| Re: New to the sport
[Re: gruntpltleader]
#91788 12/10/06 01:21 AM 12/10/06 01:21 AM |
Posts: 713 WA, ID, MT | You can learn to sail cats on an TheMightyHobie18 with a little help and good sense (feed him beer AFTER sailing). You can rig the boat solo no problem, with the possible exception of raising the mast by yourself. I'm, 6', 160 pounds, and I could just barely raise it by myself. I always recognized that doing so was always taking a risk, of losing control and dropping it (a gin pole and the trailer winch can be rigged to safely raise the mast solo). You can safely sail it solo in light winds (less than 12 kts maybe?) once you have enough skill to sail upwind and down, and control the boat enough to avoid hitting things you shouldn't. With skill, you can sail solo with the jib. Wear your PFD! Read books on sailing catamarans (which are different from monohulls). You CANNOT right a TheMightyHobie18 by yourself. Seal the mast completely so it won't take on water, or the cat will turtle (mast straight down), which makes it much harder to right. Don't sail it overpowered solo without assistance available. And approach ocean sailing when you have more experience, the consequences of mistakes are much greater. The 18 is less susceptible to pitchpoling than the 16, but it can(and will) be done. Learn to move crew weight aft, way aft, when the boat is being driven hard off the wind. The skipper keeps one eye on the lee bow the whole time he's powered up, being prepared to steer out of trouble or dump the main (and jib?). Go for it! Be conscious of not sailing beyond you skill level. And feel free to ask this group questions, they're very generous with their time. Dave Spokane, 509 276 6355 | | | Re: New to the sport
[Re: warbird]
#91790 12/10/06 06:07 AM 12/10/06 06:07 AM |
Joined: Aug 2003 Posts: 241 Largo, Florida papayamon2
Posts: 241 Largo, Florida | "Gift" is good! Take the TheMightyHobie18, learn on it, and you can always transition to something else later on if you find it to be too much boat. Just take the advice given regarding staying in light wind until you're really comfortable, and always wear your PFD and appropriate clothing/wetsuit/drysuit for warmth. (How cold IS it in Oregon waters, BTW?)
I'm going to guess that if you're planning to solo often, you'll ultimately want to downsize a bit. (I just did.) On the other hand, some guys love the 18's and don't mind the gin pole rig to raise the mast, etc. It was just too much work for me personally, and it cramped my sailing schedule considerably to always have to line up w/ crew. But do take the boat, like I said, and you'll have plenty of time to work out your preferences in the future. You probably won't be soloing for awhile anyway if you're just starting cat sailing. | | | Re: New to the sport
#91791 12/10/06 10:11 AM 12/10/06 10:11 AM |
Posts: 3,348 | You can raise the mast alone, but why bother? If you have a friend, have him (or her) stand behind the boat, raise it to an overhead position and just walk it up until you're comfortable with the weight. It's more awkward than heavy. Be sure to manage all the wires so they don't kink or get caught. Shorter guys seem to have an easier time doing this. I'm 5' 8" and not particularly strong. It seems easier for me to step under the mast than it is for the six footers. My friend, at 6'6" 250 lbs always needs help, even though his bench press is well over 300 lbs.!
Keep your eyes and ears open for a set of "magnum" wings. They make the TheMightyHobie18 a primo party boat! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Later on, you can trick it out with a spinnaker to kick it up a notch!
WATCH OUT FOR OVERHEAD POWER LINES!! Electrocution is one of the few ways to die in this sport.
Keep us posted, let us know how you're doing.
[Re: warbird]
#91794 12/10/06 11:03 PM 12/10/06 11:03 PM |
Joined: Jun 2001 Posts: 217 Palm Harbor, FL, USA Lance
Posts: 217 Palm Harbor, FL, USA | As long as the hulls are solid, the rudders updated, and you have someone to help drag that beast up the beach the TheMightyHobie18's a great boat that you'll have a lot of fun on. It's tough, fast, and fairly easy to sail. Get a copy of the "Sharing The Wind" video to see what those boats are capable of.
Lance Taipan 5.7 USA 182 Palm Harbor, FL | | |
325
guests, and 44
