| Re: how to seal a fitting?
[Re: ferminj]
#92078 12/14/06 07:25 PM 12/14/06 07:25 PM | Anonymous
| Anonymous
Unregistered | I would not use 5200. Dealer said to use something else. 5200 is permanent. BE REAL careful!!!
Doug | | | Re: how to seal a fitting?
[Re: ]
#92081 12/15/06 01:25 PM 12/15/06 01:25 PM |
Posts: 1,459 Annapolis,MD | I would not use 5200. Dealer said to use something else. 5200 is permanent. BE REAL careful!!!
Doug I've heard that a product called Anti-Bond, available at West Marine, is very effective at removing and de-bonding 5200. | | | Re: how to seal a fitting?
[Re: Keith]
#92082 12/15/06 02:11 PM 12/15/06 02:11 PM |
Posts: 12,310 South Carolina | I would not use 5200. Dealer said to use something else. 5200 is permanent. BE REAL careful!!!
Doug I've heard that a product called Anti-Bond, available at West Marine, is very effective at removing and de-bonding 5200. It is if it's a thin bead of 5200. If it's a large contact patch that's filled with 5200, forget it. I know someone who inherited a boat on which the beams were seated with 5200. After trying every chemical known to man, the beam eventually claimed part of the deck before it was removed from the boat.
Jake Kohl | | | Re: how to seal a fitting? / 4200
[Re: papayamon2]
#92084 12/15/06 03:21 PM 12/15/06 03:21 PM |
Posts: 1,911 South Florida & the Keys | A polyurethane adhesive/sealant that is very similar to 3M Marine Adhesive/Sealant 5200, but that is about half the strength, which allows for disassembly of parts. 4200 delivers flexible bonds with good adhesion to wood, fiberglass, gelcoat, certain plastics, and metals. It is paintable and sandable, and forms watertight, weather-resistant seals on joints and boat hardware above or below the waterline. | | | Re: how to seal a fitting? / 4200
[Re: arbo06]
#92085 12/15/06 03:48 PM 12/15/06 03:48 PM |
Posts: 215 Ohio | Agree... 4200. I have used it on RV windows and body seams, sealing screws and bolts in boats, etc. It remains flexible and holds until you want to remove it.
Silicone should not really be used on anything that flexes, moves, vibrates. Vibration alone will cause silicone to release. Save it for your bath tub.
Mike, Ohio Former H16, H18, N20, N17, M4.3
[Re: TeamTeets]
#92086 12/15/06 06:09 PM 12/15/06 06:09 PM | Anonymous
| Anonymous
Unregistered | Guys:
I couldn't remember the number, but 4200 is what the dealer wants to use to rebond my crossbars on my 17 to stop water coming in as a winter project.
Doug | | |
407
guests, and 47
