angle of sail is (you really need to learn to feel that through competitive experience) than it is to give you concrete information about what pattern the wind is following on and around the course.
Jake Kohl | | | Re: Best course
#84113 09/06/06 02:20 PM 09/06/06 02:20 PM |
Posts: 393 Syracuse,N.Y | Compasses are allowed per IHCA rule 16.3 and have been for a while. They can only give a heading. John: When they post a compass heading and then do a change mark with the new heading you then know which way the wind is going. That can be handy.
Pat Bisesi
Fleet 204
| | | Re: Compasses
[Re: Tom Korz]
#84117 09/06/06 10:37 PM 09/06/06 10:37 PM | Anonymous
| Anonymous
Unregistered | Jake:
Unfortunitly Rick didn't have them on DVD then. I still don't think he does. If anyone want a Tacktick Mirco I will make to a good deal.
[Re: pbisesi]
#84118 09/07/06 08:29 AM 09/07/06 08:29 AM |
Posts: 1,187 38.912, -95.37 | Compasses are allowed per IHCA rule 16.3 and have been for a while. They can only give a heading. John: When they post a compass heading and then do a change mark with the new heading you then know which way the wind is going. That can be handy. Umm, good point, verifies the shift direction, thanks Pat. Who's buoy racing a cat with a compass and why? Dan?...you have one on that jack-rabbit?
| | | Re: Best course
[Re: _flatlander_]
#84119 09/07/06 10:55 AM 09/07/06 10:55 AM |
Posts: 130 CA | So who gets out the GPS (with the VMG function) and actually plots the chart for their catamaran? Anyone? Of course you'd need to mount a compass to utilize the findings. You don't need a polar plot for a GPS to be useful for upwind/downwind training. Velocitek packages the concept nicely, but many existing GPS's can do the same thing (but on a smaller display), when used correctly. Here's how I make my GPS + compass do the Velocitek thing in a matter of seconds: Head into the wind or sail dead downwind to get the wind heading. Scroll the GPS map cursor 1000 miles away on this bearing. (My Magellan-based GPSs show the distance and heading on screen as I move the cursor.) Hold down GOTO(MARK) to create a waypoint there and GOTO the new waypoint. Display VMG, and this will give your true VMG to windward/leeward. The only caveats are that the wind may shift, and that the VMG is updated every second or two, which is really too frequent, especially downwind, where you would prefer averages over 15 to 30 seconds, IMHO, since good performance is much more dynamic than just selecting a heading, especially downwind. Your GPS will now give you objective upwind/downwind feedback for training, and you will quickly learn what the boat feels like when you are sailing your best, so you won't need the GPS or compass to reproduce the performance when racing. And when you're in the fleet, nearby boats serve as excellent performance references. | | | Re: Best course
[Re: Glenn_Brown]
#84120 09/07/06 12:02 PM 09/07/06 12:02 PM |
Posts: 3,348 | Since I started this mess, I will take the liberty to get back on course and start a little [censored] at the same time! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
If you are not an evil techno-demon, bent on destroying the purity of our sacred avocation, with obscene microchips, batteries and wires. How do you choose the best course up wind.
I'd be interested in hearing from the sailors out there, if there are any! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
btw- Egyptian cotton is the only "true" sail cloth!
btwbtw- Mary you should do away with that [censored] thing. It is much too scary and serious sounding. How 'bout [OMG! You won't believe what he said! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />]
| | | Re: Best course
[Re: fin.]
#84123 09/07/06 12:42 PM 09/07/06 12:42 PM |
btwbtw- Mary you should do away with that [censored] thing. It is much too scary and serious sounding. How 'bout [OMG! You won't believe what he said! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />] You guys are no fun at all! <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> Where's Wouter? I'll bet I could start some [OMG! You won't believe what he said! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />] with him! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
2,490
guests, and 352
