| Re: battens
[Re: mitch]
#87626 11/02/06 02:21 PM 11/02/06 02:21 PM |
Posts: 330 | My personal opinion is that there is a tendency to place to much emphasis on tuning via batten tension. The primary purpose of applying batten tension is to transfer tension across the skin of the sail in order to reduce or eliminate wrinkles, not to influence sail shape. Sail shape is a result of many factors, but primarily it is the reslut of the sail's cut, mast characteristics, and the tension applied by downhaul, mainsheet, etc. The stifness and taper of the battens themselves can influence sail shape to a degree, but they really should be made to accentuate the cut of the sail.
I pretty much tension my battens the same way for all conditions, under the premise that the tension of the batten should be slightly more than required to remove wrinkles (i.e. take out the wrinkles, pull a little more and you're there). In higher wind, I might put them in a little harder to reduce the chance of one getting loose and poking a hole in the sail.
It is my understanding that overtensioning the battens can actully result in flattening the sail because the excess batten tension pulls out the broadseaming along the batten pocket. If you've ever seen a sail with the "hungry dog look", there is a lot of draft in the vicinity of the batten, but the sail material between battens is quite flat.
Just my opinion.
sm | | |
4,684
guests, and 654
