Page 3 of 3 1 2 3
Re: Click on my name and you'll see my personal info [Re: Wouter] #988
08/08/01 07:42 AM
08/08/01 07:42 AM
brobru Offline OP
brobru  Offline OP
<br>1. Ok,..see, now I know.
<br>2. I am a numbers person. I am a professor at University of the Virgin Islands in CIS(comp info science).
<br>3. The Danes have a rich history in these Islands ( St. Thomas, St. John and St. Croix) you know.
<br>4.The site referreed to a few posts ago confirm what you have numerically plotted out,...he said lift the boards too( with out the math).
<br>5.OK, ...NEXT QUESTION.......mast -spreader- configuration. The I-17 mast was previously set up on PRE -BEND mode( spreaders back 4 inches, super tight wire). I changed it to a 1 inch bach-tight configuration. This is the only other factor I changed ( ..the other factor being the mast rake foreard 1 hole,...which, I believe did not matter much).
<br>6. Knowing the above factors, and that before there was 100% neutral helm,....and now it is weather helm and slo....comment?....analysis?,....suggestions...
<br>regards,
<br>Bruce
<br>St. Croix <br><br>
Re: Click on my name and you'll see my personal info [Re: brobru] #989
08/08/01 06:43 PM
08/08/01 06:43 PM
Bruce,
<br>In raking your spreaders forward you have straightehed your mast.
<br>It is great that you have adjustable spreaders because it will assit you in setting up your masts bending characteristics to your sail and body weight.
<br>
<br>I suspect what you have done is made your sail fuller but more importantly you have made your leach tighter.
<br>These things induce drag and also give the weather helm.
<br>(Slow and weather helm.)
<br>
<br>If you want to sail with your mast set like this you will have a lot of power off the breese but your going to pay for it upwind.
<br>Once again you will either have to sail upwind with your traveller out further or get some more bend back into that mast.
<br>As you sail upwind ease your traveller an inch at a time and eventually the helm should go nuetral again. If your mast is too straight you may still not be able to get it going the way you want it. Give it a try and see.
<br>
<br>You have two variables to play with, diamond tension and spreader rake. They can both be set in different combinations to give the same prebend at rest but once you start applying sheet tension and downhaul the mast will behave differently. The more spreader rake the more the mast will bend under load.
<br>If you're not happy I would suggest you measure your prebend now and then gradually remove pre bend and measure and document your settings and observations.
<br>
<br>My veiw is that basically a lighter person will benefit more from more spreader rake and a heavier person less spreader rake even if the pre bend is the same unloaded.
<br>
<br>There are a lot of variables and it is essential to keep track of your tuning progress that you do your best to change only one variable at a time.
<br>
<br>Just something for you to think about.
<br>
<br>Phill<br><br>
1475- (22 downloads)
Re: Click on my name and you'll see my personal info [Re: phill] #990
08/09/01 08:16 AM
08/09/01 08:16 AM
brobru Offline OP
brobru  Offline OP
Phill,
<br>1. Looks like I will be adjusting things this weekend.
<br>thanks
<br>Bruce<br><br>
Page 3 of 3 1 2 3
0 registered members (), 641 guests, and 43 spiders.
