Re: Adjusting Trapeze harness [Re: Robi] #85355
09/28/06 09:08 PM
09/28/06 09:08 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
Robi,
I'd love to see how the spectra turned out. I'll keep an eye on this thread for when you get some posted.
-Rob V.
Rob V. Nacra 5.2 Panama City
Re: Adjusting Trapeze harness [Re: flumpmaster] #85356
09/29/06 10:04 AM
09/29/06 10:04 AM
CA
Glenn_Brown Offline
Glenn_Brown  Offline
CA
I like dogbones but have avoided putting them on my boat because of the teeth chipping factor.
I simply coated my dogbones with tool-dip from the hardware store. That's the rubber stuff used to coat plier handles. No teeth chipped yet.
I prefer this style of 'bone, as it is really easy to grip and hook into either end:
http://store.catsailor.com/tek9.asp?pg=products&specific=jmorfmnqr4
I tie to the top, but some like to tie the trap line to the middle for a smaller adjustment when they switch ends.
Re: Adjusting Trapeze harness [Re: Redtwin] #85357
10/10/06 12:21 PM
10/10/06 12:21 PM
Robi,
-Rob V.
Here are the photos
[Linked Image][Linked Image]
Re: Adjusting Trapeze harness [Re: Robi] #85358
10/10/06 03:24 PM
10/10/06 03:24 PM
How safe is it though?
There isnt much to hold onto, have you ever tried to release it under load?
Re: Adjusting Trapeze harness [Re: Tony_F18] #85359
10/10/06 04:03 PM
10/10/06 04:03 PM
As far as safety goes, I cannot speak, because I have not found myself in a position where releasing it is a huge concern. Yet again, I am extremely comfortable with the ocean and being extended periods of time under water. That said, I will not talk about safety. What I think is safe maybe is not safe for others.
As far as releasing under a load, I have released it under a load and it releases just fine. In this case you just grab onto the line, instead of a handle or the dog bone itself and release just like a regular trap system.
At first I thought the plastic tubing would have more friction on the harness hook, but so far I have not noticed an increase in friction. So releasing it from the harness is effortless and easy.
<img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Adjusting Trapeze harness [Re: Robi] #85360
10/10/06 06:44 PM
10/10/06 06:44 PM
Redtwin Offline
Redtwin  Offline
Thanks for the pics, Robi. I think I am going to try that next time I need to replace the trap lines. I just set them up with new spectra so it will probably be next summer. I may test it out on my son's trap since he always has problems with getting his height adjusted properly. It looks like it would be easier to adjust.
-Rob V.
Re: Adjusting Trapeze harness [Re: Redtwin] #85361
10/10/06 07:38 PM
10/10/06 07:38 PM
Simple stainless steel or titanium rings 2" - 3" diameter work really well on the end of the line too.
Re: Adjusting Trapeze harness [Re: Frozen] #85362
10/11/06 08:13 AM
10/11/06 08:13 AM
H
h77 Offline
h77  Offline
H
For adjustable lengths: I had gone ahead and invested in a system similar to this one:
http://store.catsailor.com/tek9.asp?pg=products&specific=jndrgpdmi0
I assume it is targeted at serious racers where any bit of extra leverage counts.
Once sailing with an inexperienced crew, the adjustable line became uncleated, and the crew went swimming. Of course there was wind and waves adding to the excitement. I now prefer the non-adjustable setup, avoiding worries about losing someone.
Bear in mind that the setup I was using only LOOKED like the one Rick sells.
H77
Re: Adjusting Trapeze harness [Re: Robi] #85363
10/11/06 05:11 PM
10/11/06 05:11 PM
Robi,
I used this system myself and I found a larger loop makes it easier and therefore quicker to hook up.
Never had any issues unhooking.
Only real issue is that is will fail eventually. I think it must be the fibres cutting one another where the hook loads up the line. Replace the line once a season and this can most likely be avoided.
Re: Adjusting Trapeze harness [Re: h77] #85364
10/11/06 06:08 PM
10/11/06 06:08 PM
Redtwin Offline
Redtwin  Offline
H77,
I have the fiddle blocks for an adjustable setup but I removed them after I almost went for a swim while singlehanding <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> (Thank God for stop knots). I also heard a story of a sailor who almost lost their thumb when it got caught in the block during an emergency maneuver. I think it was one of HobieGary's friends. I know there was a story written about it on TheBeachcats.com, but I couldn't find it.
-Rob V.
0 registered members (), 223 guests, and 46 spiders.
