| Re: "T" foils on F14
[Re: Tornado_ALIVE]
#84408 09/13/06 12:12 PM 09/13/06 12:12 PM |
Posts: 9,582 North-West Europe | All in good fun, boys. We currently see the F16 and now F14 class using foil rudders. No offense but these 2 classes are far from professional classes. Why have we not seen other more professional classes trial these. May be most of these other classes have something in their class rules forbidding this ????????
The answer to that is partially yes. Alot of classes do have rules like the overall width rule that prevent T-foils from being used. Other reasons are that builders don't want the additional hassle, so don't expect Hobie or Nacra to develop and introduce stuff like this into the cat scene. Other reasons may well be pure scientific in nature. As I wrote in an earlier post; it can be quite possible that longer boats do not get the same boost from fitting T-foils then the shorter boats like the 16's and 14's. It was tried in the A-cat class and discarted. However the length to width ratio of the A's is far higher then the other classes. The A's are just alot longer and also alot smaller then the other boats. And of course they have less weight in that carbon mast. All factors that limit the possitive effect that T-foils can have. I have personally sailed with T-foils a couple of times and I must say they truly make the platform very stable. I own a boat without T-foils and I do feel a significant difference despite both being F16's. I dare not quote an performance increase % but I'm convinced that the T-foils can't be just waved away. I wouldn't be surprised if well designed T-foils turned out to be an advantage that just a score of sailors overlooked for such a long time. Afterall how long did it take before the bulk of (professional) sailors and classes started using wingmasts ? In this line of thinking I have no special regard for professional classes. More often then not they are more conservative then non-professional classes. Most development is done in small and tinker oriented environments. Wouter
[Re: Seeker]
#84410 09/13/06 02:07 PM 09/13/06 02:07 PM |
Posts: 3,528 Looking for a Job, I got credi... | I have only one sail to support this in a Stealth F16.
All IMO of course.....
The T foils make the ride down wind very much smoother and you can drive the boat much harder. There were times while I was getting used to it that I was thinking that "I'll need to bear off in this gust to stop the bows going too deep, when in fact I did not; the foils gripped and the boat just went faster.
I agree 100% with T_A that they are adding drag as they are holding the back of the boat down and you could go faster with crew weight further back.
but you run out of crew weight ! At some point you have to shed power to keep the bows out (and so not going at full speed). Yes, by adding weight to the back of the boat by moving back you fix this, but you can only get so far back.
From sailing the boat only once, I can see that it will by critical to sail the boat all the time with the foils not dragging until you need them. The foils could make people lazy as the bows just don't dip anywhere near as much.
Consider this
2 boats are exactly the same except one boat has T foils on the bottom of the hulls.
Boat A and boat T (has the foils)
In light wind with NO waves
Boat A should be slightly faster than boat T as the T foils have more drag.
In light wind with waves
Boat A might be faster as it has less drag, but, boat T will slop around less on the waves as the T's prevent some of the wave action moving the boat around (so the rig shakes around less), but boat T has more drag and this will be compounded by the wave action.
In moderate wind and small waves
Boat A should be slightly faster as it has less drag, but boat T may have some small benefit from the more stable platform
In moderate wind and waves
Boat a might be faster as it has less drag, but, boat T will slop around less on the waves as the T's prevent some of the wave action moving the boat around (so the rig shakes around less), but boat T has more drag
In strong wind with smallish waves
Boat A might be slightly faster as it has less drag, but boat T will have benefit from the more stable platform and will also be able to drive the boat much harder downwind as there is less probability of pitchpole.
In strong wind with big waves
Now my views are thus :
1, T foils add a little (and it is very little) drag as you have more area in the water. 2, T foils make a massive difference sailing downwind in the windier stuff as the boat is much less tippy for/aft and so can be driven MUCH harder. Once you are standing at the back of the boat, you cannot go any further back. 3, When the wind is lighter, crew positioning is vital to ensure the foils are not dragging. 4, I've not sailed the boat in waves yet so cannot comment.
Another thing, over the last 8 years, I have gone from sailing a 20 foot boat (Hurricane 5.9) that was a dream to sail down wind in the big stuff, loads of volume up front and so we did not really factor in pictpoling into many sailing days
Then I moved onto a 17 foot 6 boat were you do have to be a little more carefull (still loads of volume up front). I've now gone to the Stealth (waiting delivery) and we'll see how that goes, but on my first sail,it was behaving more like and 18+ foot boat than the 16 foot boat that it is.
IMO T foils are the dogs danglies....
F16 - GBR 553 - SOLD I also talk sport here | | | Re: "T" foils on F14
[Re: scooby_simon]
#84411 09/13/06 03:03 PM 09/13/06 03:03 PM |
Posts: 371 Michigan, USA | Scooby,
I agree with ost of your points except that a more stable rig will have more power because the reduction in "hobby horsing" will leave the rig powered up more of the time. Add that factor to all of your wind and wave ranges and it seems that the T-foils would be a better solution around the bouys.
I don't know much about the rules in the Tornado Class, but F18 Rules don't specifically rule T-foils out, except Rule A.2 which includes "Formula 18 class rules are closed class rules, what is not expressly permitted is prohibited."
Les Gallagher
[Re: sparky]
#84415 09/13/06 05:02 PM 09/13/06 05:02 PM |
Posts: 3,528 Looking for a Job, I got credi... | Scooby,
I agree with ost of your points except that a more stable rig will have more power because the reduction in "hobby horsing" will leave the rig powered up more of the time. Add that factor to all of your wind and wave ranges and it seems that the T-foils would be a better solution around the bouys. I am (trying) to say that the rig stability helps. I currently believe T foils are the way to go !
