| I am planning a cruise and need some help #94671 01/06/07 04:35 AM 01/06/07 04:35 AM |
Posts: 902 Norman,OK | Some of you know that I have a Nacra 5.2, and I am planning a small cruise on it in the middle of march.
The plan is to sail from Corpus Christie in the direction of Galveston. I have a list of important stuff that I know I need. The trip will involve sailing along the coast in the internal waterway between the mainland and the coastal island. At night I will be camping out and cooking some basic food over a small gas stove.
The storage of the gear isn't to much of an issue, I have a truck bed cover that I have folded into a triangle and have hung up front acting like a forward tramp. It won't hold a person comfortable but will hold gear.
What I am looking for is some input on a few things. First off I want you all to give me so ideas on equipment. I already have a nice list going but I think that outside input will help. I have all the camping gear and it is very light because I have used it for elk hunting in New Mexico.
So get started what do I need?
Also I plan to be self sufficient on this trip because I want to be able to turn around at anytime without having to worry about reaching a destination to restock.
I forgot to add above that a close friend will be sailing his Hobie 17 with me and will need the same information, but we don't want to have to rely on each other.
Okay, and in my defence I understand that these boats are not made for distance sailing, but if the guys can sail stuff like the worrel and other distance races surely we can take it easy and have some fun!
| | | Re: I am planning a cruise and need some help
[Re: gree2056]
#94672 01/06/07 07:55 AM 01/06/07 07:55 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Seems to me that if people are able to go hiking in the wilderness for a week or more with everything they need in their backpack, you should be able to do the same thing on a boat. Only difference that you don't have to actually carry the backpack yourself -- just tie it down on the tramp. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Sounds like a fun trip, since you are doing it on the "inside."
Don't forget to take a paddle. And watch out for tidal current at inlets, because it can sweep you right out to sea, if the current is anything like it is at inlets in Florida. | | | Re: I am planning a cruise and need some help
[Re: gree2056]
#94673 01/06/07 09:43 AM 01/06/07 09:43 AM |
Posts: 12,310 South Carolina | Not made for distance sailing? Pahshaah.
First; test your forward trampoline before you rely on it. It would be a bad third or fourth day to have all your gear disappear when you get some bad weather. Second, weight forward on a catamaran (a 5.2 doesn't have a ton of reserve buoyancy up front either) can be a problem if the weather gets strong. The solid toneau cover might also pool water leading to an additional weight problem. If you are single handing, you should easily be able to store the things you need on the main trampoline. Use dry bags, you can get large ones from walmart for about $12 to $15. You can move the drybags from the front beam to the rear beam depending on where you think you'll need the weight.
Safety gear: VHF radio, Cell phone (stored somewhere VERY nice and dry), waterproof flares, whistle, paddle, righting system to solo right the boat...EPIRB might be nice but since you are staying inside, it is probably not a requisite item.
Jake Kohl | | | Re: I am planning a cruise and need some help
[Re: gree2056]
#94674 01/06/07 09:50 AM 01/06/07 09:50 AM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | Gary Friesen is the person to get information and instruction from on this subject. He has done several camping/cruises from southern California to the Catalina Islands, sometimes is some pretty hostile conditions. He also has some pretty well written accounts of these trips in the ezine "On the Wire". I was unable to find it though. It's out there somewhere.
-Rob V. Panama City Rob V.
Nacra 5.2
Panama City | | | Re: I am planning a cruise and need some help
#94676 01/06/07 03:23 PM 01/06/07 03:23 PM |
Posts: 902 Norman,OK | I have tested it, I loaded it up with almost 200lbs of gear and went for a cruise on my local lake. Granted I won't have that much gear on it when I got down there but I wanted to check and make sure it was solid. Also it isn't solid, it is netting. So it won't hold any water.
I have all the safety gear mentioned and some other stuff. I even added a small inflatable raft. I figured that if something was to happen and i needed to abandon the boat it would be nice to have something floating.
When i loaded up the front with 200 pounds i did have to take it easier in chop but the boat does pretty good even with all that weight up front. I figure that the heaviest stuff I will store on the tramp but other than water I think I can get on the water under 50 pounds.
