| Re: Broken Gudgeon Bolts
[Re: peter]
#96878 01/22/07 12:47 PM 01/22/07 12:47 PM |
Posts: 36 MOBILE, AL. | A 4" porthole has to be put in behind the rear crossbar. I went through the suggestions that have been posted & it boiled down to wasted time. Plus once you get the bolts out the plate in the hull will fall out & you will have to put in a porthole anyway. it is a good thing to have the porthole for a spooge to soak up water in the future. Doug
SOUTHERN CROSS FIBERGLASS, LLC.
9301 HWY. 90 EAST
MOSS POINT, MS. 39581
251-473-8159 DOUG KLEM
[Re: papayamon2]
#96880 01/22/07 12:58 PM 01/22/07 12:58 PM |
Posts: 36 MOBILE, AL. | you can do that but you still end up with the corrosion problem down the road so the port is needed and quite handy to have for storage .
9301 HWY. 90 EAST
[Re: peter]
#96883 01/22/07 06:14 PM 01/22/07 06:14 PM |
Posts: 1,383 Kingston SE South Australia | Peter your spending a few dollars on tools if that doesn't work take it to your local vehicle workshop and they will tap it out for you. It wont cost much they do it all the time on old motors. For attatching stainless fittings to aluminium get a tube of the anticorrosive gunk to put on all your bolts, rivets etc regards
[Re: bvining]
#96885 01/23/07 12:08 AM 01/23/07 12:08 AM |
Posts: 41 los angeles | Looks like I've got my work cut out for me this coming weekend. I'll pick up some Blaster and my left handed bits and give drilling out the bolts a go. Hopefully using care and some appropriate guide blocks will do the trick, and I'll be able to clean up the threads in the backup plate with a tap and be done. If not, I came across a "broken screw extractor" today which could be used as a last resort. It's essentially a 3/8" diameter hardened steel tube with saw teeth milled into both ends, and it has a bore of slightly more than 1/4". I tested it, and it does cut aluminum, although because it has no set to the teeth, it has little clearance for the chips and has to be extracted every 5 seconds or so and cleared. Using a guide block with a 3/8" hole, I could cut down around the outside of the bolts, through the glass and the aluminum backing plate, and remove the bolt like a wooden plug in a hole saw. McMaster Carr catalogue has a stainless threaded insert for a 1/4-20 bolt which has an external 7/16" thread, which could be tapped into the hole in the backing plate and epoxied in place. Then I'd theoretically be back in business, once I fill the enlarged hole in the glass back up. But I'd rather go the other route, if possible. I'll let you all know how it turns out. Thanks for all the great brainstorming. This forum is great!
Peter | | | Re: Broken Gudgeon Bolts
[Re: peter]
#96886 02/04/07 07:18 PM 02/04/07 07:18 PM |
Posts: 41 los angeles | Got 'em out! PB Blaster and the bolt extractor worked on one of them, once I had a proper hole bored in the end of the stud using a cobalt drill bit. The bit that came with the extractor was useless. The other bolt was a lot more work. Using the broken screw extractor (see earlier post) and a wooden guide block with a 3/8" hole in it, I bored a 3/8" hole around the outside of the broken bolt. Since the extractor's ID is only slightly more than 1/4", it used the bolt itself as a guide once it got started. I drilled as deep as the aluminum plate. I then cut a length of 3/8" thin-wall steel tube, and inserted it into the hole in the transom, so that it protruded about 1/4". This gave me a reference fitting for my drill blocks. I set up a fence and stop on my drill press, drilled a 3/8" hole 1/4" deep into the block, and, using the same setup, drilled the guide hole for my bits to drill into the stud, exactly centered on the 3/8" hole. I used my Dremel with a silicon carbide grinding wheel to give me a flat on top of the stud, and used a spotting drill bit in one of my guide blocks to get a start. I then started with a 1/8" bit and worked my way up to a #7, and then cleaned out the threads with a 1/4-20 tapered tap. Trick is to drill SLOW, maybe only 100-200 rpm, with lots of pressure, and cutting fluid. If you build up heat, you'll work harden the stainless. Careful not to let the bit grab and snap off (don't ask). The relief I feel right now is priceless. Now to finally finish off this boat and get it into the water. Thanks to everyone for your ideas and support. Hopefully my experience will prove useful for someone else.
Peter Shapiro P19MX | | |
350
guests, and 51