[Re: George_Malloch]
#84416 09/13/06 06:06 PM 09/13/06 06:06 PM |
Posts: 12,310 South Carolina | The reason they won't work on "conventional" rudders is that you wouldn't be able to use the rudder in anything other than the fully down position - there would be too much drag otherwise when you have the rudders down just enough to sail out of shallow water. SPEED BRAKES! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jake Kohl | | | Re: "T" foils on F14
#84417 09/13/06 11:30 PM 09/13/06 11:30 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | The reason they won't work on "conventional" rudders is that you wouldn't be able to use the rudder in anything other than the fully down position - there would be too much drag otherwise when you have the rudders down just enough to sail out of shallow water. But why would there be water drag if they are in the fully "up" position? Maybe a little air drag. And being able to flip them up briefly would help to get grass off the rudder blades. Grass is a major problem in many areas of the United States. I thought maybe the reason for needing a casing so the rudder can go straight up and down was because the foils cause increased stresses on the transom?? Or maybe too much stress or "drag" for existing rudder systems to keep from kicking up??
[Re: Tornado_ALIVE]
#84419 09/14/06 01:27 AM 09/14/06 01:27 AM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett OP
Posts: 1,012 South Australia | I will try Steve, 1. We have sailed through weed with two identical F14’s, and both caught weed on their rudders and were forced to extract that weed. One cat had T foils the other didn’t. The T foil cat slid the rudder up in the case and extracted the weed, slid the rudder back down and continued sailing. The other one had “kick” up rudders and swung the rudder up cleared the weed and swung the rudder back down. Conclusions were that the swung rudder was quicker BUT the difference was very little. Definitely not enough to be a deciding factor in “rejecting” the T foils. 2. When you look at the so called “drag” from T foils, you have to approach the question not from a “static” two dimensional perspective as if the boat was standing still and the bows went up and the transoms went down, (or visa versa) if this was the case there would be enormous loads (not drag) transferred from the foils directly to the transoms, but instead the hulls are moving forward THROUGH the water when the bow “dips” (or rises) and therefore we have a three dimensional “global” situation. Think of the foils not so much as resisting the vertical movement of the hulls, but more so as directing the direction of the hulls through the water in the vertical plane, exactly the same as the rudders do on the horizontal plane. Because of this the change to the angle of incidence of the T foils to the actual direction of the movement of the hulls is very small (only a few degrees) and as such the resulting drag is approximately the same as that caused by the rudders when steering in a straight line (which never in actuality really happens as even in a straight line we are always steering a little up to counter leeward drift) This is why when you calculate (quite simply) the potential “load” that the area of the foils can generate (IE for the Stealth numbers have been bandied about of 100 or more kg’s) it would appear that the transoms need to be substantially reinforced to take that extra load, BUT in reality due to that “force” not being by any means a static vertical load the transoms can handle the T foils without any additional reinforcing. Our testing so far, between two identical F14’s, one with foils and one without showed that over the full range of our extensive testing the cat without foils could never match the cat with foils under any sailing condition. 3. The so-called drag does not seem to be a “variable” with the different sea states. The drag is a constant relatable to the actual speed of the foils through the water. The greater the hull speed the better they work I.E their efficiency goes up with speed greater proportionally than the increased induced drag. 4. Read my original posts you will see that we yardsticked TWO identical F14, one with and one without T foils 5. I think that my academic qualifications together with my lifetime spent designing, testing, building, and selling catamarans may just qualify me to perhaps have my “testing” practises accepted as valid. | | | Re: "T" foils on F14
[Re: Darryl_Barrett]
#84422 09/14/06 05:52 AM 09/14/06 05:52 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I sail a Stealth without 'T' Foils and would love to try the T's just too feel the difference. I only have two conerns about T's the first is the nodding dog syndrome. I cann't see how they could reduce this due to how waves are formed (sea swell not lake waves) in the first place. Infact, T's could be slower in some instances. The other concern is that I quite often find myself sailing downhill with my windward rudder tip just flicking in and out of the water. When a gust hits using T's and before I can react the windward rudder might still lift out and when I bear away would the T prevent the rudder/hull to come back down as quickly as I would like whilst trying to bear away. If so this would counteract sailing 'harder' downwind. In saying this I have spoken to John Pierce, Jalini and Wayne and I don't think they would ever go back to normal rudders so their advantages must out weigh their disadvantages. MP*MULTIHULLS | | | Re: "T" foils on F14
[Re: Mark P]
#84423 09/14/06 07:27 AM 09/14/06 07:27 AM |
Posts: 5,590 Naples, FL | Has anyone addressed how these rudders are used in water of unknown depth? I've kicked up a rudder or two in areas I thought were deep enough (the Keys mostly), and while it's a pain to run back and reset, at least it didn't break the rudder.
The same is true for hidden lobster trap lines that aren't marked or are somehow sitting below the surface. If the T-foil rudder caught one at full tilt, would it kick up (or out, or something), or just bring the boat to a screetching halt?
If there is no provision to kick up, would it be prudent of the sailor to keep the minimum daggarboard depth greater than that of the rudders?
[Re: Mary]
#84424 09/14/06 07:39 AM 09/14/06 07:39 AM |
The problem is that you have to be at a complete standstill to kick them up - or the foil will want to drive the rudder down as the boat moves forward. The solid rudder trunk does also allow very precise control over the angle of the t-foil while under way - and that's got to be really important. This kind of trunk is used on skiffs like the 49'er (throwing stones <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />). Even our I20 style kickup rudder systems will allow the rudder to angle back just from loading (especially when the springs wear a little).
Jake Kohl | | |
10,809
guests, and 377
