Re: The new Scheurer G5 A Class [Re: grob] #90441
11/28/06 12:08 PM
11/28/06 12:08 PM
Grob,
Now THAT's interesting
Do you have a link to more info ?
Can this material be hot formed or will that destroy the bond c.q. fibres
Re: The new Scheurer G5 A Class [Re: Rolf_Nilsen] #90442
11/28/06 12:17 PM
11/28/06 12:17 PM
Berylliosis is a form of metal poisoning caused by inhalation of beryllium dusts, vapors, or its compounds or implantation of the substance in the skin. The toxic effects of beryllium most commonly occur due to occupational exposure. Beryllium is a metallic element used in many industries, including electronics, high-technology ceramics, metals extraction, and dental alloy preparation.
There are two forms of beryllium-induced lung disease: acute and chronic. Acute berylliosis has a sudden, rapid onset and is characterized by severe inflammation of the lungs (pneumonitis), coughing, increasing breathlessness (dyspnea), and other associated symptoms and findings. In addition, in some individuals, the skin or the eyes may be affected. The more common, chronic form of the disease develops more slowly and, in some cases, may not become apparent for many years after initial beryllium exposure. Chronic berylliosis is characterized by the abnormal formation of inflammatory masses or nodules (granulomas) within certain tissues and organs and widespread scarring and thickening of deep lung tissues (interstitial pulmonary fibrosis). Although granuloma development primarily affects the lungs, it may also occur within other bodily tissues and organs, such as the skin and underlying (subcutaneous) tissues or the liver. In individuals with chronic berylliosis, associated symptoms and findings often include dry coughing, fatigue, weight loss, chest pain, and increasing shortness of breath.
Nasty stuff - if you inhale it.
Re: The new Scheurer G5 A Class [Re: grob] #90443
11/28/06 12:39 PM
11/28/06 12:39 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I have experience with aluminium impregnated with carbon fibres, this is also used for the gudgeon pins of Nascars, I believe its just been banned from F1.
Doesnt carbon and aluminum swap electrons? Wouldnt this combo degrade quickly in a marine enironment?
Re: New material usage [Re: fin.] #90444
11/28/06 01:32 PM
11/28/06 01:32 PM
Can you engineer a design that would reduce the loads to the point you don't need exotic materials? That sounds cheaper... But not as sexy as Unobtainium
SPEAKING OF toxic materials, I just heard that Russian spy who died was poisoned by an exotic material (Polonium 210??) made from Bismuth exposed to neutrons. not sure if I heard it right, but one milligram is more than enough to kill...
So all that cloak and daggar stuff isn't all fiction... <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: New material usage [Re: waterbug_wpb] #90445
11/28/06 01:43 PM
11/28/06 01:43 PM
Some things you might like to know:
http://www.webelements.com/webelements/elements/text/Pd/key.html
http://en.wikipedia.org/wiki/Polonium
Some things you won't:
http://www.godlikeproductions.com/b...mp;amp;mpage=1&showdate=11/26/06
Re: The new Scheurer G5 A Class [Re: Rolf_Nilsen] #90446
11/28/06 02:15 PM
11/28/06 02:15 PM
Houston
carlbohannon Offline
Houston
Year and years ago I designed a beryllium heat sink for some space hardware. A simple metal block, machined and then pickled.
We had a safety review and were required to do all the work in a special machining station with containment and filtration. To make long story short, I was standing outside when suddenly dust started blowing out. It took about 2 hours to determine it was just "dust" kicked up by a cooling fan. It was a very long scary 2 hours. Plus I was wet from being washed down.
That was scary but not really dangerous. We knew it was hazardous and had 2 levels of containment plus filtration masks. The real danger is when you don't have a clue. The best example is cutting edge aerospace where they were working with brand new materials. There are a lot of stories from 1950-1960's of technicians dying from strange illnesses after working on secret projects. The SR71 and Be-Al for example. More probable for sailors are the people who coat their lungs while spray painting IMRON without a respirator, cleaning toxic materials off your hands with solvents that are absorbed by the skin or the time the by-product of curing paint killed all the insect life in my garage. (Or that neat surplus or stolen stuff you bought on eBay)
Know what you are doing. I have enough friends that are sick right now.
Re: The new Scheurer G5 A Class [Re: carlbohannon] #90447
11/28/06 02:24 PM
11/28/06 02:24 PM
Thank you Carl.
Re: The new Scheurer G5 A Class [Re: carlbohannon] #90448
11/28/06 02:25 PM
11/28/06 02:25 PM
Decades ago I painted cars for a living. When it got to the point that I could TASTE enamel reducer when I got it on my hands, I found a new line of work.
Re: The new Scheurer G5 A Class [Re: grob] #90449
11/28/06 02:33 PM
11/28/06 02:33 PM
Houston
Houston
Well engineers have already succeeded at marrying aluminium and ceramics into a new material called glare. So why shouldn't it be possible ?
Same weight as Al, same stiffness as steel.
Gareth
The general term is matrix metal. High strength metallic crystals with melting points higher than aluminum are mixed with aluminum. Normally they use bromides, carbides and monocystals. Sometimes the price is reasonable. Specialized made some bicycles with M2 framses
Re: The new Scheurer G5 A Class [Re: Wouter] #90450
11/28/06 02:39 PM
11/28/06 02:39 PM
Brighton, UK
grob Offline
grob  Offline
Brighton, UK
Grob,
I have a picture somewhere, I posted it on this forum once but I know that link no longer works.
Its quite specialised and is very expensive at the moment. But like all these things should get cheaper as volumes increase. I think it can be made in a number of ways, the hard part is getting the two materials to bond well. The way we have used it it is hot formed in a mold, a bit like sintering, to get the net shape and is then finish machined.
Gareth
Re: The new Scheurer G5 A Class [Re: bvining] #90451
11/28/06 02:41 PM
11/28/06 02:41 PM
Brighton, UK
grob Offline
grob  Offline
Brighton, UK
Sorry I don't know the answer to that.
Gareth
Re: The new Scheurer G5 A Class [Re: grob] #90452
11/28/06 03:56 PM
11/28/06 03:56 PM
Gareth
Yes it does - no Alu in my new boat as a result !
Re: The new Scheurer G5 A Class [Re: grob] #90453
11/29/06 12:45 AM
11/29/06 12:45 AM
Thanks Grob,
Re: The new Scheurer G5 A Class [Re: scooby_simon] #90454
11/29/06 09:45 AM
11/29/06 09:45 AM
Houston
Houston
Gareth
Electrolysis works like an electrical circuit. When the carbon is completely contained and completely in contact with the aluminum you can't create a meaningful circuit. Like the copper in many aluminum alloys
0 registered members (), 17,433 guests, and 434 spiders.
Yesterday at 04:54 AM
