What does it cost? #98559
02/08/07 07:30 PM
02/08/07 07:30 PM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
What does it cost to get a 21' cat painted?
Re: What does it cost? [Re: arbo06] #98560
02/08/07 08:11 PM
02/08/07 08:11 PM
Why? your boat looks great!
Re: What does it cost? [Re: arbo06] #98561
02/08/07 08:56 PM
02/08/07 08:56 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I've heard the bulk of the cost is attributed to the amount of kitty treats you need to keep a 21' cat still whilst its hue is altered.
Re: What does it cost? [Re: arbo06] #98562
02/08/07 09:55 PM
02/08/07 09:55 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I spent close to $2K painting Flight Risk, but that's 24' hulls, 3 crossbeams, center and fwd pods. I did 90% of the prep, and was around for masking and moving the pieces around over the course of 4 or 5 days. I used $950 worth of very expensive automotive paint (Viper red and Corvette yellow, with clear coat). The bodyman was a friend of mine, so I only paid him around $700, and the graphics guy got $200 for a days work.
Dave
Re: What does it cost? [Re: davefarmer] #98563
02/08/07 10:04 PM
02/08/07 10:04 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Better pic.
Re: What does it cost? [Re: davefarmer] #98564
02/08/07 10:18 PM
02/08/07 10:18 PM
Dave:
That is sweet. Are the mast and beams powder coated? I am thinking of doing that to mast and spars on sunfish when I rebuild it. They are really corroded now.
Doug
Re: What does it cost? [Re: Jake] #98565
02/09/07 07:53 AM
02/09/07 07:53 AM
arbo06 Offline OP
arbo06  Offline OP
It looks great but, you know how it is, I am aware of all of the scratches, dings, etc...
If it is affordable, i'd like it to be perfect, at least for a little while.
If I do all the prep and prime, do you think i could do it for less than $1,000.00?
Re: What does it cost? [Re: arbo06] #98566
02/09/07 08:26 AM
02/09/07 08:26 AM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
$1000 is probably doable if you can find someone who has the equipment to shoot if for you for cheap (less than $500). Depending on Color and paint system, you are probably looking at about $500 just for the paint, primer, reducer, converter, etc... If you do awlgrip, here is how I would do it:
sand existing paint with 150 grit
Shoot 1 coat of 545 epoxy primer
fill any dings, etc... with awlfair
sand with 150
shoot 1 coat of high build primer
longboard and fair
shoot 1 coat of 545
lightly sand
shoot 1st coat of finish
lightly sand
shoot intermediate topcoat
lightly sand
shoot final coat.
Some guys then wet sand and then shoot a clear coat on top.
Each step is not alot of time, but there are alot of steps. If you add up the materials needed to do this, it is close to $500 (could be more depending on colors). This is how we did mine, but did not do the high build (wish I had). The hard part is getting the right conditions (when the painter is available) to shoot the finish coats.
Good Luck!!
Todd Nacra 20 www.wrcra.org
Re: What does it cost? [Re: Todd Berget] #98567
02/09/07 01:32 PM
02/09/07 01:32 PM
How much weight does that add to the hull?
Re: What does it cost? [Re: waterbug_wpb] #98568
02/09/07 02:46 PM
02/09/07 02:46 PM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
not much if you sand off the gelcoat. paint is actually lighter than gelcoat. When you consider that you are sanding off alot of the primer, it is probably about the same weight.
Re: What does it cost? [Re: Todd Berget] #98569
02/09/07 10:34 PM
02/09/07 10:34 PM
arbo06 Offline OP
arbo06  Offline OP
as is
Re: What does it cost? [Re: ] #98570
02/09/07 11:11 PM
02/09/07 11:11 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Doug,
All my beams, boards, and the mast are composite construction, and they're all painted with the same automotive paints.
Dave
Re: What does it cost? [Re: davefarmer] #98571
02/09/07 11:24 PM
02/09/07 11:24 PM
Dave:
Have you ever done powder coating? I am just afraid paint on the mast of sunfish and scratch and flake off easy.
Doug
Re: What does it cost? [Re: ] #98572
02/09/07 11:58 PM
02/09/07 11:58 PM
West Michigan
F17_129 Offline
F17_129  Offline
West Michigan
I've never specifically looked for powder coating on sailing related items, but I've never been horribly impressed with it's abrasion resistance in general. In some cases I've seen it fail where it gets rubbed/hit repeatedly up and then just falls off in chunks. Probably why extrusions are anodized vs. powder coated in the sailing world
Re: What does it cost? [Re: F17_129] #98573
02/10/07 12:02 AM
02/10/07 12:02 AM
So what would it cost to get mast and spars on a Sunfish anodized? Any idea?
Doug
Re: What does it cost? [Re: ] #98574
02/10/07 12:52 AM
02/10/07 12:52 AM
That entire chunking falling off issue has to do primarily on how the surface was prepped prior to painting. If the surface was prepared correctly and thoroughly then the paint should stick darn good.
Powder coating involves baking the paint into the metal. I dont think it can be done on composites.
Anodizing I beleive involves dipping the metal into an electrically charged paint/chemical?
Both ways are pretty darn expensive for big items like a mast, boom, spinnaker pole or crossbeams.
Re: What does it cost? [Re: Robi] #98575
02/10/07 01:43 AM
02/10/07 01:43 AM
Mast and spars (or whatever call them? The two pieces that form a V to hold the sail) on the Sunfish are aluminum. What would you guys suggested, The are corroded pretty bad and I want to do something them as I rebuild Sunfish and add racing sails and parts.
Doug
Re: What does it cost? [Re: ] #98576
02/10/07 09:06 AM
02/10/07 09:06 AM
catman Offline
catman  Offline
Powder coating may be a slight step up from painting but it will still flake off. The earlier Mystere's used powder coating on the spars and beams and it flaked off.
I had my beams and mast media blasted, then I used a dupont etch for aluminum, then sprayed clear Imron on the bare alum. It lasted about three years. I just redid the the mast and beams last spring.
0 registered members (), 677 guests, and 36 spiders.
