| Re: Trends in spi design
[Re: Rolf_Nilsen]
#98045 02/05/07 04:27 AM 02/05/07 04:27 AM |
Posts: 285 | Guys,
It doesn't help to understand if something's changed in spi design to speak of tight luff or a loose luff. Please let's stick to the numbers. Please Rolf take the time to measure the luff of yr Gransegel asymmetric. Are you sure about the 9,10 mm distance between max hoist and end of pole? Apparently it seems to me a little too much. Please follow my argument: since the max hoist is set at 8,18, we can estimate the distance between max hoist and pole attachment to the main beam at 8,30 m. Now square root of (8,30x8,30+4,00x4,00)= 9,21 m with the pole parallel to the ground.
Please Dan and Tornado Alive do the same (i.e. take the measurements) on yr F18s. The distance between max hoist and pole attachment in F18 catamarans is very close the Tornado's (as per the F18 class rule max hoist is set at 8,15 m), however the pole lenght should be a little less. From the examination of the pics F18 spi apparently have a shorter luff but I would not trust much into pics. Please check also the girth of yr F18 spis. Thanks
P.S. Incidentally are you aware of Gransegel spis on the boats of WORLD CLASS F18 crews? | | | Re: Trends in spi design
[Re: Catfan]
#98046 02/05/07 05:19 AM 02/05/07 05:19 AM |
Posts: 1,669 Melbourne, Australia | Please Dan and Tornado Alive do the same (i.e. take the measurements) on yr F18s.
Sorry mate, boat is de-rigged and de-beamed ready for the trip up to the Worlds. As of this weekend, you wont here from me for the rest of the month. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> P.S. Incidentally are you aware of Gransegel spis on the boats of WORLD CLASS F18 crews?
Whilst there are none better as far as Tornado kites, from what I have heard, they have not got the shape right for the F18s as yet. Anyone out there running Gran Segel F18 Kites ????? As for luff tension, like I said I run mine tight. Minimal twist if you grab the full with your hand..... Under load though it will not look quiet so tight as you have a bit of flex from the pole, stretch from the sail cloth and halyards. | | | Re: Trends in spi design
[Re: Tornado_ALIVE]
#98047 02/05/07 05:45 AM 02/05/07 05:45 AM |
Posts: 4,451 West coast of Norway | Steve, have a good time at the worlds! I'll be rooting for you and Macca on the Blade! Wish I had the money to go down there with the family for a break in our abysmal winter. The Gran Segel guys in Malmø are really poor at marketing their products. As far as I know, the only good reference they have on F-18 spis is a victory in the Archipelago race with Will Sunnucks at the helm. I'll try to measure my Gran MK-4 tonight.. It's something I should have done a long time ago. The 910cm was the current setting in 2004 amongst the pros. With this setting, you could twist the luff about 45deg with your fist before it was tight. We used 910cm, but tightened the luff line to move draft a bit forward. We could not twist the luff much at all, and that was fast downwind if you could 'wild thing'. Take a look at these pics, from Mike Dobbs (username Tornado here) photoarchive. These are from the Miami OCR and T NA's, and demonstrate quite clearly how thight the luff is set on the Tornado these days. http://i5.pbase.com/o6/30/7530/1/73986543.uVpshoTo.IMG_3883.jpghttp://i5.pbase.com/o6/30/7530/1/73986546.GbLur4SS.IMG_3887.jpg | | | Re: Trends in spi design
[Re: Catfan]
#98049 02/06/07 08:04 AM 02/06/07 08:04 AM |
Posts: 12,310 South Carolina | I beg all the ownwers of Tornado and F18 cats who usually make posting on this Forum to provide us with their measurements Thanks I'm 5'8" tall, have a 33" waist, and weigh about 175lbs.
Jake Kohl | | |
567
guests, and 26
