Downhaul System for The Blade #92151
12/14/06 04:58 AM
12/14/06 04:58 AM
Houston, TX
asaber Offline OP
asaber  Offline OP
Houston, TX
Does anyone have pictures of the downhaul system for the blade or a better setup (more efficient and easy to thread) then the standard factory setup they can share?
My 9 yr old son (Omar) who is learning to crew and drive the boat has a tough time with the downhaul, in the standard setup.
Many Thanks,
Asim
Houston, TX.
Asim_Saber - Blade X-1
'No Mo Speed, I'm almost there'
Re: Downhaul System for The Blade [Re: asaber] #92152
12/14/06 06:42 AM
12/14/06 06:42 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Asaber,
Did you already check the improved downhaul system on the European Blade ? It is a lot easier and lighter to handle then the previous system. My Blade is still being made so I won't be able to send you pics now.
Gill
Re: Downhaul System for The Blade [Re: asaber] #92153
12/14/06 06:48 AM
12/14/06 06:48 AM
I have the internal downhaul, original equipment from the factory. The other guys who've seen it seem to like it.
Try giving Vectorworks a call.
Re: Downhaul System for The Blade [Re: fin.] #92154
12/14/06 09:15 AM
12/14/06 09:15 AM
Asim, what kind of downhaul system do you have? Is it the external cascadin 8:1?
I to would like to upgrade this system, but frankly I have not been able to figure out, how to do so. Aparently I will need to perform some radical changes of what is located where on the mast. I am not very fond of drilling extra holes in the mast. I dont like the system very much, but I have learned to suck it up and deal with it.
Re: Downhaul System for The Blade [Re: Robi] #92155
12/14/06 09:36 AM
12/14/06 09:36 AM
These are exterior shots of the my downhaul, if you like I'll pull it apart so you can see the inside. Not much too it.
This is the distance up from the mast base. This through bolt is the main support.
Re: Downhaul System for The Blade [Re: fin.] #92156
12/14/06 09:39 AM
12/14/06 09:39 AM
Mast base.
Re: Downhaul System for The Blade [Re: fin.] #92157
12/14/06 09:39 AM
12/14/06 09:39 AM
another.
I think the simplest thing would be to order it from Vectorworks.
Re: Downhaul System for The Blade [Re: fin.] #92158
12/14/06 10:20 AM
12/14/06 10:20 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Yeah - I'd recommend switching to the internal system. If Vectorworks can supply the mast base, the rest is off-the-shelf parts (although I think there may be some spacers on the top bolt).
Putting it together will be a bit fiddly, but really not that hard. When I took mine apart, I successfully taped a bit of rope to the end of that top bolt, pulled the bolt out, and then lowered everything down the mast. Reassembly was just a matter of pulling the rope tight, and then sliding the bolt back through.
Initial assembly will be a little bit harder as you'll need to put stuff onto the middle bit of the rope whilst it's hanging out the bottom of the mast, but if you use sufficiently thin rope, you should be able to cut and knot it, and still get it through the bolt holes in the mast.
Re: Downhaul System for The Blade [Re: fin.] #92159
12/14/06 10:47 AM
12/14/06 10:47 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
I think that it should mentioned that the actual downhaul can be seen in the last pic in the top left corner (peeking out from behind the rotation arm).
Re: Downhaul System for The Blade [Re: bobcat] #92160
12/14/06 11:39 AM
12/14/06 11:39 AM
Oops! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
1 registered members (Damon Linkous), 4,145 guests, and 742 spiders.