How much water should I take. Lets just say it should be a five day trip, and I want to take double the water I should need. Would 6 gallons be sufficient plus some gatorade to drink?
[Re: Mary]
#94678 01/06/07 03:57 PM 01/06/07 03:57 PM |
Posts: 902 Norman,OK | I over did it when I loaded up the boat for the test. I figured if I was going to test it I might as well over do it. Like I said above, I am looking to get on the water with less than 50 pounds of stuff on my boat not including water. Then if I take 5 gallons of water that is 40 pounds so I am looking at 90 pounds total. I think I could shave another 10 pounds off the gear so I could be on the water with less then 80 pounds on the boat. The old Nacra will hardly notice 80 pounds.
I was thinking Ramen noodles and trail mix. My tent only weighs 4 pounds and sleeps two. The camp stove is less than a pound and I won't need many cloths. So this should be a pretty light packing job.
[Re: gree2056]
#94679 01/06/07 04:20 PM 01/06/07 04:20 PM |
Posts: 5,590 Naples, FL | take a hiking size water purifier. The good ones will desalinate/purify about 1 liter/10 minutes. Handheld & small, it's a great emergency tool to extend your water rations
[Re: waterbug_wpb]
#94681 01/06/07 06:25 PM 01/06/07 06:25 PM |
Posts: 902 Norman,OK | So the water filter I have will desalinate the water? I didn't think it would since the salt is dissolved into the water. I have one of those that I use in the mountains, I will take it for sure if it will make the water drinkable.
Also Mary, I am really excited about this cruise. It won't be hard and should be a blast.
I am also a pretty avid bass fisherman, I am going to take a heavy bass rig with a small tacklebox. I know there are some redfish on those barrier islands so I should have some fun fishing also.
[Re: MauganN20]
#94683 01/06/07 06:36 PM 01/06/07 06:36 PM |
Posts: 902 Norman,OK | I didn't think so. I will just make sure to take plenty of water.
[Re: gree2056]
#94684 01/06/07 11:40 PM 01/06/07 11:40 PM | Anonymous
| Anonymous
Unregistered | | | | Re: I am planning a cruise and need some help
[Re: ]
#94685 01/06/07 11:44 PM 01/06/07 11:44 PM |
Posts: 902 Norman,OK | Yeah, that would be really cool....but it costs more than what I paid for my boat.
[Re: Mary]
#94686 01/07/07 09:13 AM 01/07/07 09:13 AM |
Posts: 12,310 South Carolina | That sounds like SO much fun. I wish we could get more catamaran sailors interested in doing group cruising trips like that. Actually, yeah...that does sound like a lot of fun.
[Re: ]
#94687 01/07/07 09:14 AM 01/07/07 09:14 AM |
Posts: 12,310 South Carolina | Have you ever tried one of those? You'll sweat 1 gallon worth of water for every cup produced. The specs say you get about 1oz every 2 minutes and it requires 40 (not easy) strokes a minute. | | | Re: I am planning a cruise and need some help
[Re: avalondarlyn]
#94690 01/07/07 12:47 PM 01/07/07 12:47 PM |
Posts: 902 Norman,OK | If you read a little closer about the forward tramp it is a triangle. It is a net truck bed cover. I folded it in half making it a triangle. The back side is attached along the front crossbar. The front or the corner of the netting attachs where the bridle wires meet. So it is basically what you are talking about.
I am taking a paddle, it is a plastic paddle with an aluminum handle and a plastic grip. I think somewhat close to what you describe. I also have an extra shroud, I think between it and some other stainless cable that I have and am taking I should be able to repair anything. I hadn't thought of the innertube. I will have to add that to the list.
I love the pictures of the boat taking the distance sail. I might go with a tarp over the tramp but in a big rain storm it might be nice to get inside a very dry ten rather then a leaky tarp over an already wet boat. My tent that i have is a very extreme tent, made for winds up to 80mph, and completely water proof. I would have a hard time justifying not taking it when it only weighs four pounds and can set up in just a matter of minutes.
Keep up the great suggestions!
2,100
guests, and 208
