Daggarboard settings [Re: mcole] #9797
08/23/02 09:01 AM
08/23/02 09:01 AM
Well, at approx 460 lbs, you are definitely going to break things on that boat when the wind blows. Consider a smaller skipper or reserve some money for new boards!
In actuality, I'm not as smart as your average sailor, so I marked my boards in 6" increments. This way I can holler - "Boards at 2, downhaul at 4", etc. and even the new crewmember can figure it out. I've marked a lot of things (got it from monohulls): Traveler, boards, outhaul, downhaul... West Marine has those cool stickers if you want to make it look good.
As far as settings go, you'll need them (on average) deeper than we would, as we're barely minimum weight (327). Here are my guidelines:
Upwind/light air (up to 5) - all the way down
Upwind/breeze (5-12) - 6" from all the way down
Upwind/strong breeze (12-18) - almost 1/2 way down
As you can see, we don't need as much lift as the wind picks up, and the lift causes heel. The board still helps us track well, but keeps us from getting knocked over as much
Reach/light wind - full down
Reach/breeze - 1/2 down
Reach/strong breeze - 1/4 or less down
Again, it's a lift thing. As the breeze picks up, we want the boat to sail flatter and plane more because I can't stand any further aft than the rudder casting, so the boards come up to reduce drag and tripping
Run/light wind - full down
Run/breeze - 3/4 down
Run/ Strong breeze - 1/4 or less down
Again, lift adds a bit of heel. In bouys, that's great to drive deeper. In distance, the course may not always favor driving that deep, so the boards go up.
Also keep in mind that these settings are combined with mast rake, rotation, downhaul, outhaul, sheet and traveler, and even weight distribution.
Good luck to ya! Hope this helps get you in the ballpark, too! Maybe we'll see you at the Tybee 500 this spring...
Team Katastrophy
I-20 USA 279
Re: Making boards? [Re: tami] #9798
08/23/02 10:07 AM
08/23/02 10:07 AM
Houston, Texas
EasyReiter Offline OP
Houston, Texas
I can make any part for any boat the limit being the cost of the mould. that is if I have to make a mould for a one of a kind part then the cost of the part includes the cost of the mould. right now I have the desire to make I20 dagger boards cause I need one. I would construct them almost the same as the original unless someone wanted one that was stronger and then I would add more carbon fiber or aluminum to reinforce the part also I can put custom colors and designs in mine. the cost would probably be %50 - 60 of a new one, on a part that I do not have a mould for and about %40 if I do.
Marc Reiter I 20 #861 Dikes, Ferries and Tramps. www.texascitydike.com
0 registered members (), 21,417 guests, and 762 spiders.
Yesterday at 04:54 AM
