| Re: "backpack-type" water bladder
[Re: catsailorp19mx]
#9591 08/16/02 02:08 PM 08/16/02 02:08 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | CamelBak is the name of the product.
They've got a webstite--www.camelbak.com
The backpack/fluid bottles are used by mountain bikers, X-country skiiers, etc. They come in different sizes and should be available at outdoor sport outfitters like REI or EMS.
[Re: ejpoulsen]
#9593 08/16/02 05:40 PM 08/16/02 05:40 PM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | The generic term for the products is "hydration packs", although CamelBak has captured a large chunk of the market share. Some of the PFD manufacturers are making hydration packs designed to fit onto PFD's. I own one made by Lotus Designs (the EFT pack) and love it. (They are a subsidiary of Patagonia.)
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
#9596 08/22/02 11:43 AM 08/22/02 11:43 AM |
Posts: 5,590 Naples, FL | As far as using the water to add to your minimum weight, most design class racing won't permit that, and you'll get restriction weights. But if you're headed to a distance race, it's almost a must for equipment. As you say, I always get thirsty on the wire, and it's not exactly convenient to have to go down and rummage through stuff to find a drink.
A note of advice here. My crew has the smallest "backpack" possible (no extra storage space other than the fluid bladder). This keeps her from getting hung up while tacking. I have a larger one (storage area that is, we have similar fluid capacity - 70 oz) so I can keep a radio and emergency equipment on my person in case I fall off the back or break something. Not to mention it's a good place to put energy bars (crew has to get them out though)..
My 2 cents
Team Katastrophy
[Re: DanWard]
#9599 08/22/02 06:06 PM 08/22/02 06:06 PM |
Posts: 217 | I believe these devices are not legal for racing, there is no technical difference between this device and a "water jacket". i.e. you can wear a real big water bag on your back for first upwind leg, then dump out all water at first mark, and cover your opponents. Highly unfair, and ruled out. I believe there is actually a IYRU or USYRU (now US Sailing) appeals case.)
It really p*ss*ed me off, because I have had one salivary gland removed due to tumor, and I get really thirsty when sailing. And, with my unirig, there is no wench onboard to hand me a drink, either!! Wonder if I can get a doctor's note?
[Re: Eric Anderson]
#9600 08/22/02 06:28 PM 08/22/02 06:28 PM | Anonymous
| Anonymous
Unregistered | Hi Eric,
What does this SI stand for?? Plus, if I'm doing my conversion factor correctly- 8 to 10kg's equals to about 16 to 20 pounds.- that's alot of water. I personnally have a camelbak- The one a have holds 70 oz's. (adding probably 2 pounds to my person.) I have to also say -THEY ARE GREAT!- I would hope that people used them only for drinking (water....) purposes and not abused for adding weight to their person. Thus, there might be a possibility to allow them for racing.
| | | SI = Sailing Instructions #9601 08/22/02 08:14 PM 08/22/02 08:14 PM |
Posts: 217 | He's saying check the sailing instructions for the race, to be sure t's not illegal to have this type equipment while racing?.
| | | Re: SI = Sailing Instructions
[Re: jcasto1]
#9602 08/22/02 08:26 PM 08/22/02 08:26 PM | Anonymous
| Anonymous
Unregistered | Thanks!- I guess I should of known that one.... | | | Re: "backpack-type" water bladder
[Re: Eric Anderson]
#9604 08/23/02 09:19 AM 08/23/02 09:19 AM |
Posts: 5,590 Naples, FL | Eric has a good point - always check with the sailing rules for that race. Obviously, anything with bouys will probably not allow it. Many distance stuff we've been in doesn't specify that you can't race with it, and as someone else said, 70 oz. of water weighs a little over 4 lbs.
My issue is that with the other required gear, I could see this weight going over. I would presume that the max weight varies per race, as EPIRB, radio, flares, drysuit, etc probalby puts close to 25 lbs on me. Maybe I'll switch the flares for the water.....
Just some thoughts...
[Re: EasyReiter]
#9608 08/23/02 01:14 PM 08/23/02 01:14 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I don't see the problem with camelbacks for distance racing. .
When you drink the water where does it go? A couple pounds of water or whatever isn't going to be the deciding factor in a 100 mile race. Dehydration could be to your health!
655
guests, and 139
