| How to fix a hole in a boat? #98825 02/12/07 02:55 PM 02/12/07 02:55 PM |
Joined: Jun 2001 Posts: 833 St. Louis, MO, Mike Hill OP
Posts: 833 St. Louis, MO, | I have a golfball size chunk out of the leading edge of a keel boat about 3ft up from the bottom of the keel and 3ft. down from the boat. How should I fix this? What specific products should I use?
Thanks, Mike Hill
Mike Hill N20 #1005
| | | Re: How to fix a hole in a boat?
[Re: Mike Hill]
#98826 02/12/07 03:04 PM 02/12/07 03:04 PM |
Posts: 12,310 South Carolina | I have a golfball size chunk out of the leading edge of a keel boat about 3ft up from the bottom of the keel and 3ft. down from the boat. How should I fix this? What specific products should I use?
Thanks, Mike Hill If this is a monohull, you will need to fix this by sinking the boat - use lead or a good hole saw. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Seriously though, what's the keel made of? Is it a keel/fin that's made of lead? You can solder lead back in to fill the chunk. Otherwise, if the spot is stable, you might think about filling it with Bondo - but it sounds like a pretty big hole for that.
Jake Kohl | | | Re: How to fix a hole in a boat?
[Re: Dan_Delave]
#98828 02/12/07 04:59 PM 02/12/07 04:59 PM |
Posts: 833 St. Louis, MO, | Yes, it's well above the lead. It's just fibreglass. I was thinking I could fill it with epoxy somehow. Can you give me specific links to what I need. That would help a lot. Not structural at all. I just don't want it to pop out. There will be a coat of bottom paint going over the whole keel when finished.
Mike Hill N20 #1005
[Re: Mike Hill]
#98829 02/12/07 05:07 PM 02/12/07 05:07 PM | Anonymous
| Anonymous
Unregistered | Yes, it's well above the lead. It's just fibreglass. I was thinking I could fill it with epoxy somehow. Can you give me specific links to what I need. That would help a lot. Not structural at all. I just don't want it to pop out. There will be a coat of bottom paint going over the whole keel when finished. Alright, who was driving? | | | Re: How to fix a hole in a boat?
[Re: ]
#98830 02/12/07 08:07 PM 02/12/07 08:07 PM |
Posts: 12,310 South Carolina | Yes, it's well above the lead. It's just fibreglass. I was thinking I could fill it with epoxy somehow. Can you give me specific links to what I need. That would help a lot. Not structural at all. I just don't want it to pop out. There will be a coat of bottom paint going over the whole keel when finished. Alright, who was driving? Probably the person who's most worried about it being fixed <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
[Re: Mike Hill]
#98831 02/12/07 09:11 PM 02/12/07 09:11 PM |
Posts: 5,582 “an island in the Pacifi... | Yes, it's well above the lead. It's just fibreglass. I was thinking I could fill it with epoxy somehow. Can you give me specific links to what I need. That would help a lot. Not structural at all. I just don't want it to pop out. There will be a coat of bottom paint going over the whole keel when finished. Get Bondo with fiber impregnated into it. It'll be strong, easy to shape after it sets up and will take paint well. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: How to fix a hole in a boat?
[Re: hobie1616]
#98832 02/12/07 09:56 PM 02/12/07 09:56 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Mike: Go to this site West Systems then to Product information. Go down about half way and you will find the Colliodal Silca. You can use either the slow or the fast method by choosing the hardener (slow or fast). You can get fiberglass cloth, or mat and use scissors to get the chopped fiberglass. All of these items can be found at West Marine. West Systems at West Marine Later, Dan | | | Re: How to fix a hole in a boat?
[Re: Dan_Delave]
#98833 02/13/07 07:32 PM 02/13/07 07:32 PM |
Posts: 263 SC | I would use Evercoats formula 27, much like bondo developed for a marine environment,although I know Jake has had good sucess with bondo.
Always borrow money from a pessimist. He won't expect it back.
[Re: Dan_Delave]
#98834 02/13/07 07:39 PM 02/13/07 07:39 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | From someone who has done MAJOR fiberglass bottom work, here's a couple of things.
1. How long was the boat in the water with that hole? If very long at all, you may want to try to borrow a moisture meter to check and see if/how wet the surrounding glass has gotten.
2. How much damage does the surrounding glass have? If it's delaminated, it will need to be ground out till you get to solid glass again. The combination of wet and damaged could lead to blisters around the area in the future.
3. Something like that, we always filled in with replacement fiberglass and resin. You say the size of a golf ball, so I would put that on borderline glass vs. bondo. IMHO, below the waterline on a mono, structural or not, anything more than just a thin layer for fairing, I'd use glass. You would do that just like any other glass project. Remove all damaged material and paint first. Overlap with the original material and put on a layer, wait, put on a layer, wait. Then once it's built back up beyond it's original level, fair back off to be even with the surrounding hull.
4. If you don't use glass, make sure to use a barrier coat before applying the bondo, want to make 100% sure that the glass is sealed since you have the center exposed. You are more likely to have water intrusion and subsequent delamination later. Believe me I've taken a sand blaster to the bottoms of boats that only look to have mild to moderate blistering, only to find that a LOT of glass is delaminated by water intrusion. | | |
448
guests, and 272
