| Re: drain plug install question
[Re: papayamon2]
#94138 01/03/07 06:51 PM 01/03/07 06:51 PM |
Posts: 12,310 South Carolina | You probably need to attach the new drain plug fitting with screws (I'm assuming you're talking about the metal part and not gluing in the actual plug itself - right?). You can fill in the original screw holes with 5200 and perhaps rotate the fitting to create a fresh new set of holes specifically for that fitting.
Jake Kohl | | | Re: drain plug install question
[Re: avalondarlyn]
#94140 01/07/07 05:20 PM 01/07/07 05:20 PM |
Posts: 263 SC | Another aproach you might want to consider. The Hobie 20 uses nylon drainplugs that simply thread into threaded holes in the sterns, Once I forgot mine and to sail for the weekend I epoxied the holes shut (I know ... ) after I got the boat home I redrilled the holes and taped them to fit. No fittings necessary.
Always borrow money from a pessimist. He won't expect it back.
[Re: zander]
#94141 01/07/07 05:24 PM 01/07/07 05:24 PM |
Posts: 263 SC | P.S. you can get the h20 plugs from the catsailor online store.
351
guests, and 36
