Nacra Crossbar Beam Failure #8770
07/15/02 10:00 AM
07/15/02 10:00 AM
Maryland, USA
PRagen Offline OP
PRagen  Offline OP
Maryland, USA
My Nacra 5.5 SL front crossbar just failed. One end of the dolphin striker pulled out of the beam. I should say it pulled through the beam. It created a good 1.5 by 4 inch hole in the beam where the backing plate in the beam holding the dolphin striker end came right out. The rod holding the mast then pushed part way through the beam, since the dolphin striker was no longer holding it, and bent the beam, but the mast stayed up.
I assume this was a corrosion problem, but I have never heard of this happening. Has anyone else seen this? I don't know how you could easily inspect for such a thing.
Does anyone have any spare Nacra 5.5SL front crossbars lying around? I thought not.
Patrick Ragen
Taipan 4.9 USA 274
Re: Nacra Crossbar Beam Failure [Re: PRagen] #8771
07/15/02 07:35 PM
07/15/02 07:35 PM
brobru Offline
brobru  Offline
..I have seen that happen down here......when you look at the size of the 'spacer',...the part inside the mast,....it looks REAL light duty.....it would be sensible to redesign a better 'spacer' to distrubute the load more over a given surface area....
What until you see the price of a new beam...
Bruce
St. Croix
Re: Nacra Crossbar Beam Failure [Re: PRagen] #8772
07/16/02 08:22 AM
07/16/02 08:22 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
If you don't mind doing some drilling and fabrication, it might be worth it to have a look at industrial aluminum supply houses for Al tubing, which is what the beam really is.
Dwyer Mast co. might also have Al extrusion
Good luck
tami
Re: Nacra Crossbar Beam Failure [Re: tami] #8773
07/16/02 09:11 AM
07/16/02 09:11 AM
Long Island, NY
Ed Norris Offline
Ed Norris  Offline
Long Island, NY
Hi, Tami,
Isn't the crossbar powdercoated or externally treated in any way?
Sail Fast, Ed Norris
Re: Nacra Crossbar Beam Failure [Re: Ed Norris] #8774
07/16/02 09:45 AM
07/16/02 09:45 AM
Clear Anodized. Most anodizing shops will have facilities to anodize the 8'6" beam (just not a mast). The process isn't too expensive and I would estimate it would cost you anywhere from $30 to $75 for the anodizing. You can get this in colors too. (I wonder why no body ever does this).
Re: Nacra Crossbar Beam Failure [Re: PRagen] #8775
08/02/02 08:27 AM
08/02/02 08:27 AM
St Croix Virgin Islands
vicatman Offline
vicatman  Offline
the same thing happened to my TheMightyHobie18...the rod broke then the main beam broke...twisted the rear beam and it broke.. buddy of mine was on it...fortunately there was a guy in a powerboat that saw what happened and pulled him ashore....I got two used beams from a guy in Texas for $200 bucks...not bad..priced some used ones in FL for $225 a piece.....
Re: Nacra Crossbar Beam Failure [Re: PRagen] #8776
08/02/02 04:33 PM
08/02/02 04:33 PM
jcasto1 Offline
jcasto1  Offline
I have a N5.0 port hull with two crossbeams.
Take it off my hands, please!
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: 5.0 port hull - Symetrical or no?? [Re: jcasto1] #8777
08/04/02 05:51 PM
08/04/02 05:51 PM
Long Island, NY
Ed Norris Offline
Ed Norris  Offline
Long Island, NY
DID you say 5.0!!! I'm looking for a late model (mine's a 95) starboard hull - - - does anybody know if they're interchangeable??
0 registered members (), 2,726 guests, and 133 spiders.
