It's painting time (opinions required) #9243
08/06/02 02:12 PM
08/06/02 02:12 PM
reidqa Offline OP
reidqa  Offline OP
Everybody,
The hulls have been sanded, the small dings and scatches bondo"ed. I am going to paint this historical beauty with the following.
Water-Based Acrylic Enamel Paint Primer (Grey)
2 coats sanded between with 80 grit
Polyurethane Enamel Gloss White
2 Coats (paint heated to maximize gloss)
Anybody any last idea's.
Re: It's painting time (opinions required) [Re: reidqa] #9244
08/06/02 09:29 PM
08/06/02 09:29 PM
Sandy Hook, NJ Fleet 250
jonr Offline
jonr  Offline
Don't paint… the boat is fiberglass, use the appropriate materials. Paint will scrape or peel off (80 grit paper will make scratches you can see from 50 feet). You may be able to sand and polish the gel coat back to its original condition. Start sanding with 400 go to 1000, then 3m polishing compound. Any voids should be filled before final sanding. If gel coat is to thin for sanding re-coat with quality polyester or epoxy.
Re: It's painting time (opinions required) [Re: jonr] #9245
08/07/02 07:22 AM
08/07/02 07:22 AM
reidqa Offline OP
reidqa  Offline OP
Jon,
I agree but cost is prohibited to epoxy entire hulls. The boat is to be gently sailed, never/ever raced. The age of boat will not permit any stresses (president of Hobie informed it could be dangerous).
Many Thanks
The hulls are extremely faded due to over 20 years of sitting in previous owners yard
Re: It's painting time (opinions required) [Re: reidqa] #9246
08/07/02 02:38 PM
08/07/02 02:38 PM
catman Offline
catman  Offline
If you use 80# grit your going to have a mess of scratches in the paint. You should use 320 or 280 between coats. are you using a DA. or hand sanding? I painted my boat and used no primer. The paint will stick to the properly preped gel coat just fine.
Re: It's painting time (opinions required) [Re: catman] #9247
08/07/02 04:04 PM
08/07/02 04:04 PM
reidqa Offline OP
reidqa  Offline OP
Cat,
You are correct about grit along with emails, I have received. I have sanded the hulls in preparation for painting. I will be hand sanding between coats, to inexperienced with power.
Many Thanks
Re: It's painting time (opinions required) [Re: reidqa] #9248
08/09/02 12:48 AM
08/09/02 12:48 AM
If the boat "will not permit any stresses" I wouldn't bother about the paint.
WoW
Re: It's painting time (opinions required) #9249
08/09/02 04:54 AM
08/09/02 04:54 AM
reidqa Offline OP
reidqa  Offline OP
Wind,
The stress is racing, not gently sailing, this is an origninal Hobie out of the 1000's built, it's #66 from 1968 (the year Hobie started). The parts after 1972 do not even fit on boat, on a major search for product of pre 1972 production boats.
The hull has an extreme curve which is signature of orginal Hobie design, and has sat in yard for over 20 years.
Yes, its a classic and as such must be treated as such, gentle handling for a gentle girl.
Re: It's painting time (opinions required) [Re: reidqa] #9250
08/09/02 06:54 AM
08/09/02 06:54 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I just painted my H-20 with Awl Grip. It looks great!
Just don't be scared to paint slowly to ensure complete coverage. I went too fast and the finish is dull in the spots where I did't get enough paint applied
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: It's painting time (opinions required) [Re: jonr] #9251
08/09/02 04:15 PM
08/09/02 04:15 PM
Houston, Texas
EasyReiter Offline
EasyReiter  Offline
Houston, Texas
My opinion:
Dont paint, it will peel, crack, chip and mostly look bad.
If you really love the clasic nature of a Hobie from 1968 and do not intend to use it as most of them now are (planted in concrete in front of a t-shirt shop) then sand and polish the hulls to their original shine, it is not that hard to do and will last as long as the 35 year old fiberglass will.
PS. there is nothing that will make acrylic stick to fiberglass for very long.
Marc Reiter I 20 #861 Dikes, Ferries and Tramps. www.texascitydike.com
0 registered members (), 368 guests, and 46 spiders.
