| Re: Split rings on rudder pintles
[Re: sooneraviator]
#86019 10/08/06 10:04 AM 10/08/06 10:04 AM |
Posts: 829 Charleston, SC | I don't put anything in the bottom of the rudder pins on my 16. As long as you have pins in the top, the rudders will not come off because the upper casting keeps them down. I've never had a problem. ringding = split ring
Trey
[Re: NCSUtrey]
#86020 10/09/06 12:17 PM 10/09/06 12:17 PM |
Posts: 321 Albuquerque NM | Rings should work fine as long as you can get the rudder castings down over them.
As for only using the top pins, experiance tells me differant. after a capsize, I found that one of the pins did actualy find its way out while upside down. USE BOTH PINS
Sam
[b] Sail Like you have a Pair
[Re: NCSUtrey]
#86021 10/09/06 12:49 PM 10/09/06 12:49 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | I don't put anything in the bottom of the rudder pins on my 16. As long as you have pins in the top, the rudders will not come off because the upper casting keeps them down. Unless/until you turtle it....then the whole rudder/tiller/crossbar/hiking stick assembly could easily end up on the bottom of the lake....expensive! I realized what the bottom holes were for the first time I went turtle. I was inexperienced at the time and had no idea what to do next. How to right it came to me slowly, but the "bottom hole" revelation jumped right out at me! Jerome Vaughan Hobie 16 Clinton, Mi'sippi | | | Re: Split rings on rudder pintles
[Re: rattlenhum]
#86022 10/09/06 01:49 PM 10/09/06 01:49 PM | Anonymous
| Anonymous
Unregistered | Jesse:
Get some of the quick clips. They just slide in hole and click when they lock. I use them on Hobie 17 as pins go in from bottom. Just grab round end and pull when ready to remove. REAL easy.
Doug
[Re: CMerrell]
#86024 10/10/06 09:23 PM 10/10/06 09:23 PM |
Posts: 4,119 Northfield Mn | I've never ran a bottom pin, but have always worried about it coming out when the boat goes turtle, rarely do my cams come unlocked, but once in a while. It's still attached at the tiller crossbar anyway. No worse than breaking a plastic rudder pin like on a 14.
2,369
guests, and 385
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
