| Re: That "cool" buzzing sound.
[Re: Dan_Delave]
#98630 02/09/07 01:19 PM 02/09/07 01:19 PM |
Posts: 5,590 Naples, FL | I had a 12kt and a 18kt "hum". I faired out the daggar and rudder trailing edges and removed the 12kt hum, but the 18kt hum remained. Over 18 kts, and the wind, water, and boat was making so much noise I couldn't tell if it faded out again or not....
Someone told me to fair the trailing edges unequally (like an airplane wing trailing edge) so that the edge does not vibrate as much as a symmetrical edge would.
[Re: hokie]
#98632 02/09/07 06:38 PM 02/09/07 06:38 PM |
Posts: 461 Victoria, Oztralia | Hi All If you go www.ahpc.com.au and look under the technical info, theres a document about noisy foils, I think written by Jim Boyer, might be worth a read, I can't remember all the detail, its been a while since I read it. Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: hokie]
#98634 02/10/07 06:44 PM 02/10/07 06:44 PM |
Posts: 829 Charleston, SC | In addition to fairing, having the correct mast and rudder rake should help too. And how would mast rake and rudder rake affect it?
Trey
[Re: NCSUtrey]
#98635 02/10/07 08:45 PM 02/10/07 08:45 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | Mine hum at about 3/4 speed and then quiet down when I really start hauling [noodle] (either that or I no longer focus on the noise at those speeds). I like it for the reason mentioned... it lets me know when I'm moving along nicely and when I lose speed. It is not a loud hum at all, my son calls it "whales singing".
-Rob V. Nacra 5.2 Rob V.
Nacra 5.2
Panama City | | | Re: That "cool" buzzing sound.
[Re: NCSUtrey]
#98637 02/11/07 12:10 PM 02/11/07 12:10 PM |
Posts: 168 San Diego | And how would mast rake and rudder rake affect it?
In the Boyer article posted above he mentions how putting on an assymetrical trailing edge creates some pressure on the foils to fix the problem, I think it would be along the same idea. Mast rake and rudder rake will change the pressure on the foils too. It seemed to work for my rudders but maybe it was because I didn't have these things adjusted correctly at first, though the changes I made were not huge. The first thing I did was switch the sides the rudders were on just to see and it helped a little. | | | Re: That "cool" buzzing sound.
[Re: hokie]
#98638 02/11/07 12:16 PM 02/11/07 12:16 PM | Anonymous
| Anonymous
Unregistered | Guys:
It has been my experience that mast rake LOADS the rudders up, raking the rudders forward REMOVES the load. Just make sure you have a little weather helm. NEVER want lee helm.
Doug | | | Re: That "cool" buzzing sound.
[Re: hokie]
#98640 02/11/07 02:01 PM 02/11/07 02:01 PM | Anonymous
| Anonymous
Unregistered | Hokie:
You may be be right. BUT in a long race, holding the ariba with two fingers is MUCH sweeter than having to PULL the %$$&**%^&^% <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> out of it. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
[Re: ]
#98641 02/11/07 04:44 PM 02/11/07 04:44 PM |
Posts: 473 Panama City, Florida | I went out today for the first time since doing a bottom job and the humming was a deeper tone and started (and stopped) at a lower speed. I would guess it started around 5 knots and stopped by 8. I didn't get much faster than that since winds were pretty light today, but at least I was able to determine that it did indeed stop and it wasn't because I couldn't hear through the splashing. I haven't done any work to my rudders or daggerboards, but I did change the standing rigging which might have changed the mast rake a little (not much though).
-Rob Rob V.
Nacra 5.2
Panama City | | |
285
guests, and 48
