| Hobie 18 hull leaking...HELP #8588 07/08/02 10:46 PM 07/08/02 10:46 PM | Anonymous OP
| Anonymous OP
Unregistered | Primarily ocean sailing boat, taking on a substantial amount of water in the port hull. I thought it was the drain housing by the plug, but I put marine silicone and believe I fixed it. It pours in from being submerged from the swells. I know there is a 'small' leak in front of the center board area, but it just barely drips. What suggestions does anyone have? I was only out for about 1 1/2 before there was about 2-4 inches in the hull, I mean the entire lenght of the hull! I'm in San Diego...like it matters, but I need some suggestions. For one, I need to be safe, and for two, I need to sail longer than a few hours! Thanks guys! | | | Re: Hobie 18 hull leaking...HELP #8590 07/09/02 10:18 AM 07/09/02 10:18 AM |
Posts: 805 Gainesville, FL 32607 USA | I have repaired at least 8 Hobie 18s and 18Ms in our fleet that had cracks under both front and rear crossbars and shroud connectors. Some cracks were a foot long and the hull had not broken off yet, amazingly. But they WILL BREAK if not repaired. Some of these had been older boats- pre'85 without the reinforcing D-plates. Magnums often split under the left front and right rear crossbar, sometimes at the inside lip but usually the outside lip. The wings add too much stress that the boat was not designed for. Turn them over and add epoxy/ fiberglass inside, even in front of the crossbar, as far as you can reach.
Signed, Catcobbler
| | | Re: Hobie 18 hull leaking...HELP #8592 07/09/02 09:13 PM 07/09/02 09:13 PM |
Posts: 1,911 South Florida & the Keys | My 18' was leaking in the seam that seperates the deck from the hull. As you know, they are seperate forms. I ended up pumping air into yhe hull and spraying the seam with dish detergent and finding the bubbles. I marked the bubble areas with a black marker then came back and opened those areas with a thin screwdriver and injected 5200.
Leaks no more.......
Eric Arbogast ARC 2101 Miami Yacht Club | | |
2,649
guests, and 324
