| Re: Latest, hottest, from Paris
[Re: Rolf_Nilsen]
#91365 12/05/06 12:25 PM 12/05/06 12:25 PM |
Posts: 902 Norman,OK | It looks cool, what would the advantage of the rig sliding, other than being a good way to cut off fingers?
[Re: MauganN20]
#91368 12/05/06 02:54 PM 12/05/06 02:54 PM |
If improved righting moment is the intend then he is sliding it in the wrong direction. You'll want the rig on the luff hull then !
[Re: Wouter]
#91369 12/05/06 03:19 PM 12/05/06 03:19 PM |
Posts: 3,528 Looking for a Job, I got credi... |
Indeed.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Latest, hottest, from Paris
[Re: scooby_simon]
#91370 12/05/06 03:39 PM 12/05/06 03:39 PM |
Posts: 12,310 South Carolina | could you get a hull out of the water that way?
Jake Kohl | | | Re: Latest, hottest, from Paris
[Re: fin.]
#91372 12/06/06 08:35 AM 12/06/06 08:35 AM |
Posts: 1,226 Atlanta | I've seen on of these on a trailer in CT. Always wondered what the heck it was. Not the best looking craft, especially on a trailer. | | | Re: Latest, hottest, from Paris
[Re: bvining]
#91373 12/06/06 09:12 AM 12/06/06 09:12 AM |
Posts: 6,049 Sebring, Florida. | In reference to the CLC design above, it looks like you could easily add another Ama to the other side and have a very neet little trimaran. I wonder if they could do a kit for the wood Blade F16? Most of their stuff is built using the Stitch and glue method while the Blade is done by the tortured ply method, I wonder which is lighter and which is stronger. Any thoughts out there? Maybe they could even do some A cat hulls for homebuilders?
Blade F16 #777
[Re: Timbo]
#91374 12/06/06 09:19 AM 12/06/06 09:19 AM |
Posts: 9,582 North-West Europe | "tortured ply" method is a more developped form of the general "stitch and glue" building method. In effect the first uses "stitch and glue" as well but adds steaming to the proced in order to end up with a more (complex) curved surfaces. I wonder which is lighter and which is stronger.
Hard to say, dependents on the specific design. Wouter
[Re: Andinista]
#91376 12/07/06 12:38 PM 12/07/06 12:38 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Wouter, et. al.,
If the hulls are of equal weight, unlike a proa, then if you put the mast on the leeward hull, you have the righting moment of nearly the whole boat's weight, but inversely, if it's on the windward hull, a much smaller righting moment, but a much larger displacement moment of the leeward hull.
I've always had a novel (I think) solution as well, but don't want to post it here. (the idea).
If you or another builer type could e-mail me, there could possibly be a patent in it.
F-18 Infusion #626- SOLD it!
[Re: srm]
#91378 12/07/06 07:18 PM 12/07/06 07:18 PM |
If you put the rig on the windward side, you get the righting moment of the weight of the boat + weight of crew + weight of rig.
sm
Not so. You get practically no advantage of weight when you put the rig on the windward hull. The only thing resisting the boat rotating upside down is the amount of buoyancy in the leeward hull. When you do use this to keep the boat upright, you depress the hull more in the water. You will get some minor lifting effect on the windward hull - but it will be small.
#91379 12/08/06 01:04 AM 12/08/06 01:04 AM |
Posts: 105 Bloomington, IN | Not so. You get practically no advantage of weight when you put the rig on the windward hull. The only thing resisting the boat rotating upside down is the amount of buoyancy in the leeward hull. Surely this is just phrased badly, Jake. If this were true, there would be no point to trapezing. Righting moment is determined by the center of bouyancy (CB) for the boat, combined center of gravity (CG) of everything on it, and the distance between the combined CG and CB (moment arm). Moving the mast to windward (towards the right in this diagram) will move the combined CG right, increasing the moment arm, thus increasing the righting moment - same as trapezing (although the mast/rig will have less effect being lighter than the crew). Why you would want a sliding mast in a practical boat is beyond me. The complexity is surely not worth it. However, ORMA 60 Tris have used mast canting to good advantage.
Jeff Tiger 849
[Re: Timbo]
#91380 12/08/06 06:07 AM 12/08/06 06:07 AM |
Posts: 3,348 | In reference to the CLC design . . . Maybe they could even do some A cat hulls for homebuilders? I contacted them, they said no. It would take too long for them to recoverer their costs. | | | Re: Latest, hottest, from Paris
[Re: Timbo]
#91381 12/08/06 08:25 AM 12/08/06 08:25 AM |
Posts: 1,226 Atlanta | Maybe they could even do some A cat hulls for homebuilders? Timbo, I dont know if you were asking this question because you wanted to build an A cat, but there are lots of ways to homebuild and lots of designs. Lots of build techniques too. I could probably get the stations for a current A design and you could strip plank or ply. PM me if you are interested. Bill | | | Re: Latest, hottest, from Paris
[Re: jbecker]
#91383 12/08/06 09:36 AM 12/08/06 09:36 AM |
Posts: 12,310 South Carolina | Not so. You get practically no advantage of weight when you put the rig on the windward hull. The only thing resisting the boat rotating upside down is the amount of buoyancy in the leeward hull. Surely this is just phrased badly, Jake. If this were true, there would be no point to trapezing. Righting moment is determined by the center of bouyancy (CB) for the boat, combined center of gravity (CG) of everything on it, and the distance between the combined CG and CB (moment arm). Moving the mast to windward (towards the right in this diagram) will move the combined CG right, increasing the moment arm, thus increasing the righting moment - same as trapezing (although the mast/rig will have less effect being lighter than the crew). Why you would want a sliding mast in a practical boat is beyond me. The complexity is surely not worth it. However, ORMA 60 Tris have used mast canting to good advantage. Agreed. But now look at a similar diagram with the mast on the windward side (and no trapezing) like we were talking about. The large majority of the sail pressure is offset by the buoyancy of the leeward hull, not the boat weight, in that arrangement. There would be very little boat weight on the side of the sail plan that provides the righting moment in your diagram.
Jake Kohl | | |
2,883
guests, and 311
